Go Back   Les Paul Forums > The Les Paul > The Custom Shop > Luthier's Corner
Like Tree12Likes
  • 3 Post By RAHAZ
  • 1 Post By RAHAZ
  • 1 Post By BCRGreg
  • 1 Post By Syrus
  • 3 Post By gator payne
  • 1 Post By gobig2000
  • 1 Post By djrussell
  • 1 Post By Davio
Unread 04-20-2011, 06:24 PM   #1 (permalink)
RAHAZ's Avatar
Curly Redwood build
Here is my solid Curly Redwood build. The wire channels will be routed like the old LP Custom models with a long drill bit and some good preparation. LOL The body was milled on a CNC from the 3D model I created. Last night I routed the perimeter to free it from the frame and did the round over on the back. Here are the photos to get caught up.
In the milling process I ran into some tearout just like Dan (DGNRepair) said I should expect. I have plenty of leftovers to pull a plug from to fix it. Should I cut it out with a forstner bit to create a clean edge then use a plug cutter to create the fill piece to match grain or is there any other options? I pondered doing a custom carve on the upper horn like my Carl Thompson inspired bass but that would mean not doing top binding.
Detail of the back on the lower horn.
Next to the Semi-hollow of the same design.
cooljuk, Reverend D and Syrus like this.
1932 Gibson L-00 "Stacy" (Needs Restoration)
2003 Epiphone Les Paul Custom Elite "Elly"
2008 Epiphone J-200 "Noel"
???? Tacoma Acoustic-Electric "Ruby"
Under Construction
2008 Hilleboe 5-String Bass "Amethyst"
2010 Hilleboe Mjöllnir
2010 Hilleboe Redwood Mjöllnir
RAHAZ is offline   Reply With Quote
The Following 2 Users Say Thank You to RAHAZ For This Useful Post:
Unread 04-20-2011, 07:26 PM   #2 (permalink)
cain61's Avatar
Re: Curly Redwood build
Dude, that's awesome. Gotta build me a jr. along those lines.
cain61 is offline   Reply With Quote
Unread 04-20-2011, 08:44 PM   #3 (permalink)
MLP Vendor
DGNRepair's Avatar
Sucks about the tearout. Just find the chip and glue it back in. What you might be able to do is use some of the wood from the cutoffs right from that area. Then you can make a patch. I have done that in the past, usually works out well.
Cool body shape.
DGN Custom Guitars - Handcrafted Guitars, Repair and Restoration
Like me on Facebook
DGNRepair is offline   Reply With Quote
Unread 04-20-2011, 10:03 PM   #4 (permalink)
Reverend D's Avatar
Thanks for posting this, it caught my eye the other day, the shape is cool and of course redwood its gonna look grand when finished out!
Regards,
Don
Reverend D is offline   Reply With Quote
Unread 04-21-2011, 03:24 PM   #5 (permalink)
RAHAZ's Avatar
Thanks for watching. I just wish I didn't have as demanding of a day job so I could work on these before the heat washes in.
Cool body shape.
Haha! The chip as probably sucked up when we were cleaning off the mill. I'll try my hand at it and post the results. Glad some other folks dig the shape. It's gone through a heap of changes to get to this.
Thanks! If you do post up a thread. I'm a serial gawker in this forum.
Under Construction
Unread 04-21-2011, 03:40 PM   #6 (permalink)
shotgunlew's Avatar
Heck ya another redwood guitar!
60% of the time...it works every time....
Gun Control = Using Both Hands!!
Everyone Please Pray for Sgt Jeffery Crones and the rest of the boys in iraq! Get some boys!
Chris "The Gunhand" Of the MLP Pirates Crew
1986 Les Paul Jr (Cherry red Singlecut )
1994 MIJ fender Telecaster 52 reissue
1984 JCM 800 1x12 50 watt combo
Behringer 4x12 cab (Bugera speakers)
shotgunlew is offline   Reply With Quote
Unread 04-21-2011, 07:31 PM   #7 (permalink)
Powerless
Barnaby's Avatar
I love redwood as a guitar wood. This has a great shape and looks like it will be stunning.
I'm also guessing that you can fix the tearout invisibly.
Originally Posted by Roman View Post
I cant die, I have too many guitars to do.
My first and second build threads
My third and fourth build threads
My fifth and sixth build threads
Barnaby is online now   Reply With Quote
Unread 04-21-2011, 08:01 PM   #8 (permalink)
RAHAZ's Avatar
Yours looks stunning Lew. Roman does amazing work. I can only hope mine comes out playable and decent sounding.
Thank you sir!
I'm going to try to make it invisible. Since this will be only my 3rd build I'm hoping I can pull it off.
Under Construction
Unread 04-23-2011, 09:08 AM   #9 (permalink)
cain61's Avatar
I seem to remember that Preeb on TDPRI shows how make invisible repairs on one of his thinline tele build threads over there. Thinline Tele build - Page 4 - Telecaster Guitar Forum
I hope this helps
Unread 06-10-2011, 02:43 PM   #10 (permalink)
RAHAZ's Avatar
Annnd we have some progress. Still need to work this top a little more. Redwood is strange to work with.
There are some growth areas that feel lower that the adjacent areas. Is this softer wood that had more removed from the same sanding pressure?
Wetted with a touch of naptha. As you can see it dries REALLY quick out here with 5% RH
155 likes this.
Under Construction
Unread 06-10-2011, 05:11 PM   #11 (permalink)
MLP Vendor
DGNRepair's Avatar
Looking good. Redwood with big figuring like yours is a bit of a challange to get completely flat. I usually start with a coarse grit paper that will cut both the softer and harder parts at about the same rate. Then as you work your way up to higher grits use a lot less pressure and you will find the results become very smooth. I have actually gotten away from using and orital too much on redwood. On maple I use an orbital all the way up to 220 but on Redwood I stop at 100 and continue by hand from there. Too much pressure is what causes the humps you feel over the figuring. Hope this helps.
Like me on Facebook
Unread 06-10-2011, 05:41 PM   #12 (permalink)
BCRGreg's Avatar
Use a sanding block with two layers of tshirt under the sandpaper. That will level the surface.
Aleksander likes this.
www.bcrmusic.com
https://www.facebook.com/pages/BCR-M...76454402425822
BCRGreg is offline   Reply With Quote
Unread 06-10-2011, 06:09 PM   #13 (permalink)
RAHAZ's Avatar
Thanks for the info. As I took it down from the steps to smooth I used 60 on the orbital. I've gone back and started working areas with 120 and 220 on an eraser. It seems to be working, albeit slowly.
Thanks Greg. I've got a stack of "rags" to put to use now.
Under Construction
Unread 12-06-2011, 03:15 PM   #14 (permalink)
Syrus's Avatar
Looks killer :] !
RAHAZ likes this.
Syrus is offline   Reply With Quote
Unread 12-07-2011, 04:24 PM   #15 (permalink)
mdr40z's Avatar
I really like it
mdr40z is offline   Reply With Quote
Unread 12-07-2011, 10:53 PM   #16 (permalink)
MLP Vendor
captcoolaid's Avatar
Very cool
http://mhd-pickups.com/
Luthier pricing available.
Or visit my youtube page
http://www.youtube.com/user/MHDPickups?feature=mhum#p/f
http://soundcloud.com/mhd-pickups/madhousedesigns-gameybluesmp3
DC DOES NOT EQUAL OUTPUT. Dc is a resistance value and that is all. It WILL NOT tell you what it will sound like, it WILL NOT make you sound like another player.
captcoolaid is offline   Reply With Quote
Unread 12-07-2011, 11:44 PM   #17 (permalink)
Bartlett Retrospec Member
jonny's Avatar
I really like that horn
Can't wait for more!
Well, I don't care if she IS in a cult, she sells damn good vegetable dip.
jonny is offline   Reply With Quote
Unread 12-08-2011, 12:55 PM   #18 (permalink)
RAHAZ's Avatar
Originally Posted by captcoolaid View Post
Very cool
Thanks guys. I've got a butcher block counter (honey-do) that bumped my builds but did give me an excuse to hunt down some more wood.
Under Construction
Unread 12-08-2011, 03:23 PM   #19 (permalink)
gator payne's Avatar
Slight off topic for this thread but kind of related.
I am mostly a fingerstyle acoustic player. because I am a finger style player I like my notes to be rich with overtone and personally I like a little dark melonic flavor to the tone. In acoustic tops no wood does a better job at providing rich complex overtones with a dark melonic feel than Redwood. I absolutly adore Redwood. Just don't look at it wrong or it will dent like a 1990 yugo in a hail storm
b-looser, RAHAZ and Eigen like this.
The true measure of a craftsman’s soul can only be measured when all he has learned is multiplied by all he has taught.
gator payne is offline   Reply With Quote
Unread 12-12-2011, 07:40 AM   #20 (permalink)
gobig2000's Avatar
i love the shap you have come up with!
RAHAZ likes this.
gobig2000 is offline   Reply With Quote
Unread 05-07-2012, 08:26 PM   #21 (permalink)
RAHAZ's Avatar
I am having trouble getting this horned fixed... I am hoping someone can point me in the right direction.
I took the rough chipped area and cut it with a handsaw to make a step. Cut a piece of the old blank that matches the area grain.
I wrapped the block with taped sandpaper and pulled it across the step keeping the path straight but there is always a gap...
See below for pictures.
Under Construction
Unread 05-07-2012, 08:35 PM   #22 (permalink)
Powerless
Barnaby's Avatar
You could try pressing the two pieces together and pull a thin strip of sandpaper between them (facing the new piece). After a few times, the gap should get considerably smaller. This method is often used in fitting necks.
Maybe someone has a better idea?
Unread 05-07-2012, 08:48 PM   #23 (permalink)
djrussell's Avatar
Is that bare feet I see!! IN A WORKSHOP! GAWWW! Sorry Couldnt help myself.
Looking great so far man, I think Barnaby has the right idea. I cant really think of anything else to do unless you were willing to cut another block to see if it works better.
gobig2000 likes this.
'13 Maiden DC Special [Build] | Maiden Telecaster [Build]
'12 AXL Badwater 1216 Jr | Aria STG-003 [Project] | Maiden Tele Rocket 88 [Build]
'11 Hagstrom Viking II | Maiden Junior [Build] | Gladiator GG-165 DC Junior
'09 Gibson Les Paul Junior [BJA Signature] | Hagstrom Swede
'08 Hagstrom D15CE
'07 Gibson Melody Maker | Fender Telecaster | Hagstrom F-300
'00 Fernandes FGZ-1C
'99 Fender Stratocaster
'95 Fernandes Stratocaster
djrussell is online now   Reply With Quote
Unread 05-07-2012, 09:31 PM   #24 (permalink)
You will either love or hate the dark tone the redwood will bring. Personally it is my favorite top for acoustics used for melonic finger style. It brings a warm throaty bass and lower mid tone kin too a shot of twenty year old bourbon. Goes down smooth and fills you torso warmth that seems to last long after the notes have passed.
IMO the only real issue with redwood is that it will dent if you look at cross eyed.
In regard to a hard time finding curly redwood top blanks like this one, pm me and I will put together a couple contacts for you. Plenty of it out there.
Unread 05-08-2012, 08:01 AM   #25 (permalink)
emoney's Avatar
Looks like you're on the right path, you just need to sand until you get the gap as close
as you can. From the pics, looks like it needs to be a little more "square" on the body,
where the piece came out. Otherwise, there's always the "slurry" fill for the gaps and
then "Darkburst" the outer edge. Love this body shape, btw.
emoney is offline   Reply With Quote
Unread 05-08-2012, 02:04 PM   #26 (permalink)
RAHAZ's Avatar
I think I will give that a try. Thanks!
I knew someone would call me out on that.
Agreed on the squareness and slurry fill. I'm going to try the method Barnaby mentioned. After seeing DGN's bursted redwood build I think it is a no-brainer. Glad you like the shape.
Under Construction
Unread 05-09-2012, 01:57 AM   #27 (permalink)
Davio's Avatar
Nice work. I'm glad to see your redwood project. I have a nice little pile for the next rounds of builds after I use the last of the pecan I'm on now. Thanks for posting !
RAHAZ likes this.
"How can you have any pudding if you don't eat your meat ?" - Pink Floyd
Davio is offline   Reply With Quote
Unread 07-23-2012, 09:10 PM   #28 (permalink)
Aleksander's Avatar
This is really great!!!. Keep rocking
Aleksander is offline   Reply With Quote
Unread 07-23-2012, 09:21 PM   #29 (permalink)
RAHAZ's Avatar
Thanks man. Been digging your build thread too. My wood related projects are shelved until the temps go down again.
Under Construction
