#782 (permalink) |
Re: MLP Bartlett Build
Hi Tom,
Have a question about correct binding thickness. Really regretting not ordering your Royalite bindings now, looks like yer using .090" for the neck as well as the body? I have some StewMac white 1/4" x .065" but I think I may need .090 for the body binding and maybe the neck. I can see that the extra thickness on the neck will make forming & rounding the fret end "nibs" a lot easier. If I final sand before cutting the body binding channel will .065 suffice for both, or should I get .090"/2mm then scrape & sand? Not liking the idea of using the thnner stuff now. (Spent half the evening checking threads etc, more confused now that when I started, as they all seem different, some use .065 etc etc). Thanks, John. |
#783 (permalink) | |
Bartlett Retrospec Member
![]() Join Date: Feb 2009
Neck binding = 1mm (+/-) |
#785 (permalink) |
MLP Sponsor
![]() Join Date: Jan 2008
You shouldn't need to do any sanding after pore filling. just wipe it off really well with burlap and you're good to go ahead with finish.
#786 (permalink) | |
Just ordered some 2.3mm for the body that should scrape down ok, and some 9mm high x 1.5mm for the neck. Close as I could get in UK, the extra height should help with nib forming but probably overkill. Gives me some extra width to work with. Bless yers. |
#787 (permalink) |
Tom, isnt it to oily for the lacquer without sanding?? It looks great with the cherry red filler, but i am not shue if the lacquer can goes directly on the oil based filler. Thanks
#789 (permalink) | |
I don't know if it has been asked before, but what are the dimensions of the vintage correct bushings ? The length I presume is 1", but what is the diameter ? Thanks.
"Nothing quite sounds like a Les Paul. ...not even another Les Paul !" Mrs. Blackdog Website:
#790 (permalink) |
Hi Tom,
I was just wondering if you have any plans to offer the 'full kits' again in the near future? I am a big fan of your maple tops, but a full kit would give me the comfort of knowing you have matched up the top and body for tone, as well as benefit from your first class build skills
#791 (permalink) |
Guys,
I copied all of the thread and stripped out the non-technical commentary (congratulations, repeated pictures, etc). I also took the ongoing technical information post replies that related to various stages of the build and inserted them into the appropriate sections of Tom's original posts. Unfortunately, the file is rather big (~13M), and cannot be attached to a post. If someone has a download site that I can put it onto, I will do so and allow any and all to have it. It really does clean up the reading of the entire thread! Ron Worley |
#792 (permalink) | |
![]() Join Date: Apr 2010
#793 (permalink) | |
Thanks, jim voos Furniture Builder, Les Paul enthusiast and pretty poor guitar player! |
#794 (permalink) |
![]() Join Date: Aug 2011
Another possible option would be to convert it into a PDF file and then reduce the file size. I use this quite a bit, but I am not sure if you would be able to get it small enough. PDF files do shrink quite nicely.
#795 (permalink) |
MLP Sponsor
Hey Guys. I spent this morning updating this whole thread. I went and took all the photos, uploaded them to a photo bucket account, and then changed all the links in each post to point at the new pictures. it took me many hours of prep, and a while to actually execute, but now the pictures should remain even after Apple drops all it's mobile me customers in a day or two.
now I just have to hope and pray that Photobucket doesn't decide to drop off the planet.
#796 (permalink) |
Bartlett RetroPAF Vendor
![]() Join Date: Mar 2009
That is an IMMENSE amount of work. Thank you!
![]() Video Demos and More Below www.re-wind.net ReWind Electric on Facebook My name is James and I build PAFs. |
#798 (permalink) |
OK, gents, I have uploaded it and you can access it at the following link:
https://dl.dropbox.com/u/89191122/ML...werLite%29.pdf Let me know if there are any issues and enjoy! Ron |
#800 (permalink) |
Hi Tom.
You said earlier, "The body is a direct tracing from a 59. Slightly different from the body shape on the plans I sell, but it is direct from an original 59." Could you possibly explain how and where the original differs in shape from your plans? Thanks |
#801 (permalink) | |
MLP Sponsor
The main differences are the cutaway, and the base of the guitar, where the plans have a slightly flatter tail end, and a sharper cutaway at the fretboard. |
#802 (permalink) | |
I'd imagine some sort of trends if the tools got worn out, etc. Another possibility, there are so many "58" and "59" out there nowadays, and it might be possible that some of those are actually replicas / conversions themselves? Kind of reminds me the story Bruce told where they counted more 59 for sale at a guitar show than originally sold by Gibson.
#803 (permalink) |
This doesn't deserve to be a sticky, this deserves to be a book titled: how to build a Les Paul!
My first build |
#804 (permalink) | |
MLP Sponsor
I would not consider a conversion, or a replica at all in taking measurements, and i would not take any measurements of a guitar i was not 100% sure about. so far i have not seen any replicas (in person) that would pass as a real burst under close inspection. |
#805 (permalink) | |
#806 (permalink) | |
MLP Sponsor
#807 (permalink) | |
I mean luthiers like you, Bharak, Gil and a few others have analyzed Bursts to every minute detail and every nut, bolt and screw. Save the pickups and the tuners pretty much everything is (still) available today. And even for the PUs there are people like Jon Gundry who go into the last detail, use the same machines and materials. The only difference would be the label on the baseplate... But having followed this thread and reading how close you replicated a Burst I really wondered what it is that makes experts like Ganzler and you saying they could still spot a difference. Is it a certain tooling that would be needed and nobody can get anymore? I know the plastics can be a problem (And easy to spot) but if somebody would retrofit 50s hardware and original PAFs to one of your Les Pauls, would Joe Ganzler or Lou Gatanas still know the difference? |
#808 (permalink) | |
MLP Sponsor
I think Joe has a whole bag of tricks he uses to authenticate a burst. |
#809 (permalink) | |
some things just are what they are ..... and some things are VERY close..... but they too, are just what they are. ok, that makes no sense ..... |
#810 (permalink) |
![]() Join Date: Jul 2010
...........could I be so bold as to say that IMHO there are only two Luthiers on the face of this planet that know what they are doing when it comes to building a Replica.One lives in lives in Canada & one lives in the UK (& that one is not Bharat). Bharat's real expertise is building fine stringed instruments...........Violins, Violas etc. My 2c FWIW.
