#3 (permalink) |
Re: Kluson tuners interchangeable?
JD, it looks like 2 different brands of tuners in the drawings, so no, I wouldn't think they're interchangeable. If, however, you changed between the stock tuners and the waffle backs, they should be interchangeable. my .02 YMMV
Ric
84 Ebony Studio 12 White Blonde MJT Tele 12 Surf Green MJT Tele Line6 SpiderValve Mk II "shattered dreams, empty streets, runnin' from the law man"
#4 (permalink) |
Well, the first example if from Stewmac's web site, and the second from Schaller's.
I want to replace the tuners on my R8 with the Kluson all-metal waffleback ones, but just wanted to know whether or not they'd fit. I don't think they will, actually. Oh well... |
#5 (permalink) | |
why would you wanna put those ugly waffleback ones on?! ![]() your guitar would look like a chinese guitar from wallmart then... |
#6 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Nov 2010
They Probably won't fit. Besides the screw holes lining up with the one on the headstock you also hace to consider where the tunerpost is in relation to the screw holes. If the post on the wafflebacks is a different position on the tuner compared to the stock tuner, when you mount the waffle back the screw holes on the headstock will not line up with the ones on the tuner.
============ Anything worth doing is worth doing half-assed. |
#9 (permalink) |
Was thinking of putting them on my R8. I don't really like the regular Kluson tuners very much. Wish it had Grovers on it, instead, really.
#10 (permalink) | |
They are just great! Fit and work perfectly, no extra holes to be drilled. Maybe they are available for the R series as well? I think the hole on that is some 6 mm of diameter http://gitarren-mechaniken.de/hp1256...c9e681d8XY37bc |
#11 (permalink) |
Maybe it's time someone makes an historic announcement about the imminent release of a new breed of tuners that will be the best of the best, the true legend, with holes that will fit the holes left by all variants of kluson and grover tuners...
