Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Unread 05-06-2012, 11:49 AM   #1 (permalink)
alexanderja's Avatar
help ...... stripped screw head !
Need to take my pickups out .... but I've got a screw head stripped completely round holding my pickup cover on.
Any tips for getting the screw out please ?
alexanderja is offline   Reply With Quote
Unread 05-06-2012, 12:07 PM   #2 (permalink)
BrambleMonkey's Avatar
Re: help ...... stripped screw head !
If you have a dremel type tool and a steady hand you could try cutting a new slot in the head. There's also screw remover tools available all over the place (I see you're in UK - I've seen them in pound shops before). If you're in a rush you could carefully glue a screwdriver into the stripped head.
Good luck!
BrambleMonkey is offline   Reply With Quote
Unread 05-06-2012, 12:26 PM   #3 (permalink)
Les Paul Addict
Kensei's Avatar
Halfords will sell you screw removers for very little. If you can wait a couple of days ebay item 130685379361
2003 Gibson Explorer Studio Pro Swamp Ash
2012 Epiphone Ace Frehley Budokan Custom!
2007 MIK Epiphone Zakk Wylde Custom Bullseye w/EMG 81+85s (18V)
2004 MIK Epiphone Joe Perry Boneyard
2003 MIK Epiphone Les Paul Standard w/SD Pickups.
2003 MIK Les Paul Gold Top w/Alnico Pro 2s
Marshall MG30CFX
Marshall MG100HFX into AVT412
"You've still got to listen to music with a fourteen year old's ears" True dat.
www.soundcloud.com/mrkensei Drummer and Singer wanted.
Kensei is offline   Reply With Quote
Unread 05-06-2012, 12:27 PM   #4 (permalink)
emoney's Avatar
In the past, when this has happened to me, I cut the screw head off, slipped the cover
off and removed the pick-up, which left just the screw shank. Used a set of locking pliers
to remove what was left. Then I just used a new screw to replace it all. My guitar was
older, so I'm sure the wood was soft in that area, so keep that in mind if you choose to
go that route. Big box stores do sell screw-removal tools that seem to work very well.
emoney is offline   Reply With Quote
Unread 05-06-2012, 04:10 PM   #5 (permalink)
greenhorn's Avatar
+1
The easiest way to do that is by drilling through the head of the screw with a bit the size of the screws shank. Once you're through, the head will start spinning and you can then proceed to remove the ring as emoney said. YMMV.
Good Transactions: handym4n ~ Tuya Customs ~ fiftywatt ~ kingedb
greenhorn is offline   Reply With Quote
Unread 05-06-2012, 04:24 PM   #6 (permalink)
It's done !
I used the Dremel and cut a new slot.
Big relief.
Thanks everyone .... I appreciate your time !
