#602 (permalink) | |
Re: MLP Bartlett Build
Here is mine. Not done obviously. Just taking a SC sun bath at the moment. This is about 1/2 hour in. I just checked it after 2 hours and its lost Tons of the red already... Its the Moslers red. You wont be disappointed in Toms Kit you ordered or his customer service. 110% satisfied... Edit: here it is after a day in the sunshine.
#603 (permalink) |
![]() Join Date: Dec 2009
Looks great Tom...
http://w-machines.com/ Last edited by Taller76; 07-03-2011 at 05:11 PM. |
#606 (permalink) |
Great! Ill use it then with my build
By the Way... Those Dave Johnson Vintage Size Inlays... are they accurate enough or have they to be shaped manually (corners etc.) Im asking you, because you have the perfekt reference with that 55 Board. Thanks! |
#607 (permalink) | |
MLP Sponsor
![]() Join Date: Jan 2008
In This post: MLP Bartlett Build I make some comparisons between what is sold by several vendors (including myself) as 'vintage' and 'historic'. In short, the 'historic' cut inlays are almost dead on perfect. The 'vintage' ones are not, and I think many of the vendors are phasing them out as they just aren't that close. I've compared them to 55, 56, 57, and 59 Les Paul's first hand, and this is true of all of them. (they aren't perfect, but you will see they are VERY close). |
#610 (permalink) |
Oh my god... I Simply can't believe the attention to detail in all of these guitars. Beautiful, just amazing. Guelph's not that far away from Newmarket, definately would be worth the drive to see all of this in the real! Assuming you don't mind a 17 year old kid touching everything
It's amazing, I have a guitar book with several 59's in it and I would never be able to tell a difference, just amazing.I applaud you good sir!
#612 (permalink) | |
MLP Sponsor
The backs faded just like the tops, but the pores are always a bit darker because they are packed with the filler. |
#613 (permalink) | |
MLP Sponsor
#616 (permalink) |
I' m not Tom but I know the answer to your question. Just sand them a little and they'll lose the "vintage" color layer.
Why is there never enough time to do it right, but always enough time to do it over? |
#618 (permalink) |
Hi Tom,
I have been admiring your guitar builds. I have ordered some parts from you for my build. I need to order some fret wire. I noticed that you used Stew mac wire. Which of there many gauge wires do you use? Thanks, Adam. |
#620 (permalink) |
Hi,
Ivegot a problem to glue the binding you sell on my BRZ Rosewood Board. For the Bodybinding i used just pieces of Binding meltet into Pure Aceton as the Glue and it bonds very good. But for the Neck this method doesn't seem to work, the Rosewood seems to push of the Glue. I tried to sand the surface with 60 grit sandpaper but it didn't get better... What Method you recommend to glue the Binding especially on Rosewood? Do you know how Gibson glued their Binding in the 50`s ? Thank you very much! |
#621 (permalink) | |
MLP Sponsor
Gibson did not use royalite binding on the necks. They used celluloid binding and royalite only on the bodies. |
#622 (permalink) |
Thanks you make me think about removing the Body-Binding and glue it with a proper glue.
Do you know a Glue like Duco-Cement with is available in Germany? Thanks |
#623 (permalink) | |
rcshop24 - Duco Cement 1 oz Duco Cement 1 oz A2ZGLU-762.43 Why don't you buy in the US? DUCO CEMENT 1 OZ BRAND NEW | eBay Joe |
#625 (permalink) | |
#629 (permalink) |
Anyone use Ambroid, Sig-ment, or Testors Cement for Metal and Wood to attach binding? I think they are all pretty similar to Duco as they contain and can be thinned with acetone....I have seen them referred to in different contexts as acetone or (nitro)cellulose glues.
http://w-machines.com/ |
#630 (permalink) | |
<iframe width="425" height="349" src="http://www.youtube.com/embed/-1qvwes4aXI" frameborder="0" allowfullscreen></iframe> I use binding shavings dissolved in acetone and added to duco. That way it is white, gets good penetration into the wood and after drying stays put.
