Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Like Tree6Likes
Unread 07-15-2011, 03:57 AM   #31 (permalink)
Powerless
Barnaby's Avatar
Re: ,.;-~*~-;.,Vistoluk's strat build,.;-~*~-;.,
Great space and love the company name! This is for you...
All success, man! You deserve to do well.
Originally Posted by Roman View Post
I cant die, I have too many guitars to do.
My first and second build threads
My third and fourth build threads
My fifth and sixth build threads
Barnaby is offline   Reply With Quote
Unread 07-15-2011, 06:14 AM   #32 (permalink)
Whoa - that's some sexy wood you got there!!!
I still frequently check the pictures of your Mockingbird... one of my favorite build threads! - Keep up the great work.
A few questions regarding the Strats, if I may:
What scale length did you use? - Original fender?
What neck angle (if any) did you use?
cheers,
-Tom
schoeftinger is offline   Reply With Quote
Unread 07-15-2011, 06:45 AM   #33 (permalink)
ptate's Avatar
The strats are 25.5 inch (unsure about Vistoluk's) and there is no neck angle, they're laid flat.
Just love that burst, there's a clarity and purity to it that just shouts class...!!
- www.facebook.com/MississippiRelic -
ptate is online now   Reply With Quote
Unread 07-15-2011, 06:51 AM   #34 (permalink)
Powerless
Barnaby's Avatar
...as opposed to Dirty Sal, who shouts "Oi! Buy us a beer ya b@stard and I'll show you me...lawks, Vicar, wotcher doin' in 'ere, then?"
ptate, Reverend D and Vistoluk like this.
Unread 07-15-2011, 06:53 AM   #35 (permalink)
ptate's Avatar
So you've met my ex-girlfriends then.....?
Barnaby likes this.
Unread 07-15-2011, 06:58 AM   #36 (permalink)
Powerless
Barnaby's Avatar
Yep. Funnily enough, lots of us have...
Reverend D likes this.
Unread 07-15-2011, 07:03 AM   #37 (permalink)
ptate's Avatar
I wondered why her nickname was Chunnel????
Better not derail Vistoluk's thread any more debating the integrity of delicate females....Ahem.....
Unread 07-15-2011, 09:34 AM   #38 (permalink)
Vistoluk's Avatar
‪Dynasty TV Opening Theme‬‏ - YouTube
Haha oh god is it sad that I "may" have watched that whole video...and i "may" have saved it to my computer? Hey it still may be a better use of my time than...well idk, i guess not a whole lot
cheers,
-Tom
Ha thanks tom I have that guitar buried under a few other cases right now kinda forgot about it until now
Yeh ptate's right I used 25.5 and no angle, it's pretty standard.
Ha I can't say i'm not still laughing at that conversation that I so obviously missed by about 8 hours
Vistoluk is offline   Reply With Quote
Unread 07-17-2011, 02:12 PM   #39 (permalink)
Vistoluk's Avatar
So i have a bit of a dilema as far as my finishing goes....since i'm sprayign outside.
It's about 100+ degrees here and the humidity is around 85....MN....
I sprayed my first of last 4 coats yesterday (coat 9/12, after I did a complete level sand) when the temp. was down to 90 and humidy to 70 (lateron), but the finish dried really fast and I got alot of blushing. THe lacquer I sprayed was reduced 40%, and i've never had this problem so it must be due to the humidity. any advice on whether what the min. humidity should be before I spray? I just don't want to take any chances, but at the same time, I sort of have a deadline. thanks
Unread 07-17-2011, 03:34 PM   #40 (permalink)
fatdaddypreacher's Avatar
i just got thru with a set of cabinets and they blushed pretty bad on me. i thought i would have to sand and recoat, but i decided to try to see if a soft clean rage wet with lacquer thinner would help. it fixed me right up. if you wipe too much, though, it softens the finish and makes it tacky and smudges. i'd try it on a test area gently, first, though. i'm not a finishing expert, but desparate times calls for desparated measures.
fatdaddypreacher is offline   Reply With Quote
Unread 07-23-2011, 09:57 PM   #41 (permalink)
The shop looks good - but I have to keep my guitars , amps and recording equipment out of mine because of the dust - too bad...
jonas 335 is offline   Reply With Quote
Unread 07-26-2011, 09:50 AM   #42 (permalink)
Vistoluk's Avatar
Thanks for the imput! I tried that under the pickguard but figured it'd be best to just spray a thinned down coat. Kind of the same thing but less chance of me using uneven pressure. WOrked out well and all the blushing disappeared.
Haha thanks, I was working on someone's instrument and was at the point where i had to set it up so I just brought my amp down. not a perm. part of my shop!
UPDATE:
I've sprayed the final 4 coats on my first neck! It will be strung up in 2-3 weeks so I can see how everything plays, then i'll buff it out about 5-6 weeks after that!
The second strat should be finished up today, if all goes well with the weather today and spraying. I'll try and get some pics up tonight! Off to do some level sanding....
Unread 07-26-2011, 07:27 PM   #43 (permalink)
Powerless
Barnaby's Avatar
Can't wait to see - this should be good!
I'll be trying your setup for a spraybooth in September, I think. Thanks for that again.
Unread 08-03-2011, 08:55 PM   #44 (permalink)
Vistoluk's Avatar
Okay Instrument number 6 is finally completed (excepting it will get buffed in about 6 weeks). This is one of 3 strats that i've been building. The other strat is at the same point but I will probably not get it put together until it is buffed, unless There is a potential buyer that wants to see it put together.
Send me a private message if you're interested in buying this guitar, i have yet to order pickups so those could still be personalized for the buyer. Hope you like it!
Barnaby likes this.
Unread 08-04-2011, 07:05 AM   #45 (permalink)
ptate's Avatar
Beautiful man
Unread 08-05-2011, 11:59 AM   #46 (permalink)
Vistoluk's Avatar
thanks! should have the 2nd one done in a few days and up soon
Unread 08-06-2011, 02:53 PM   #47 (permalink)
Reverend D's Avatar
Beautiful guitar, love the flame on the neck, someone took a bite out of your headstock though?
Regards,
Don
Reverend D is offline   Reply With Quote
Unread 08-06-2011, 03:09 PM   #48 (permalink)
^^well, it does look good enough to eat.
Unread 08-06-2011, 05:22 PM   #49 (permalink)
Reverend D's Avatar
That is true!
Regards,
D.
Unread 08-06-2011, 05:48 PM   #50 (permalink)
Vistoluk's Avatar
haha so i forgot my lunch one day...didn't think anyone would notice...
thanks
Unread 08-06-2011, 09:16 PM   #51 (permalink)
excellant source of fiber
