#1 (permalink) |
![]() Join Date: Sep 2007
is the neck/binding damaged on this one? or is this normal?
![]() My guitars: http://www.historiclespauls.com/gear...r=JimmyAce2006 My Metacafe channel: http://www.metacafe.com/channels/jimmyace2006/ My Youtube channel: http://www.youtube.com/user/JohnnyAce07 |
#4 (permalink) |
Re: is the neck/binding damaged on this one? or is this normal?
2008 model.
#5 (permalink) |
separation of what? paint? binding from the wood?
#6 (permalink) |
Where the nitro/lacquer meets the binding, I don't know exactly how to explain.
Two different materials expanding and contracting at different rates with heat and humidity changes. Causing a split. My best educated guess. |
#7 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Apr 2011
On my i phone , it looks as though it's a lacquer crack , I can't see
the usual cracks along the frets though . One would think the usual cracks would also be present if it's a lacquer crack . .... Note : the crack / check ..... ? ..... Seems approx. 1 mm away from the binding .
"over-under-sideways-down, sooo much more than square 'n round"
#10 (permalink) |
Yeah, John, I've seen those before. Unless you can feel the board separation from the neck then it's a SER!OUS problem, otherwise it would blend just right on the vos mojo on that guitar..
If you can't keep the guitar in tune return it... |
#11 (permalink) |
it seems like most people think it is not a crack in the wood. is that right? and it is more like checking?
#12 (permalink) |
![]() Join Date: Mar 2007
I just emailed this to John, before realizing that there was a thread on it too:
"Regarding that neck/binding, I think it’s somewhat normal. I think what you’re probably seeing there is the actual line where the binding meets up with the neck. I’m guessing when they masked the fingerboard and binding to paint the guitar black, they left a little of the lower portion of the binding unmasked, so that the black paint would cover up the joint between the binding and neck. And over time, with the different rates of expansion and contraction between the binding and neck, a little crack in the lacquer has developed...not unlike lacquer checking. Of course, if it’s a guitar you’re considering buying, you’d want to verify that it is, in fact, just the lacquer, and not an actual separation between the fingerboard and neck." Frank
Check out some of my personal gear at: Historic Les Paul Database ![]() http://histrungguitars.com/ Please visit my new HiStrung Guitars Facebook page: http://www.facebook.com/pages/Histru...38001253029620 |
#13 (permalink) |
It looks like simple finish cracking. I've seen stuff like that before, but I'm surprised it's not on the seam.
eta: Just saw the above post, makes good sense. |
#14 (permalink) |
.... John , I would like to know if it's verified , either / or ...
It's not easy seein this from the pic bro . And Frank ....
#15 (permalink) |
The guitar is half way across the country; so it would be hard to get it checked out.
#16 (permalink) |
My '83 LP Custom has that all the way around the headstock and in places on the neck. In person, it sure looks like fracture in the finish from the wood expanding and contracting from changes in heat or humidity.
#17 (permalink) |
![]() Join Date: Nov 2008
I've owned a B7 and an OBG black custom. Both had that and played flawlessly. I wouldn't sweat it myself.
Guitars: Gibson | Fender Amplifiers: Hiwatt | Orange Pick-ups: WB | OTPG | Slider | EMG | Fender CS |
#18 (permalink) |
Die Hard LP Man
![]() Join Date: Sep 2009
^^ Except that indicates someone didn't care about keeping the humidity levels even close to proper for their guitar!
If you can keep your head while all about you lose theirs,.... you obviously haven't grasped the situation!! GEAR 2010 CS 50th Aniversary R0 V2 from Guitar Works 2012 CS R8 Iced Tea from Eddie's Guitars 2010 CS R7 Gold Top from Eddies's Guitars POD HD500 VOX Valvetronix VT30 |
#20 (permalink) |
I noticed a small thing like this in the cutaway of my R8 as well. It's only about a half inch long though. I'll post a pic if I can get a decent one.....
2010 Gibson Les Paul R8 in "Ebony" ![]() Fender Deluxe Reverb Reissue (Wampler Triple Wreck for dirt) with Mesa Rectifier Horizontal 2x12 Cab ![]() Monster Cables |
#21 (permalink) |
It's a bit blurry but it gives you an idea.....
#22 (permalink) |
No chipped paint and no wood exposed but in the right lighting I think I see a hairline crack in the finish along the seam.
#23 (permalink) | |
![]() Join Date: Jan 2009
Thanks, Nathan |
#24 (permalink) |
thanks for the comments everyone. if you were looking for buy a guitar, and if this issue was not a deal killer, would you adjust your offer downwards? if so, how much?
#25 (permalink) |
![]() Join Date: Jan 2008
Indeed it did/does (if you're referring to mine). Has no negative impact on the playability or tone whatsoever. Just adds to the mojo. She's structurally sound as a rock. I adore this guitar!
Chicks don't care how long your tenon is, just that you know how to use it... Eddie 2003 Faded DC Special 2003 B7 Custom Black Beauty 2004 R7 2006 Explorer ![]() Join the Black Beauty Rockers! http://www.mylespaul.com/forums/grou...y-rockers.html |
#26 (permalink) |
The guitar in question is a Jimmy Page Black Beauty LP Custom from 2008. Here is a shot of the neck of a different guitar, also a Jimmy Page Black Beauty LP Custom from 2008. It has the same "crack" running the length of the neck. I think it is natural as mentioned above by several people. Frank nailed it.
#27 (permalink) |
![]() Join Date: Feb 2008
I am surprised you are considering buying this but passed on another only because it was missing a piece of plastic. For that reason, pass and wait for the right one to come along.
Tim really wants that Bartlett Retrospec. Fingers crossed!! |
#29 (permalink) |
The question is: Did JP's BB have the same issue?
One will never know...
#30 (permalink) |
My newer custom has that same finish check - and it plays great. That JPP custom does look really cool.
www.lastbandstandingnj.com 2010 MCI 59 Amber 1958 LP Junior 1959 LP Junior 1989 LP Custom Lite w Floyd 2006 LP CR7 Goldtop 2003 LP Custom - Silverburst 2003 ES335 Flamed Amber 2005 PRS Cust 22 - Grey/Black 2011 Danocaster T Whiteguard 2004 Rosser/SRV Strat Bogner Shiva AXE FXII w/ MFC101 |
