Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Unread 04-03-2012, 03:21 PM   #1 (permalink)
155
155's Avatar
Purpose of pick up plane?
What. Is the reason for the pickup plane? If the neck plane is 4.4 and the pups are routed to that why a 1.2 pup plane? Not grasping why it's necessary...
155 is offline   Reply With Quote
Unread 04-03-2012, 03:36 PM   #2 (permalink)
'59_Standard's Avatar
Have you not seen this diagram:
'59_Standard is offline   Reply With Quote
Unread 04-03-2012, 03:44 PM   #3 (permalink)
JRo
JRo's Avatar
Re: Purpose of pick up plane?
Someone correct me if I'm wrong; I think it's to better line up the pickups with the string path.
JRo is offline   Reply With Quote
Unread 04-03-2012, 03:45 PM   #4 (permalink)
155
155's Avatar
I have seen the diagram I just dont see the reason for it...what am I missing? why cant it be flat?
Unread 04-03-2012, 04:02 PM   #5 (permalink)
TravisW's Avatar
As far as I'm aware, it's to give the bridge room to exist.
TravisW is offline   Reply With Quote
Unread 04-03-2012, 05:33 PM   #6 (permalink)
MojoMonster's Avatar
You can have it flat if you recess the bridge/tailpiece to keep the break angle intact.
MM
2009 Gibson LP Standard Trad Pro Heritage Cherry Sunburst, 2007 Edwards LP-130LTS/RE-LMD, 2010 Gibson LP 50's Tribute Studio Goldtop w/Bigsby, 2006 Gibson LP Special DC Faded Cherry, 1989 Carvin DC135T, 1988 Carvin SH225, 1998 MIJ Squier Vista Venus, 2005 MIA Squier Affinity Telecaster, 2006 Ibanez Artcore AS83VLS, ShredStrat w/FR, SwampStrat w/ StraBro90's, Carvin V3 & V30 412, Egnater Rebel 30, Dave Hunter Two-Stroke, 2xCarvin 212CE, 2xCarvin 212 Classic
MojoMonster is offline   Reply With Quote
Unread 04-03-2012, 05:39 PM   #7 (permalink)
Bartlett Retrospec Member
nuance97's Avatar
If you skipped the pu plane then you'd end up with the neck pickup in the 4 degree (+/-) neck plane, and the bridge pickup would be flat (zero degrees). The pickup plane puts the pickups flat relative to one another.
nuance97 is offline   Reply With Quote
Unread 04-03-2012, 05:58 PM   #8 (permalink)
155
155's Avatar
ok that makes sense,, if the neck plane goes through the neck pup...but what if there is no neck pup and the neck plane ends at the end of the fingerboard? seems to me it would be fine if it was flat for the bridge pup? no?
Unread 04-03-2012, 06:02 PM   #9 (permalink)
nuance97's Avatar
It could be made to be functional, but you'd see a hump at the point where the neck plane intersects the flat plane of the top. The hump would be somewhat obscured by the strings, but it would be better to just do the pu plane.
Unread 04-03-2012, 06:07 PM   #10 (permalink)
155
155's Avatar
well in my particular case its not a carve top so the neck plane will be feathered into the "flat top" hence no real hump as i will be using body contours rather then a carve top and Id rather not do the pup plane as it would create yet another "hump" on the top as it is flat...sorry for the confusion here just want to make sure im not missing something here...thx
Unread 04-03-2012, 06:33 PM   #11 (permalink)
nuance97's Avatar
Juniors, Speicals, and SGs have the neck angle routed in the neck mortice, and the whole top is flat. The pickup plane is needed on a carved top like a LP Standard.
Unread 04-03-2012, 08:19 PM   #12 (permalink)
MLP Vendor
dougk's Avatar
BTW you dont NEED the PUP plane. Lots of guitars don't have them and its fine.
Its on an LP to make the pup's (between angled rings and the pup plane) sit parallel to the strings. Long as you have enough neck angle for your TOM bridge the rest is purely up to what and how you design.
Originally Posted by DoneOne View Post
dougk 1:9 "there is nothing new under the Sunburst"
4/27 KAUER/RHONEY OPEN HOUSE! FOOD-MUSIC-BEER-GUITARS!
Owner: Kauer Guitars
Fan us on Facebook
Kauer Guitars: Federal Raid Free Since 03!
dougk is offline   Reply With Quote
Unread 04-03-2012, 08:26 PM   #13 (permalink)
emoney's Avatar
And you could always angle your pickup routes if you needed to in order to get the
p'ups flatter in relationship to the strings.
emoney is offline   Reply With Quote
Unread 04-03-2012, 09:42 PM   #14 (permalink)
TKOjams's Avatar
I have found if you don't rout a pup plane, the neck pup sits too high and the pup ring hits the strings unless you sand the bottom of the pup ring. Don't ask me how I know.
TKOjams is online now   Reply With Quote
Unread 04-03-2012, 10:13 PM   #15 (permalink)
155
155's Avatar
thanks guys!
