Go Back   Les Paul Forums > The Les Paul > Historics & Reissues
Like Tree40Likes
Unread 01-10-2012, 12:37 PM   #1 (permalink)
Bartlett Retrospec Member
reedy's Avatar
Nitro on Historics and Reissues
A question for those that might know...
Is the nitro finished used on the Historics/Reissues the same water-based nitro with plasticizers used on the regular production models or does the custom shop use the more solvent-based nitro that was used on vintage guitars?
Thanks.
reedy is offline   Reply With Quote
Unread 01-10-2012, 12:55 PM   #2 (permalink)
Cpt_Gonzo's Avatar
Re: Nitro on Historics and Reissues
If it's still sticky, it's the same crap they've been using on the standard production models, and that's no real nitro.
Real nitro isn't as sticky.
Cpt_Gonzo is offline   Reply With Quote
Unread 01-13-2012, 12:27 AM   #3 (permalink)
My two R8s are the least sticky Gibsons I've played in years...but still a little bit...
jonas335 is offline   Reply With Quote
Unread 01-13-2012, 02:32 AM   #4 (permalink)
Is there a way to avoid the stickiness behind the neck? Ive tried quite a few LPs and they vary from really sticky to tolerable but after a few minutes gunk still build up. Is there a non-invasive remedy to this?
nimrod777 is offline   Reply With Quote
Unread 01-13-2012, 03:52 AM   #5 (permalink)
1981 LPC's Avatar
'Real nitro'? As opposed to fake nitro? All nitro finishes used in mass produced guitars have plasticizers in them, some have more and some have less. There's nothing real or fake about it.
1981 LPC is offline   Reply With Quote
Unread 01-13-2012, 04:38 AM   #6 (permalink)
guitarnut_germany's Avatar
have a look at that:
gibson
click on the 10th picture on the right, you see a gibson stripped from its "nitro", uuuuh, nitro, right? that pile of plastic shit there?
WHY on earth do they put this shit on the guitars?! I'd rather get an *unfinished* guitar than one packed with plastic. We don't really have an option, do we?
I remember my first guitar teacher (maybe 20 years ago), good guitars were scarce back then, and he had a funny EVH type of axe, with floyd, basically a handmade one, which was not finished at all, it looked like shit... but maaan, that was TONEMONSTER, it had quality woods and hardware... and it was a **lefty** (big problem for my teacher back then )
guitarnut_germany is offline   Reply With Quote
Unread 01-13-2012, 05:26 AM   #7 (permalink)
RAG7890's Avatar
Interesting point CG. My new '58 Replica's Nitro is as hard as glass (bugger all plasticizer) & not a hint of stickiness anywhere.
RAG7890 is offline   Reply With Quote
Unread 01-13-2012, 05:42 AM   #8 (permalink)
slapshot's Avatar
Location: Fishing.it's like yoga but I get to kill something
Send a message via ICQ to slapshot
rub it with 0000 steel wool then polish it with some good old school car polish
slapshot is offline   Reply With Quote
Unread 01-13-2012, 06:25 AM   #9 (permalink)
I think they have been changing it over the years, my two new 2011 R5's have baby butt smoth lacquer, not a hint of stickiness whatsoever.
nicolasrivera is offline   Reply With Quote
Unread 01-13-2012, 06:30 AM   #10 (permalink)
gibson
I have a lot of tone monsters, some finished in poly, some in nitro and some unfinished. Really, the finish material will only affect the tone in relation to how thick it is applied, a thin coat won't do much for the tone.
Just don't buy guitars with thick poly finishes.
I'm sure that if you stripe a Gibson from its finsh you won't be able to tell the difference tone wise.
harrie 0492 and AxeBuilder like this.
Unread 01-13-2012, 07:13 AM   #11 (permalink)
db3266's Avatar
I keep wiping my R8 neck down with a scotch pad, I do it very gently to just remove the grime that accumulates on the sticky neck. I'm hoping that through time (the next few months and hopefully a warm summer in the UK), it wll eventually stop being sticky and stop accumulating a suprising amount of dirt!
"The guitar used to speak for me. But I can't let it do that for me anymore. I can't let it break my heart again". - Peter Green
db3266 is online now   Reply With Quote
Unread 01-13-2012, 07:22 AM   #12 (permalink)
mfolet's Avatar
VOS models have 100% nitro with no added plasticizers just like origanal bursts
mfolet is offline   Reply With Quote
Unread 01-13-2012, 08:10 AM   #13 (permalink)
as far as I know, officially all gibsons have 100% nitro, if that really is so, and what is meant by "100% nitro" is another issue
Unread 01-13-2012, 09:16 AM   #14 (permalink)
mfolet's Avatar
In this case 100% nitro means no plasticizers or additives
Unread 01-13-2012, 09:36 AM   #15 (permalink)
I wonder WHY i s then Dave Johnson (and many others) refinishing historic guitars... (and how does the "nitro" look like, that comes off those historics...see pic in my post above)
just for fun?!
Unread 01-13-2012, 09:51 AM   #16 (permalink)
winexprt's Avatar
Since it hasn't been addressed, what would be the point/benefit of adding "plasticizers" to the finish??
Originally Posted by singlecut View Post
"this guitar will vibrate your nuts off"
winexprt is online now   Reply With Quote
Unread 01-13-2012, 10:02 AM   #17 (permalink)
I would guess it's easier to apply... that's just a guess though. I think a nitro finish takes more time to apply and is a long iterative process...
There are many people who wouldn't be happy with a nitro finish as well (very sensitive, fades, cracks, chips and so on...) But man, on historics... I don't understand either.
Unread 01-13-2012, 10:06 AM   #18 (permalink)
cousingrandpa's Avatar
My R8's neck after 2 years of hard play is no longer sticky, soft & doesn't build up gunk any more, it took a few months for this. I'm just starting with my R9 so I figure it will take a few months for it to catch up.
2007 Gibson R9 Les Paul VOS BKP Mule's
2008 Gibson R8 Les Paul VOS SD Pearly Gates
1997 Orville Les Paul Standard
1964 Gibson EBO
Fender Franken strat #1 1st generation Jeff Beck neck
Fender Franken strat #2 Sherwood Green
2011 Carparelli ARCO F1
1985 Robin Artisan (SG/LP hybrid)
90's Raven LP
Ibanez 6 string bass
Seagull S6+
Harmony archtop
I wrote this song for my lady,
http://soundcloud.com/cousingrandpa/misty-blue-eyes
cousingrandpa is offline   Reply With Quote
Unread 01-13-2012, 10:15 AM   #19 (permalink)
Die Hard LP Man
KenG's Avatar
just for fun?!
People get makerovers because they want aged LPs and what they think is closer to the originals (whatever that means considering they were all over the place as well). Fading,checking all included. The people performing the work do it because they make a lot of money.
The stuff comes off in one piece because they heat it (which can be dangerous if you don't know what you're doing) and really only indicates that the coats were well bonded to one another.
If you don't like Nitro buy something else. Personally I have three newer LPs and absolutely no issues.
A comment to those who always find the necks sticky,.. it's more than likely your own sweat that's doing this (no offense intended). I've met several players over the years who's sweat from their hands corrodes strings &/or leaves gunk behind that isn't easy to clean off.
These guitars are buffed with compound on a buffing wheel, anyone who's ever buffed a finish knows if it's not hard it'll peel/tear off or melt on the wheel.
River and AxeBuilder like this.
If you can keep your head while all about you lose theirs,.... you obviously haven't grasped the situation!!
GEAR
2010 CS 50th Aniversary R0 V2 from Guitar Works
2012 CS R8 Iced Tea from Eddie's Guitars
2010 CS R7 Gold Top from Eddies's Guitars
POD HD500
VOX Valvetronix VT30
KenG is offline   Reply With Quote
Unread 01-13-2012, 10:17 AM   #20 (permalink)
ctkarslake's Avatar
Anyone know if what the difference between the VOS finish nitro and GLOSS finish nitro is?
I've been under the impression that only the VOS finish has all the "gunk" issues.
2007 LP R7 Ebony w/factory bigsby, Gloss
2005 LP R8 Plaintop, washed cherry sunburst, Gloss
2003 LP Elegant Quiltop, butterscotch, Gloss
2001 LP Standard, Raw Power, Satin
1998 LP R8 Flametop, vintage red, Gloss
1997 LP R8 Plaintop, vintage red w/factory bigsby,Gloss
1965 Hagstrom II, baby blue
Marshall AVT50H+4x12CAB
Epiphone Valve Jr.
ctkarslake is offline   Reply With Quote
Unread 01-13-2012, 10:18 AM   #21 (permalink)
db3266's Avatar
Originally Posted by KenG View Post
A comment to those who always find the necks sticky,.. it's more than likely your own sweat that's doing this (no offense intended). I've mat several players over the years who's sweat from their hands corrodes strings &/or leaves gunk behind that isn't easy to clean off.
I think I have to agree with this. I use Pure Nickel strings and they also go dirty very quickly.
Unread 01-13-2012, 10:19 AM   #22 (permalink)
winexprt's Avatar
I see. If you could speed up the application (and drying?) times you could pump more guitars out the door. That would make sense financially.
My 2011 Traditional Plus was a tiny bit sticky/tacky when I first got it, but that only lasted a couple of weeks. It's completely dry and not the least bit sticky now. I guess the fact that I had it outside of its case and on a stand for several months helped the drying process along.
Unread 01-13-2012, 10:28 AM   #23 (permalink)
Bartlett RetroPAF Vendor
cooljuk's Avatar
So they DON'T crack and check.
The percentage of the buying demographic that WANTS their guitars to do that is likely pretty minimal. There's just a much higher concentration of us here.
cooljuk is online now   Reply With Quote
Unread 01-13-2012, 10:31 AM   #24 (permalink)
cooljuk's Avatar
VOS and Gloss Gibsons from the Custom Shop have the same nitro sprayed on. VOS guitars just have some extra gunk (buffing compound) slathered on top of the finish.
Gibson's modern version of "nitro" just isn't the same nitro formula used in the glory days. That's why they don't check and crack.
deepblue likes this.
Unread 01-13-2012, 10:32 AM   #25 (permalink)
If I buy a historic, I would very much like it to crack and check , I would guess, that ***quite a few*** people buying **historics** (many of us are vintage nuts anyway) would like that as well. That's why I would only guess a proccess speed up behind this plastic stuff on the historics.
The finish used back in the 50's was a COMPLETELY different one. ON how many of your historics has the burst faded??! Even if the guitar is 20 years old, it doesn't fade. That's a different finish, call it whatever you like, it's not historicaly correct.
Unread 01-13-2012, 10:43 AM   #26 (permalink)
Barker's Avatar
I have no idea what is really in Gibson's nitro. I will say though that my 2011 R8's finish is rock hard, and it even has some fine check marks (finish cracks) on various parts of the body. I have done nothing to 'encourage' this, we have had some really large temperature, and humidty swings, and it did have a couple of cold nights in my car (oops), but that's it.
r9in09 likes this.
Barker is offline   Reply With Quote
Unread 01-13-2012, 10:44 AM   #27 (permalink)
Murphys are aged but not refinished, it's not ONLY the ageing. It has to do with the finish material as well.
Unread 01-13-2012, 10:46 AM   #28 (permalink)
Barker's Avatar
Mine has faded, and it's less than a year old. I did give it a little sun time, but only around 30 hours. The nitro has ambered as well.... .
Unread 01-13-2012, 10:47 AM   #29 (permalink)
mfolet's Avatar
They will indeed check and fade.My 2011 models have done so allready.
AXE, Barker and aspDev like this.
Unread 01-13-2012, 10:47 AM   #30 (permalink)
mfolet's Avatar
AXE likes this.
