Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Like Tree371Likes
Unread 02-28-2012, 09:49 AM   #541 (permalink)
TKOjams's Avatar
Re: 57 Custom replica Build
Originally Posted by stmfitr636 View Post
How much work went into leveling or otherwise sanding/polishing/buffing the color coat before going ahead with the clear coats?
I wondered about any transferring of orange peel or other defect through after clearcoat is leveled/sanded/polished/buffing/etc.
I never sand a color coat.
Where is the orange peel
TKOjams is offline   Reply With Quote
Unread 02-28-2012, 09:59 AM   #542 (permalink)
ltdave32's Avatar
Not trying to speak for Ken, but sanding the color coat is risky business. What one does to achieve a level surface is to diligently block-sand the flat surfaces of the guitar, then apply a sealer (grain fill can be done after the sealer and sanded), then spray a color coat, which is very fragile, no runs, etc. This is only a few thin coats of color. To sand at this stage would burn through the color coat, and you would have to start all over again. Several coats of clear are applied over the color, and the project is wet-sanded with a block to achieve a flat, glass-smooth surface, then buffed to achieve a mirror-like appearance.
One doesn't have to worry about orange peel on the color coat; multiple clear coats and sanding them will take care of any orange peel.
Ken buddy, I don't think he was implying there is orange peel, I think he's asking about how to generally avoid color coat orange peel transferring through.
"They’re based on 1950’s technology, for god’s sake! Have we no shame?"
-Henry J, on his own company's guitars.
Originally Posted by realjimjim
"She was an old sailor's widow . . . . we met in a waterfront bar . . . she could have been my mom, or maybe even my grand mom."
ltdave32 is offline   Reply With Quote
Unread 02-28-2012, 10:29 AM   #543 (permalink)
TKOjams's Avatar
Oh, gotcha
Excelent explanation, Dave. I thought he saw some orange peel and I went running out to the shop and inspected the guitar. I useally finish up at 2am, so I may have missed something.
The cool thing about the color coat is the clear hides a load of imperfections in it.
At least with black, I don't know about any other color, haven't used any others yet.
Unread 02-28-2012, 07:20 PM   #544 (permalink)
Drew224's Avatar
I'm loving those gold keystone Grovers.
I almost want to say go ahead and add a third pickup, but maybe you should see how you like it with just two, first.
TKOjams likes this.
Scarlet White
Drew224 is offline   Reply With Quote
Unread 03-01-2012, 01:04 AM   #545 (permalink)
TKOjams's Avatar
I like them also, I was going to go with the Kluson Waffleback repros but, I don't like the button color on them. If they were off white, yes, but they're mother of toileteseat and ugly. (to me YMMV)
Drew224 and mondrian like this.
Unread 03-01-2012, 01:49 AM   #546 (permalink)
Originally Posted by TKOjams View Post
...but they're mother of toileteseat and ugly. (to me YMMV)
I'm sorry, I just had to do that.
I LOL'd so hard, people at work think I'm crazy.
FWIW, TKO, you've done one hell of a build, man. Kudos to ya!
TKOjams likes this.
mondrian is offline   Reply With Quote
Unread 03-01-2012, 05:39 AM   #547 (permalink)
TKOjams's Avatar
Unread 03-01-2012, 08:44 AM   #548 (permalink)
Cpt_Gonzo's Avatar
...I like them!
But I really prefer Grovers on Les Pauls. Personal thing, but I think that the added weight to the headstock adds sustain and attack.
Drew224 likes this.
Cpt_Gonzo is offline   Reply With Quote
Unread 03-01-2012, 09:17 AM   #549 (permalink)
Bartlett Retrospec Member
Ole'Lefty's Avatar
I think this is my favorite build(it already has an edge over others because the BB is my favorite factory LP) of those I have seen. Do you use the "mirror- back chisel" technique when mitering binding?
Ole'Lefty is offline   Reply With Quote
Unread 03-01-2012, 09:30 AM   #550 (permalink)
TKOjams's Avatar
Thanks Lefty,
I'm not clear on that technique, I just used an exrtemely sharp razor blade and cut it by eye.
Unread 03-01-2012, 10:09 AM   #551 (permalink)
Ole'Lefty's Avatar
For those that are not as steady as TKO-flatten the back of your chisel and take it through the stones to a mirror polish back. When used to miter, the mirror shows the angle-you just look at the image reflected.
Now, all of my chisels are mirrored like that but for providing the truly flat back that allows the best sharp edge. The other is a side benefit.
Unread 03-01-2012, 10:26 AM   #552 (permalink)
TKOjams's Avatar
Hum, cool! I'll have to try that out someting.
Thanks
Unread 03-01-2012, 10:42 AM   #553 (permalink)
Ole'Lefty's Avatar
I have an old Swan 1/2" parer that I use only for binding trim. I took that one past 12000 grit and .5micron diamond paste. My honing sequence is, flatten back to 8K Shapton. Hollow grind on a Tormek and hand hone micro-bevel up to 8K Shapton and strop on hard leather with the diamond paste. If I have to reset a working bevel I use a jig on stones. Really I use the Tormek for shaping, more than sharpening/honing.
Unread 03-01-2012, 11:33 AM   #554 (permalink)
JimmyPage968's Avatar
TKO, do these Wafflebacks have an imroved base for more contact with the headstock? I got Grover Kluson style and they are a couple steps up from the Klusons.
Improved post, no wobble
Bolt down, no bushings
Flat base for max contact and stability to the headstock.
They're great!
JimmyPage968 is offline   Reply With Quote
Unread 03-01-2012, 12:41 PM   #555 (permalink)
TKOjams's Avatar
They're great!
I have no idea. I have never had a set in my hands. Due to the ugly ass buttons......I doubt I ever will.
Unread 03-01-2012, 10:41 PM   #556 (permalink)
Haha! I never had any good experience with Kluson tuners!
TKOjams and Reverend D like this.
Unread 03-02-2012, 05:43 AM   #557 (permalink)
Guitar Goober's Avatar
Great build TKO! Looking forward to seeing the final pics.
I have some major GAS for a black '57 custom now... and it's all thanks to you!
TKOjams and Bruiser74 like this.
Guitar Goober is offline   Reply With Quote
Unread 03-02-2012, 10:17 AM   #558 (permalink)
Exactly, thanks.
I haven't finished anything yet, so I'm trying to absorb enough so that I don't screw up too bad when I do. And having to remove several layers of clear to fix an imperfection in a color coat is not something I want to do.
I'm kinda a stickler for a nice finish... I'm sending my new car to be buffed out because I can't stand the orange peel from 99% of factory paint jobs. Didn't know if that would include going thru the clear to color to fix... glad it doesn't!
TKOjams likes this.
stmfitr636 is offline   Reply With Quote
Unread 03-03-2012, 11:10 AM   #559 (permalink)
BEAUTIFUL.......
If I ever do another LPC, I'm going to make certain to either do all-mahogany or the butt-ugliest plain maple top so I'm not derailed from the glory that is an all-black Custom.
Ready to see your finished result...the crowning touch of your wife's penmanship truly makes this one-of-a-kind. Outstanding work!
TKOjams likes this.
Red Flametop is offline   Reply With Quote
Unread 03-04-2012, 07:03 AM   #560 (permalink)
just incredible! screw bursts...customs and goldtops is where its at :P
i just love reading threads like these, thanks for documenting the process!
i've always loved working with my hands and its my dream to have a small shop like that one day...
different than yours but another clip of an amazing sounding and looking custom:
macklanders, TKOjams and Bruiser74 like this.
Toris93 is offline   Reply With Quote
Unread 03-05-2012, 10:01 AM   #561 (permalink)
FF_Pedals's Avatar
I can't remember if this came up before, are you going to do anything to yellow the binding like an amber clear coat? Or will the lacquer you used yellow over time?
FF_Pedals is offline   Reply With Quote
Unread 03-06-2012, 06:07 AM   #562 (permalink)
TKOjams's Avatar
I've been pondering this myself.
Unread 03-06-2012, 10:12 AM   #563 (permalink)
FF_Pedals's Avatar
Only you can decide
................DO IT
Unread 03-06-2012, 10:28 AM   #564 (permalink)
PM sent.
I'm loving this build!
Outstanding work.
TKOjams likes this.
MBrennan is offline   Reply With Quote
Unread 03-06-2012, 12:11 PM   #565 (permalink)
emoney's Avatar
Of course, I think 3 p'up guitars are the bomb and that was my intent all along with my
RIT Dye burst. Accident-smaxident.
WHITE...sorry, I got a little excited, but this thing is begging to be left white on the edges.
So......where's this lovely beauty at present? Shouldn't we be getting the video treatment
at this point? If I could come even close to pulling off this finish, I would've went with
solid black as this thing is as classy as a good tuxedo. Maybe I should just ship you
mine..........
emoney is offline   Reply With Quote
Unread 03-06-2012, 12:23 PM   #566 (permalink)
TKOjams's Avatar
(in my best Bill Cosby voice) ..........................Right!
mine..........
It's sitting in the shop, waiting for some of that "Best weather in the US" to head up north, so I can finish spraying the clear.
Unread 03-06-2012, 01:30 PM   #567 (permalink)
emoney's Avatar
We may need to make a "you shoot the color and I shoot the clear" arrangement. At least
until the "frozen tundra" thaws......then you can do all the shooting.
TKOjams likes this.
Unread 03-10-2012, 02:07 PM   #568 (permalink)
TKOjams's Avatar
I finished up the DC, so........
Back to my beauty!!!!
First wet sand, and more clear.
Unread 03-10-2012, 02:35 PM   #569 (permalink)
crompo's Avatar
Looking good - what's with the black custom body sitting on the floor in the photo ?
Another project ?
Wayne.
crompo is offline   Reply With Quote
Unread 03-10-2012, 02:38 PM   #570 (permalink)
TKOjams's Avatar
Another project ?
Wayne.
That is an fake gibson LP custon i found, and then tore it aport to see what it was made of. Just in case you didn't know, it's made of sh!t.
Bruiser74 likes this.
