MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Luthier's Corner
Unread 04-16-2012, 05:21 PM   #1 (permalink)
MLP Vendor
DGNRepair's Avatar
Does anyone have a source for Small Gibson Fretwire??
I have a 57 Goldtop in the shop, well its back with the customer for now, that is going to need a partial refret. I can't seem to find wire small enough, .070. The smallest I can find is Dunlop precut wire which is .075. Does anyone have a source for .070 x .030ish fret wire? Thanks for any help.
Dan
DGN Custom Guitars
Hand Made Custom Guitars
Repair and Restoration
Fairfield CT
http://www.dgncustomguitars.com
Find me on Facebook
Follow me on Instagram and Twitter
DGNRepair is offline   Reply With Quote
Advertisement
Unread 04-16-2012, 05:35 PM   #2 (permalink)
SG Lou's Avatar
Re: Does anyone have a source for Small Gibson Fretwire??
Dan
Dan,
I got a partial roll of some really narrow wire in the shop. I'm at work at the moment so when I get home tomorrow morning I'll measure what I got and get back to you. You're looking for 0.70 wide by .030 high ?
Lou
"It's all Iommi's fault. I blame him entirely"
Lou Gehrig's disease Sux.
Lets rid the world of this dreaded disease
I CAN'T SEE OR POST PICS,PHOTOBUCKET IS BLOCKED ON WORK PC'S
Guitars:
64 SG Special
Custom Shop Iommi Sig. SG
Epi Iommi SG
Jaydee "Old Boy" SG
Custom Built "Old Boy" SG replica
56 Les Paul Custom replica
63 RI Strat
Amps:
Laney TI100 1/2 Stack
Laney GH100TI 1/2 stack
Laney TI15-112 Tony Iommi Combo
Laney LC15R,
Line6 Spyder
SG Lou is offline   Reply With Quote
Unread 04-16-2012, 06:09 PM   #3 (permalink)
MLP Vendor
DGNRepair's Avatar
Originally Posted by SG Lou View Post
Dan,
Lou
Thanks Lou, that would be great. Yes, .070 wide and .030 high. I am most concerned with the .070 width. I would like the new frets the blend right in with the originals. If its up to .003 +/- it should still work for me. Thank you for checking.
The closest I have found is .063 and .075 both of which may be noticeable.
DGN Custom Guitars
Fairfield CT
Find me on Facebook
Unread 04-16-2012, 10:18 PM   #4 (permalink)
MLP Sponsor
alk-3's Avatar
Hey Dan. I have found on 57's the wire is consistently closer to .074” .. actually, to be more exact, it is .0735". What serial range is this 57? I wonder if a pattern might devellop as to when the wire changed a bit. I'm sure there are manufacturing tolerances though, so variability is to be expected I suppose.
Anyway, I have used .075 and dressed the edges ever so slightly to get them down a bit before I install them. I've actually found the wire's colour to be a bit of a problem more than the size. The new stuff is a bit more white, where the old wire has a bit of a faint golden hue to it. Heating the wire can introduce a bit of this coloring to blend them if need be.
alk-3 is offline   Reply With Quote
Unread 04-17-2012, 07:13 AM   #5 (permalink)
nuance97's Avatar
I measured the frets on a '56, and they measured .070/.071". I did some searching, and discovered the same thing. Nobody seems to makes the same size. I posted the question on $tewMac's facebook page. They said that nobody makes it, and Dan uses some kind of tool to shave a little of both sides until the correct size is achieved. They said they'd post a pic of the tool but never did. I imagine it being similar in concept to the Fret Barber.
nuance97 is offline   Reply With Quote
Unread 04-17-2012, 07:37 AM   #6 (permalink)
bruce bennett's Avatar
in this case, only Eric Johnson could "see" .005
you can sand that off with just a little 400 grit
you do realize that what your going with is a "spec" number not an actual number right.. Fretwire is horribley inconsistant, actually all die drawn metals are. they can vary by as much as .007 easy.
Bennett Music Labs
bruce bennett is offline   Reply With Quote
Unread 04-17-2012, 07:40 AM   #7 (permalink)
MLP Vendor
DGNRepair's Avatar
Originally Posted by alk-3 View Post
Hey Dan. I have found on 57's the wire is consistently closer to .074 .. actually, to be more exact, it is .0735". What serial range is this 57? I wonder if a pattern might devellop as to when the wire changed a bit. I'm sure there are manufacturing tolerances though, so variability is to be expected I suppose.
Tom the guitar has a stinger and no serial, but we believe it to be a very very early '57 based on the '56 pot codes.
I have measured more than half of the frets and they are all in that .070-.071 range. I can find .075 wire but not in full lengths of wire, just short cutup bits from Dunlop. The short 2.5" pieces with be much harder to work with if I need to shave them down slightly. Anyone know if the .075 comes in 2 foot lengths?
I did a quick setup on it yesterday and with the exception of 1 fret, the playability is passable for the customer. It looks like the refret is on hold for now. I am still actively searching for wire just to have on hand though.
DGN Custom Guitars
Fairfield CT
Find me on Facebook
Unread 04-17-2012, 07:44 AM   #8 (permalink)
MLP Vendor
DGNRepair's Avatar
Sadly I may be as crazy at EJ because I could see a difference. I was hoping I didn't have to order 2-3 brands of wire to get the right size, or close enough.
Where's the guy with the stash of vintage mid 50's wire stolen from the Gibson factory.
DGN Custom Guitars
Fairfield CT
Find me on Facebook
Unread 04-17-2012, 04:08 PM   #9 (permalink)
nuance97's Avatar
FWIW Gil Yaron also addressed this when I asked him where he found his. He said the same thing-that he couldn't. He had to buy larger wire and trim it down.
Telecaster Guitar Forum - View Single Post - 1959 Les Paul Build
Unread 04-19-2012, 11:10 AM   #10 (permalink)
SG Lou's Avatar
Dan,
I apologize for my tardiness in getting back to you.
My Dad took a spill ( 75 yrs old ) and not only did he mess his back up but he also ripped a 2" x 4" piece of skin off of his forearm. Needless to say I had a couple of busy days.
Anyway, The wire I got is .098 wide.
Sorry Mate, I thought it was narrower.
Lou
PS: the Old Man will live..........He's a tough old cookie !
Guitars:
64 SG Special
Epi Iommi SG
Jaydee "Old Boy" SG
63 RI Strat
Amps:
Laney LC15R,
Line6 Spyder
