Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Unread 08-11-2008, 09:56 PM   #1 (permalink)
Wraparound Tailpiece Stud Question
I bought a Gibson 24-3/4" Scale Fingerboard (compensated and based on a true scale of 24 9/16) from stew mac for a LP Special I am building. I would like to get the stud placement for the wraparound bridge right on the first try so any help would be appreciated.
I entered 24 9/16 (24.5625) in stewmacs Fret position calculator to get the bridge placement and I get this result
[24.623" (±0.030") from nut to center of mounting studs.]
Does this mean 24.593" for the bottom stud and 24.653" for the top?
jwc574 is offline   Reply With Quote
Unread 08-12-2008, 07:01 AM   #2 (permalink)
John Catto's Avatar
Re: Wraparound Tailpiece Stud Question
Couple of points here, first being that not all wrap tailpieces have their studs placed inline with the point the strings roll over. Once you establish that point of function place the studs based on this. Forget the fret position calculator and measure from the nut to the 12th fret. That distance from the 12th fret to the bridge is your starting point however the only string that will intonate close to that point will be your high E. Beyond that you only ADD length never take it way so place the studs so with the adjustment screws backed right out the high E "saddle point" is at that distance (same as nut to 12th fret) and the Low E is about a 1/4" back. In fact you said it's a compensated bridge and those are meant to be placed straight NOT at an angle though a tiny amount (1/32 - 1/16) may make it intonate better.
John Catto is offline   Reply With Quote
Unread 08-12-2008, 07:17 AM   #3 (permalink)
BCRGreg's Avatar
A Compensated bridge is supposed to have uniform spacing for both studs.
The earlier style bridge is tilted, with the bass side stud about 5/16" back....
IF you are using a non compensated bridge, you have to remember to shift both studs 5/32" to the bass side, to account for the strings angling over the bridge. If you drill with the bridge centered, the high E string will be too close to the edge of the board.
Great avatar, John, as usual.
www.bcrmusic.com
https://www.facebook.com/pages/BCR-M...76454402425822
BCRGreg is offline   Reply With Quote
Unread 08-12-2008, 07:29 AM   #4 (permalink)
Dino's Avatar
Originally Posted by John Catto View Post
... measure from the nut to the 12th fret.
Center of the 12th fret?
Or the actual fret wire?
btw ... love the avatar.
Dino is offline   Reply With Quote
Unread 08-12-2008, 07:31 AM   #5 (permalink)
BCRGreg's Avatar
Break point of the nut to center of the fret.
www.bcrmusic.com
Unread 08-12-2008, 08:38 AM   #6 (permalink)
Dino's Avatar
That's what I thought, but I wasn't sure.
Thanks Greg.
Unread 08-12-2008, 09:37 AM   #7 (permalink)
BCRGreg's Avatar
Thank John, too, Dino. Be polite or we'll withold your food for a while.....
www.bcrmusic.com
Unread 08-12-2008, 10:14 AM   #8 (permalink)
Dino's Avatar
THANKS JOHN!
I'm Sorry .... I must have been totally distracted by your avatar.
Unread 08-12-2008, 10:34 AM   #9 (permalink)
BCRGreg's Avatar
HAHAHA!!!!!
Catto with the WIN!
www.bcrmusic.com
Unread 08-14-2008, 06:52 PM   #10 (permalink)
Thanks guys. I took your advice and drilled for the posts last night. Strung it up today and intonation is perfect.
Unread 08-17-2008, 11:34 AM   #11 (permalink)
BCRGreg's Avatar
Excellent.
www.bcrmusic.com
