#1 (permalink) |
Help: E7#9 (Hendrix chord) sounds like mud
On my 335, if I play the Hendrix chord it sounds thick and chunky, both clean with my volume rolled down and full up with overdrive. On my Les Paul, it sounds kinda crappy, no note definition or blending. Worse, when I roll down the volume, I lose all the highs and it sounds worse. I tried lowering the pickups and it helped for a lot of things, but I'm still not satisfied. Is it the pickups, the pots, anything else? Thanks!
#2 (permalink) |
![]() Join Date: Jul 2007
Re: Help: E7#9 (Hendrix chord) sounds like mud
try 50s wiring if you're rolling off the volume.
500K pots will help (if you don't already have them), I like RS Superpots for volume too also, are you changing the amp settings when you switch guitars? quite a difference between a 335 and an LP |
#3 (permalink) |
The RS kit etc and things like changing to oil/paper caps and so on will increase the sweetness of your LP tons.
I wouldn't advise using the same amp settings for a semi like the 335 and an LP. They are 2 seperate beasts and should be treated as such.
#4 (permalink) |
MLP Chaplain
![]() Join Date: Jun 2007
Dont play that chord then brother.
JW http://www.myspace.com/jwblues54 Robert Johnson went to the crossroads to sell his soul to the Devil, what have you done with yours? |
#5 (permalink) |
![]() Join Date: Aug 2007
Vote 2 for paper in oil caps, and vintage wiring
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk |
#6 (permalink) |
![]() Join Date: Nov 2007
I think Page used that chord on the lemon song? Might give you a tone reference, he'd not had his Les Paul long back then.
More importantly - what Les Paul, what pickups, what pots, what caps have you already got? Even more importantly, have you checked the intonation lately. Having G# and G in the same chord is a real test for perfect intonation. Liam |
#7 (permalink) |
I've got two Les Pauls now, an R7 and an R8. They both came with the pickups extremely close to the string, so much so that there was magnetic pull on some strings. I was having intonation problems and moving them down solved that. I can't figure out why Gibson set them so close, other than maybe they are set up for two-note power chords and single lines.
Still, anything more than a major or minor chord is gunky. Is the RS prewired kit easy to install? Does that come with '50s wiring? I can solder, but not much more. If that doesn't solve it, I may start with some more even sounding pickups. |
#8 (permalink) |
Sounds like you might need to try different pickups. I run quite big pickup clearances compared to most.
What caps are inside the "faux" bumble bees? Are they not PIO. Tone caps don't make a huge difference unless you've got the tone control rolled off. Nor do the pots for that matter. Liam |
#9 (permalink) |
Maybe the low E string is causing the muddiness? There could be some string buzzing from that string since it's not being fretted. Try the chord without that string to isolate the problem. Just a thought.
#10 (permalink) | |
Try to play it on SG, Hendrix was also SG player.
#12 (permalink) |
Sewell Wampus Cat Classic with 2x10s, Rajin' Cajuns. Basically, it is a tweed style amplifier. I'm think that because of the scooped mids aspect of a semi-hollow, the notes are blending better. It's not the low E string.
A big issue for me is that I'm not getting a good sound when I turn the Les Paul's volume down. I think I'm going to install one of the RS kits to see if that works. |
| Jimi hendrix sex tape??!? | specter1001 | The Cellar | 30 | 07-31-2009 04:52 PM |
| Trying NEW sounds of of my LP | gofguitarKP | Epiphone Les Pauls | 17 | 03-18-2008 04:01 PM |
| New Video: Blues You Can Use: #04 Playing Over Chord Changes | dkirwan | Guitar Lessons | 24 | 01-27-2008 06:15 PM |
| Chord Inversions | MIDNIGHT | Guitar Lessons | 34 | 12-22-2007 04:56 PM |
| Hendrix Digitech pedal | Volusia | Pedals | 8 | 12-06-2007 10:22 PM |
