MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Luthier's Corner
Like Tree3Likes
  • 3 Post By Udonitron
Unread 12-06-2010, 09:57 PM   #1 (permalink)
FU Flu U POS!
Udonitron's Avatar
Best Spray Gun For Applying Lacquer?
Hello guys
1st time posting in this area but I thought I would ask the pros
I am refinishing my MIJ Les Paul Jr. and was wondering what the best spray gun would be for applying the lacquer?
I went to Lee Valley the other day and grabbed this gun, a luthier who works there said it rocks and is very efficient and precise on spray radius and consistency.
Critter Air-Powered Spray Gun - Lee Valley Tools
Notice it has a unique siphon design and draws the liquid up (stored in a nice glass Mason jar...cool eh?) and then sprayed out.
Do you think this would be a sufficient choice or should I go for a HVLP gravity fed gun instead?
Thanks in advance for your input and advice on this dilemma
Fool, this is life. Get a hotdog if ya can't take the bun.
Flickr
Guitar Talk
TRUTH
Udonitron is offline   Reply With Quote
Advertisement
Unread 12-06-2010, 10:00 PM   #2 (permalink)
bfcg's Avatar
Re: Best Spray Gun For Applying Lacquer?
These are from a forum search.
Hvlp gun recommendations & airbrush
New Sprayer-Earlex 5000
HVLP System
.http://www.bfcguitars.com
bfcg is offline   Reply With Quote
Unread 12-06-2010, 10:05 PM   #3 (permalink)
FU Flu U POS!
Udonitron's Avatar
Ah yes, the search function lol.
I was searching for applying lacquer and lacquer spraying but I could not find anything in the 1st few pages...sorry.
The sprayer I posted above is unique however, anyone have any experience with that particular design?
Cheers
Flickr
Guitar Talk
TRUTH
Unread 12-06-2010, 10:07 PM   #4 (permalink)
bfcg's Avatar
I have experience with both and the links above are really comprehensive.
The syphon type created too much spittle for me and the HVLP is very bulky IMHO.
Unread 12-06-2010, 10:14 PM   #5 (permalink)
i just used the touch-up sprayer from harbor freight. works very well exelent controlTouch-Up Air Spray Gun
mrzippy is offline   Reply With Quote
Unread 12-06-2010, 10:31 PM   #6 (permalink)
FU Flu U POS!
Udonitron's Avatar
Ah interesting sprayer.
So you almost use it via a hip shot style then hey?
The trigger looks to be utilized via your palm or thumb?
There is also this nice smaller gun and reservoir HVLP gun
Flickr
Guitar Talk
TRUTH
Unread 12-06-2010, 10:46 PM   #7 (permalink)
FU Flu U POS!
Udonitron's Avatar
What do you use personally?
Flickr
Guitar Talk
TRUTH
Unread 12-07-2010, 07:16 AM   #8 (permalink)
bfcg's Avatar
I do not do production spraying so I use a badger model 400 and a compressor for shooting bodies and a smaller badger airbrush with a diaphram compressor.
Very compact and both are effecient for one offs and repairs.
Badger 400 gun - Shop sales, stores & prices at TheFind.com
Unread 12-07-2010, 09:36 AM   #9 (permalink)
FU Flu U POS!
Udonitron's Avatar
Ah OK...like the one mrzippy posted but better quality.
I ended up buying the same one mrzippy linked to but on fleabay instead last night.
We shall see how well it does.
I was tempted to buy an airbrush as well to test out.
Cheers for your input mate
Flickr
Guitar Talk
TRUTH
Unread 12-07-2010, 11:34 AM   #10 (permalink)
Freddy G's Avatar
For years I have used 2 suction feed devilbiss guns. The large one (JGA) is perfect for spraying full coats and for getting fast build. The smaller (EGA) gun, also known as a touchup or doorjamb gun, is still by far my favorite gun for bursts and for final coats. The pattern and fine atomization are perfect for bursts and colour graduation where you need maximum control. Also I like to shoot a final clear topcaot with this gun as opposed to the larger JGA. After wet sanding, I apply one final coat with the small gun and because it atomizes much finer than the JGA, the final coat is much smoother with better flow out and less orange peel. The bottom line is that after the final coat is sprayed I can use a much less aggressive grit of sandpaper to level the lacquer before polishing, saving time in the whole process.
This year I got a Fuji HVLP system (about $700) and I'm still wrastling with it
The spray pattern is not nearly as controllable as my devilbiss guns and the cap and needle set that it came with were just way to big for guitar work...you could spray the side of a barn with that huge pattern. So I got a smaller cap and needle set and even still it sprays heavier than my Devilbiss JGA. But I can use it for applying heavy coats for build.
Freddy G is offline   Reply With Quote
Unread 12-07-2010, 11:38 AM   #11 (permalink)
dougk's Avatar
Given your two choices, go with the gravity fed HVLP setup.
That being said, my personal favorite (of the half dozen or so I own) is my larger siphon feed Binks 2001. Freaking fantastic gun!
I use a couple small cheap touch up guns for spraying my bursts, they work great for that. I keep one dedicated for JUST goldtop since that powder is almost impossible to 100% clean out of the gun.
The touchup guns will spray tight enough to burst headstocks:
edit: I've used this set in the past (I still use the touch up gun for bursts and the larger for laying out sealer coats now) http://www.grizzly.com/products/2-Sp...tal-Cups/H7671
A dude with a beard, hammer and lots of flannel.
dougk is offline   Reply With Quote
Unread 12-07-2010, 01:00 PM   #12 (permalink)
FU Flu U POS!
Udonitron's Avatar
Nice...thanks guys for the input.
I suppose I will end up buying a few and figure out which is the best.
it will all be trial and error but hopefully the siphon fed one I got will do the trick on a 2-3 coat of lacquer for my Jr.
I do not want it thick and glossy but rather protect the finish but still sink into and show off the mahogany grain.
I have finished staining my Jr a nice water based ebony stain
Flickr
Guitar Talk
TRUTH
Unread 03-05-2013, 10:46 PM   #13 (permalink)
Originally Posted by Udonitron View Post
Hello guys
It depends on the compressure and sprayer and what you are spraying.I think you mentioned spraying wood. If you are spraying wood, you want to use higher then 7% automotive 10%+ , that said, I prefure the newer HVLP spray guns. HVLP allows 80% paint to cover object. Oldfashion sprayer 15% paint hits the object being painted(see why the push is on for the switch? Pollution control. GRACO, although pricy is completely adjustable. You
can draw like a pencil with no overspray, etc.. The best part is the quality of the paint job...especialy if you don't have a spray booth.and doing a fine prep job.Don't rush paint so it can be completely dried.
If you are paintingmetal make sure there is no moisture outside and it's 70degrees+. Understand, there's a perfect situation and there's not. you don't want to have to be sanding this off to redoe it.
steveracer16 is offline   Reply With Quote
Unread 03-05-2013, 11:18 PM   #14 (permalink)
FU Flu U POS!
Udonitron's Avatar
Ha this is from 2010 mate, all good now!
I have refinished a few guitars now and all good, cheers for the help and reply!
I did this one from scratch
Flickr
Guitar Talk
TRUTH
Unread 03-06-2013, 12:00 AM   #15 (permalink)
Wait'n for the bus
martin6string's Avatar
I started with an earlex 5000 and its good to get started with though, I now have an accu spray 23 turbine with the accu spray 10 gun. So much better atomization vs. the earlex. Personally, I would go with an Apollo system if you want the absolute best. Though, body shops often use the accu spray rigs day in and day out.
-Matt
Premium guitar electronics, aged parts and vintage inspired pickups
www.MartinSixStringCustoms.com / www.MSSCGuitar.com
Sign up for exclusive deals and coupons / Contact Us
martin6string is offline   Reply With Quote
Unread 03-06-2013, 12:33 PM   #16 (permalink)
BleedingGums's Avatar
This is fantastic! Almost has an Escher-like vibe as it looks like the grain is melting.
BleedingGums is offline   Reply With Quote
Unread 03-06-2013, 12:42 PM   #17 (permalink)
FU Flu U POS!
Udonitron's Avatar
Yeah tried to make it like that, cheers man!
Over-spray and then wet sand it to give it a bit of a gradient.
Flickr
Guitar Talk
TRUTH
Unread 03-06-2013, 01:41 PM   #18 (permalink)
dickjonesify's Avatar
What gun did you end up with?
dickjonesify is offline   Reply With Quote
