#1 (permalink) |
Measuring pick up height question
When I measure pick up height using the standard factory settings do i go 1/16th inch and 3/32 inch from the screws on the pickups or from the plate?
I recently played around with R8 pickups and i am fining that where they originally were was best. It just doesn't seem right what ever I do to them. Do most people actually play around with their heights? thank you |
#2 (permalink) |
Re: Measuring pick up height question
I've got my neck dialed in pretty well but my bridge still has to much bite so I am constantly messing with it, seems like no matter where it's set I have to keep the tone around 8 or so. Have you tried adjusting the polepeices? That made a huge difference on my neck pup.
2007 Gibson Les Paul R8 "Jamie Leigh" OTPG'd 2001 Gibson Les Paul R6 "Aimi" '53 Soapbars 2007 PRS Hollowbody Spruce " Clara" Skatterbrane'd 2001 Fender AmStd Telecaster "Sharon" Lollar'd 1960's Gibson J50 "Imogene" Phaez 15 Watt 6v6 "Rising Sun" all pots, caps, and harnesses by Jonesy@ tonemojo
#5 (permalink) |
String depressed at the last fret (closest to the PUs), Measure from the top of the pole screw to the bottom of the string.
I do play with them and always seem to go slightly lower (larger distance) than factory spec for optimum balance and tone (to my ears). I find this true for humbuckers and single coils. They just sound "sweeter" to me that way although the output is reduced somewhat. |
#6 (permalink) |
![]() Join Date: Oct 2007
What everybody else said, just tinker around with them until you get
what you looking for. One of my favorites is the 500T in my Classic. I would have thought the distance would be greater on that one opposed to like a 57. But actually, it's closer (for my preference?) go figure |
#8 (permalink) | |
![]() Join Date: Jul 2007
that's not really a bad thing IMO. Mine's roughly the same, I usually keep it around 7 or 8. But there are times I feel the band is walking all over my frequencies, and that high treble leaves me a bit of wiggle room to project a solo.
------------ Don Primary Tone: what the body and neck does not have cannot come out as tone - Iwanade, BOTB Quote:
#9 (permalink) |
Yeah and I play with fingers so I can lighten my attack and pick nearer the neck and darken the tone a bit, that leaves the brightness in the bag for when the need arrises.
