#1 (permalink) |
Basically, if I have a RI guitar, other than volume...do changing pots and capactiors alter tone? And if so, by changing them, in what way would the tone be altered. Is it accurate that 59 RI's of today and a true 59 have the same taper, same pots and same cap values? Thus giving about the same tone?
Also, if one were to take RI pots and caps out and put in real authentic vintage pots and caps, is there any real benefit to that? Meaning any tonal improvements or for all purposes will it likely be the same. Since we are not talking about old wood or anything, I was wondering if an aged cap or pot or whatever would make any sort of difference. Let me know what you think to all three paragraphs. Thx
"Forget musical talent, experience, or skill. All you need is an opinion, and a computer." - GFM on TGP My massive, ever evolving and revolving collection. http://s553.photobucket.com/albums/jj392/jdwright6/ |
#2 (permalink) |
![]() Join Date: Jul 2007
Re: What effect do pots and caps have on tone?
IMO better pots will give you a better sweep, maybe open the tone up a touch.
If you want vintage tone, IMO, put some PIO caps in there. Tons of threads on caps, hit the search switch up top. |
#3 (permalink) |
MVP Clown
![]() Join Date: Sep 2007
Well ... Pots make your volume go up and down
and if you don't connect the caps then you won't get any sound !!! ![]()
" Over the Pond Guy " PAF Pickups & M69 Rings ... @ OverthePondGuy@aol.com |
#4 (permalink) |
Pots & caps only work if you are a knob-twiddler. If you always keep everything on 10 it defeats the purpose.
![]() ShamRockers-1Up/Press Play On Tape-The Eric Clapton Social Group-The VOX club |
#6 (permalink) | |
MVP Clown
#7 (permalink) |
NOT SO! The higher the pot value the brighter, clearer, and purer sounding the string tone. The higher value allows higher frequencies to pass through. By doing this the string tone is totally different. A 300K pot does not sound the same as a 500K pot unless the 500K is turned down. When my 300K pots in my 335 were turned down everything got muddy, didn't have any choice but to keep everything on 10. With the 500K and 50's wiring it stays clear on any number and the treble does not bleed off like stock factory wiring unless I turn the tone pots down. The guitar now does not even ressemble the guitar I originaly bought. Had to make changes to PUP height and Poles, amp settings and even had to change the pick I had been using from day one it changed the way the guitar sounded so much. Using that same pick that sounded so good everyday now sounds like trash.
#9 (permalink) | |
Point is, you can try anything. Things like pots are relatively easy to swap out and undo if you don't like it. Just be ready for the possibility that there may be undesireable side effects that go along with it. I'm not trying to step on anyone's toes here, but rather trying to add to the discussion. Fred |
| Tags |
| 1959, capacitors, pots |
| Does Color effect the tone? | shal1234 | Gibson Les Pauls | 73 | 09-07-2009 10:57 AM |
| Heavier Strings Effect A Lot Of Tone | rios39 | Tonefreaks | 17 | 03-12-2009 05:22 PM |
| Tone Effect of spinning Pups? | nitrous12 | Tonefreaks | 2 | 09-01-2008 11:12 AM |
| The effect of strings on tone | single cut 54 | Tonefreaks | 38 | 04-15-2008 11:15 AM |
| Caps wired between tone center terminal and tone pot body | whywhyzed | Tonefreaks | 8 | 02-04-2008 04:44 AM |
