#1 (permalink) |
Les Paul tone question
New guy here ready to pull the trigger on a vos r8. Really having a tough time deciding between two lp's. Played five and two of them stood out as the most toneful, best sustain, etc. Not knowing too much about the benchmark for a "good" Les Paul I'd thought I'd ask for a bit of advice. The two that I've narrowed it down to are a washed cherry burst and a beautiful iced tea burst. The cherry is 9lbs and is very loud and bright acoustically and has a good biting tone without being harsh. Plugged in it has round lows and bright highs. The iced tea is 9.5lbs and is warmer acoustically with a bit more midrange. Plugged in it is a bit thicker, smoother, and darker sounding than the cherry. The cherry plays a bit better but the iced tea is more visually appealling to me. Any thoughts?
#3 (permalink) |
![]() Join Date: Jul 2007
Re: Les Paul tone question
very close, but, if it was me, I'd opt for the cherry. 1/2 lb lighter, and I like the bright side of it acoustically, you can always find the mids with those pickups.
#4 (permalink) |
A brighter guitar can be easier to work, especially if you are a lead player and depending on the amp you're playing it with... I prefer a dark sounding Les Paul personally, but I play a style of music that darker guitars *tonewise* work well with, and I push the mids and presence on all of my amps.
Otherwise it only comes down to playability and feel and color preference. If they have the same neck profile, a good setup will make the either play like a dream. I also have a soft spot for Ice Tea because its almost a real faded tobacco sunburst *which is my favorite finish on any instrument*. Cherry is the classic Les Paul color though. |
#5 (permalink) |
![]() Join Date: Oct 2007
You like the sound and looks of the ''iced tea '' the only down side is it's
1/2LB heavier .I'd go for the ''iced tea'' . If it sounds good now ,how good is it gonna sound with a set of great pickups in it?Lots of vintage Lesters are in the 9 to 9 1/2 LB bracket.Looks and sound every time for me! |
#7 (permalink) |
![]() Join Date: Nov 2007
Don't know if I'm alone, but unlike strats and teles, I find it really hard to know what a Les Paul is really going to be like until I'm in the rehearsal room with the amp cranked up. Playing on my own I like them dark, as soon as there's the rest of a band there I really like crunch and bite.
Then once you add looks into the equation like that, toss a coin. I'll bet they'll both be great. (I'd probably go with the iced tea and hope a pickup change got the bite back myself). And you'll never have to compare them again... |
#8 (permalink) |
All great points, thanks! I think the washed cherry probably sounds a little better between the two but I'm more drawn to the iced tea which also has a slight hint of flame. They are both winners and once I walk out of the shop it doesn't matter anyway. I tend to use highs on my amp sparingly and push the mids a bit so I think either will sound fine. I have no idea how the wolfetones will sound. My only experience is with duncans. I guess to sum things up, the cherry is more open sounding while the ice tea sounds syrupy. The good thing is that I found two that sound great with the cherry edging the iced tea out tonally with a good amount of ring. I think either will sound much bigger than my prs cu22.
#10 (permalink) |
I'd suggest having a quick listen to Bloomfield or Page. That little extra high end can cut the mix better than a ton of mids can.
But either way, you found 2 great guitars. |
#11 (permalink) |
You should go with the one that feels and sounds the best to you. Whichever way you go, you should change the pots and wiring before the p/u's because those changes might make the burstbuckers sound better... If they don't, you can always swap out the p/u's later...Good luck and enjoy your quest, R8's are great guitars..
#13 (permalink) |
'Syrupy' is more like what real 50's Les Pauls sound like.. at least the ones I've played. The Iced Tea sounds pretty dang good if you ask me. Highs can cut over a band a little better than just mids alone, but do you even plan on gigging the guitar? Also what style of music are you into? Slash is an all mids kind of player, and so is Kerry King and they don't have problems being heard over their bands.
#14 (permalink) |
![]() Join Date: Aug 2007
I'd grab what ever one really really speaks to you, Color ect is secondary if that, Playability and tone, Thats what I would be after, and I'd have to hear it cranked also thru a rig like mine
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk |
#15 (permalink) |
Definitely will be gigging with the R8. Both guitars will cut in my band. Playing everything from classic rock, 80's rock, modern rock. My main guitar right now is a prs cu22 which is very midrange heavy. Cuts through just fine.
#16 (permalink) |
I think it basically will come down to color choice and weight then... They are both killer guitars by the sounds of it. What I would do is ask some random hot girls which one they think is 'sexier' and let that help sway me. Pleasin' the ladies is paramount.
#17 (permalink) | |
Master Luthier V.I.P.
![]() Join Date: Dec 2007
Go play them both blindfolded, let your ears and hands decide.
Factories build guitars for profit, Luthiers build them for players ![]() |
#18 (permalink) |
I rest my case behind the old Luthier Roman
#19 (permalink) |
Going this afternoon to make my final decision and end the anxiety. I'm ready to give my PRS a rest for a while. Has anyone tried the wolfetone marshallheads? Wondering how that might change the tone of the guitar.
#20 (permalink) |
![]() Join Date: Mar 2007
Most after market pickups will change the sound of your guitar as will better caps. Those caps in stock Gibson's could be better, as can their pickups. Wolfe makes some great pickups BTW.
Remember this simple truth: Satan will always seek to drive you away from the cross, but the Holy Spirit will always draw you back to the cross. Trust in Christ. |
#22 (permalink) |
Went to make my decision and the cherry burst had been sold. Thought that made my decision easier but there was a tobacco that sounded great too. One more trip and I should make a purchase. I'm sure they are getting sick of me. I did notice that the iced tea had a top that was obviously not bookmatched. One side was a bit darker than the other. Is that normal? I would think that a bookmatched top would produce a more consistant tone.
#25 (permalink) |
Rather than start a new thread specifically for my question, this thread title fits the bill near enough.
One of the signs of a "good" LP is the way it sounds strummed acoustically, with vibration of the headstock and body considered important signs. Yet many guitars incorporate inertia blocks to prevent transference of the string vibration to the body (which would in effect dampen the vibration). The pickups are "reading" only the energy of the string vibrating between nut and bridge, so any transference of energy to neck and body is "lost" energy. So why, if the ideal would seem to be a design that kept the maximum vibration energy in the strings, is it that a vibrating headstock and body is a good thing for an LP? I'm puzzled and hoping someone can enlighten me.... |
#27 (permalink) | |
#28 (permalink) |
i go for the acoustic tone. you can swap everything on the guitar but you're stuck with the wood. if it resonates well and just 'sings', i don't really care how heavy it is, what the top looks like (unless it's totally jacked) or how the electronics sound. the other thing to look at is the fretboard - you probably won't be replacing that. get the one that feels the best.
you won't be disappointed in the wolfetone marshallheads. they're great sounding pickups and really are better than the burstbuckers. |
#29 (permalink) | |
"Now Known as The Post-O-Matic 5000" ![]() ZOMG! Its Gemma!!
| basic tone question | ksu guitarist | Tonefreaks | 6 | 05-29-2008 04:23 PM |
| tone question. | ksu guitarist | Epiphone Les Pauls | 4 | 05-29-2008 12:10 AM |
| lp tone, thought or question | st.bede | Tonefreaks | 8 | 04-18-2008 02:17 PM |
| Les Paul Push-Tone | BobbyK | Gibson Les Pauls | 0 | 02-15-2008 04:39 AM |
| classic les paul tone | Funky Bob | Epiphone Les Pauls | 6 | 11-19-2007 12:19 PM |
