#1 (permalink) |
Tony Iommi's SG Build
Well I have gotten far enough along with this that I can finally post for all to see. Templates for neck profile, body, headstock shape and the raw materials. I had already inlayed the dots in the fingerboard when I took this "group shot. Logs to Lumber supplied the Ό sawn 3 3/4 x 3 3/4 x 36 neck billet eBay My World - logstolumber0 North Ridge Hardwoods supplied the 14 x 19 x 1 ½ body blank Luthier Tonewood Supplier, Guitar Tops, Body Blanks, Acoustic Sets, Neck Blanks ![]() Lets start with the Fingerboard. It's an ebony pre slotted Gibson scale from Stew-Mac Found the center of the board, intersected a center line at each position marker and drilled them out ![]() ![]() A drop of Crazy Glue into each hole and in went the 1/4" pearloid dots ![]() Drawing the Neck outline of the template ![]() Marking the 22nd fret ( where neck will join the body ) and the end of the fingerboard so I can mill off the "Drop off" area just past the end of the FB ![]() ![]() Milling the 3 degree angle into the tenon ![]() ![]() Flip the neck over and mill the -3 degree angle onto the bottom of the tenon. ![]() ![]() Here you can see the angle in the neck tenon with the "drop off" and the bottom of the tenon parallel with each other. ![]()
"It's all Iommi's fault. I blame him entirely" A.L.S. aka Lou Gehrig's disease Sux. Lets rid the world of this dreaded disease ![]() I CAN'T SEE OR POST PICS,PHOTOBUCKET IS BLOCKED ON WORK PC'S ![]() Moritz Guitars stmoritzguitars@hotmail.com Guitars: 64 SG Special Custom Shop Iommi Sig. SG Epi Iommi SG Jaydee "Old Boy" SG Custom Built "Old Boy" SG replica 63 RI Strat Amps: Laney GL50 head w/4x12 Laney Cab. Laney LC15R, Line6 Spyder |
| The Following 19 Users Say Thank You to SG Lou For This Useful Post: |
#2 (permalink) |
Re: Tony Iommi's SG Build
Body blank rough cut on the bandsaw.
I busted my last 1/4" blade so I had to use a 3/8" blade instead. What a BITCH to cut tight curves with it ! ![]() Body template that was accurately Cad drawn off of a early 60's SG Jr. THANKS MAGNUS ! ( Note the reminder : THIS SIDE UP LEFT HAND ) I had to write that on all of the templates so I don't mess up ! LOL ![]() Routed to shape with a 1/2" bearing guided template bit. ![]() Holes drilled ![]() Control cavity's excess was drilled out with a Forstner Bit and routed to final shape and depth. Cover lip was routed out along wuth the cover it's self. ![]() ![]() ![]()
#3 (permalink) |
YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES ! ! ! ! ! ! ! ! !
Let's do this ![]() ..........I mean you. Let's let YOU do this! |
#4 (permalink) |
Stew-Mac Hot Rod Truss Rod slot cut and T/R set into place
![]() ![]() FB profile cut - 1 11/16th" at the nut and 2 1/4" at the end. using this jig I made. It's set exactly 4 1/2" between the blade and the fence. Line up my marks at both ends with the edge of the board and the angle is cut. ![]() ![]() Don't "Fret"...Just do it ! LOL I also run the wire through my home made fret wire radii thingamajig ! ![]() ![]() Smear a little Titebond into the slot, wipe excess with a damp cloth and hammer in the fret. ![]() ![]()
#5 (permalink) |
Head stock ears and veneer glued up.
![]() ![]() ![]() Shaping the body bevels with a rasp and 80 grit sandpaper. ![]() ![]() ![]() ![]() ![]() Side view of Bevels ![]()
#6 (permalink) |
Some Naphtha wiped on the body
![]() ![]() ![]() Binding glued to the FB edges and FB glued to the neck blank ![]() ![]() ![]() ![]() Headstock shaped, tuner holes drilled out.
#7 (permalink) |
Neck blank profiled, side maker dots holes drilled out. dots added.
![]() ![]() ![]() So after 4 days this is where I'm at. I'll shape the back of the neck maybe tomorrow and i'll route the mortise into the body. If all looks good I'll glue up the neck and the bulk of the build is done ! ![]()
#9 (permalink) |
You and ME both
![]() and Thanks !
#10 (permalink) |
Thoughts:
1. I'm CRAZY stoked for you 2. Glad to see someone else using 2 1/4 at the end of the fretboard. A man after my own heart. 3. Still super stoked for you! 4. Quit smokin! ![]() Sully |
#11 (permalink) |
PS:
1. My bandsaw blade is 3/8'. Yep, tight curves suck! 2. I feel your lefty pain. Makes you second guess just about everything! |
#12 (permalink) |
Super cool. I'm in the middle of reading "Iron Man" right now. Can't wait to see this one done!
. . . One out of every three Americans is suffering from some form of mental illness. Think of two of your best friends. If they are OK, then it must be you. ![]() George Carlin http://soundcloud.com/job-job-type-job/wake-up-chi ![]() |
#16 (permalink) |
Lou you should make/sell plans or templates..with a man of your sg knowledge people like me would storm to get some
Building instruments not for money, but for an obsession |
#19 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Apr 2010
What, no cross inlays?
2010 Epi Les Paul Trad Pro | Bordeaux | 2000 Squier Strat | Barney 2003 Squier P-Bass | Boomer | 2010 Epi DR-100 | Brownie "Die 4 U" now available at Bandcamp |
#25 (permalink) |
![]() Join Date: Mar 2007
looking mighty fine Lou
![]() blah blah blah, blah blah blah blah blah. BLAH?! Blah BLAH BLAH???!! A.Lifeson |
#30 (permalink) | ||||
#1. Still stoked ! #2. It just makes it easier. IMO #3. Keep asking myself if this is for real ? #4. Easier said then done. Coffee and Cig's is whats keeps me going when i'm in the shop ! Quote:
I was at the NJ book signing that Tony did so I got it autograped as well. Thats where we sealed the deal for me to build him an SG ![]() Quote:
![]() Nope, He has plenty of SG's with cross inlays. I'm building him a replica of his 64 SG Special aka Monkey SG ![]() ![]() Quote:
![]() Thank you all for the kind words Guys...........Coming from "Master Builders" like your selves it means a lot !
