Old 09-06-2008, 12:34 AM   #1 (permalink)
BJA Les Paul Jr tuning Problem
I am having a problem keeping the g string in tune. I bought the guitar and had it setup rather quickly. It was set up about a month ago and has the same strings from the setup. It has never stayed in tune. I noticed the g string tuner seems to tune up then slip back a little bit. It is harder to tune than the rest of the strings. Do you think this could be an issue? If so, are there better tuners for a Les Paul Jr. The one on it now are three on each side. All three are connected together.
Any thoughts would be appreciated.
Thank you.
see image at www.millstar.net
btomlinson is offline   Reply With Quote
Old 09-06-2008, 04:53 AM   #2 (permalink)
John Catto's Avatar
Re: BJA Les Paul Jr tuning Problem
99% probably the way the nut's cut.
John Catto is offline   Reply With Quote
Old 09-06-2008, 08:18 AM   #3 (permalink)
Grumpy Old Luthier
BCRGreg's Avatar
Fold a piece of 800 grit paper in half and gently work the fold back and forth in the slot. Tune up the string and put a tiny dab of Chapstick in the slot.
Fixed.
www.bcrmusic.com
www.grumpyoldmenband.com
http://www.youtube.com/user/unkagreg
www.ristguitars.com
BCRGreg is online now   Reply With Quote
Old 09-07-2008, 12:04 AM   #4 (permalink)
Thank you so much for your thoughts.
Is this because the nut may not be holding the string steady. The deeper slot will allow the string to remain in one spot on the nut? This will keep the tesion more consistant? I looked at the nut and the slot does not cut through the whole nut. Do you think this is why it will not stay in tune. Because it is setup, I don't think i want to lower the string with a deeper slotted nut. Maybe ajust a subtle increase?
Thanks again. I apprecuate your help
Old 09-07-2008, 12:20 AM   #5 (permalink)
kspeed's Avatar
Don't deepen the groove, slightly widen it. The issue is likely that the G string is getting caught or is "binding", which is why your tuning probably tends to "jump" and it's tough to get it just right or to keep it in that key once you get it there.
kspeed is offline   Reply With Quote
Old 09-07-2008, 12:25 AM   #6 (permalink)
That make sense. Thanks to all.
Old 09-07-2008, 09:21 PM   #7 (permalink)
Should the slot go from the front of the nut all the way to the back?
Old 09-07-2008, 09:26 PM   #8 (permalink)
kspeed's Avatar
Not on a nut for a LP - the slots should only be on top (the rounded off area):
Old 09-08-2008, 07:51 AM   #9 (permalink)
Thanks so much. I just need to find some 800 grit sand paper.
Old 09-08-2008, 10:51 AM   #10 (permalink)
ehamady6's Avatar
Big Bends Nut Sauce could also help: Big Bends Home Page: Stay in Tune and end Broken Strings
ehamady6 is offline   Reply With Quote
BJA Les Paul Tuning Problem btomlinson Gibson Les Pauls 11 09-06-2008 07:33 PM
strange Problem on a les paul vaibhav Luthier's Corner 28 08-25-2008 05:04 PM
1979 Les Paul Standard Ground problem. Rasputin Gibson Les Pauls 22 04-06-2008 02:11 PM
Problem with a String Tuning Fork SlashB The Backstage 0 03-29-2008 06:21 AM
My Les Paul Problem.....help!!!!!!!!! st.bede Tonefreaks 9 01-24-2008 02:56 PM
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
