| View Poll Results: Does your Historic stay in tune ? | |||
| Yes ! |
82 | 90.11% |
| No ! |
2 | 2.20% |
| Not for more than a song or two !! |
8 | 8.79% |
| Multiple Choice Poll. Voters: 91. You may not vote on this poll | |||
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
MVP Clown
![]() Join Date: Sep 2007
Does your Historic stay in tune ??
Are you happy with the stock tuners that your Historic came with and does your guitar stay in tune to a reasonable degree ? I see alot of pro players upgrade from the stock Kluson's to Grover's .... If you changed tuners did you notice a difference in tuning stability and or tone ??
#2 (permalink) |
Re: Does your Historic stay in tune ??
Mine stay in tune and I'm fairly brutal and beat the crap of of the strings.
Personally I prefer Kluson or Kluson style tuners. Back in the day the original Kluson's left a lot to be desired. That's why you see a bunch of Burst's with Grovers. However,today the Kluson style tuners are much better than their vintage counterparts. The biggest difference in tone would be the Grover's with their added weight(appox.5.5 oz)can add a bit more sustain and more focus to the tone. I prefer the more airy characteristics of Kluson style tuners. If one is having issues staying in tune then the culprit is usually the nut. The D and G strings are the most prone to going out of tune while playing due to their steep angle from the nut to the tuner. A properly cut nut and even some lube will correct most tuning issues. Also intsalling the strings properly and streaching them very well should be a given. Last edited by Sean French; 09-26-2007 at 01:02 PM. Reason: spelling |
#3 (permalink) |
All of my guitars, including two historics, stay in tune, at least close enough for government work.
Just do plenty of string stretching when I change strings |
#5 (permalink) |
Yep! The actual tuning machines themselves don't mean squat after the guitar is in tune. People switch to Grovers usually because of the smooth feel, and gear ratio which can make for easier tuning... but you still need to put lube in the nut, no matter what type of tuners you use... even a high end set of Schallers or Spertzel will pop when a string goes over a dirty spot in the nut, and jump a pitch.
#6 (permalink) |
I didn't know I was supposed to tune it...doesn't it come tuned?
2004 Les Paul R0 (Washed Cherry) 2006 PRS Custom 22 (Vintage Yellow) Mesa Lonestar Special |
#9 (permalink) | |
MVP Clown
#10 (permalink) | |
Guest
Posts: n/a
I've heard a lot of people over the years who blame tuning instability on vintage style Kluson tuners. I've even entertained this thought myself at one time, but after a little research, I can tell you that it's simply not true. A worm gear will turn a spur gear, but NOT the other way around. More times than not, the culprit is tight nut slots, failure to pre-stretch strings, not tuning UP to pitch, or any combination thereof. Do Grovers feel better? They sure do! Would I retrofit them to my Kluson equipped Lester? Absolutely NOT! |
#11 (permalink) |
I had a run on tuning problems as well with all three of my Historics, I focused on the nut, making sure it was slotted staright and correct depth and width, graphite (pencil lead works great) or nut sauce.
Correct string wrap on the tuner stems (critical) and then strings, I found the Boomers work great, I use the custom lights. I have no tuning issues now, (I posted a similar thread a few months ago) In the words of KennyF Absolutely NOT |
#13 (permalink) |
So far, I'm quite happy with the stock tuners on my R0. It stays in tune very nicely.
#14 (permalink) |
I also find nut lube to be the key. Whenever I buy any new guitar I put on new strings and nut lube the minute I get it home. I prefer to make my own lube with Vaseline and Graphite powder mixed 50/50. The commercial nut sauce is too dry for me. If I hear a ping sound when tuning a string I run a strip of emory cloth lightly through the slot to take off any burrs without actually sanding the slot lower. I've always had great luck with my Les Pauls staying in tune and I play with a heavy hand. I'm always puzzled when I read about Les Pauls being notorious for tuning problems. I usually chalk it up to people not knowing the basics of nut prep or PRS lovers doing their thing.
#15 (permalink) |
i play alot, and also do alot of bends..and the only time i have to touch the tuners on my R 8 is when i change tunings..like from standard to drop D..they are really the best tuners i've used..
#18 (permalink) |
![]() Join Date: Aug 2007
its allllllllll in the set up, I dont find anything wrong with the current version of the Kluson machines Graphite in the nut and bridge slot help I wind a whole lotta string on to the posts. I bend and vibrato alot when playing, compound bends with vibrato , both BB King style and or ala Clapton/ Betts , up and down. man that took a while to get right too
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk |
#20 (permalink) |
![]() ![]() ![]() ![]() Need some cheese to go with that whine there Bobbo? Jest had to tug yer chain on that one, sorry
#24 (permalink) |
yes, it stays in tune.
MySpace.com - Conny Martin - DE - Rock / Blues / Other - www.myspace.com/connymartin
#25 (permalink) |
![]() Join Date: Jun 2007
People are quick to blame the tuners, but I find that it isn't the problem. I find some guys just don't know how to wrap strings or stretch them properly. Also, Gibsons nut work just isn't the best. Have to make sure to have the nut slots properly cut, and always use something to lube the nut, since the material Gibson uses these days tends to be a bit soft and grabby. I would prefer they went to a harder plastic like the old days, or to bone.
Old Klusons would loosen up because the housings would bend a bit. Notice that thin strip of metal that surrounds the top side of the shaft on the sides? That is what holds the knob shaft gear to the string shaft gear. Over time, that little strip bends, and loosens up the tuner. I have found by carefully bending it back, the tuners work almost as good as new again.
#29 (permalink) |
MVP Clown
" Over the Pond Guy " PAF Pickups & M69 Rings ... @ OverthePondGuy@aol.com |
#30 (permalink) |
I have not had any problems. A friend of mine changed his tuners out to Grovers and compared to mine they felt loose when you turned them. There was some play in the knobs as well. The historic tuners on mine are tight and work just right. No issues.
www.tonefordays.com |
| R9 - any bad years to stay away from? | RCCola | Historics & Reissues | 35 | 05-27-2008 04:40 PM |
| New Epi won't stay in tune | Gunnysmiles | Epiphone Les Pauls | 43 | 05-26-2008 08:48 AM |
| switch epi tune-0-matic for gibson tune-0-matic? | Paul | My Other Guitars | 0 | 01-23-2008 01:09 AM |
| Boycott China, Boycott Korea. Stay away from Guitar Center | mojofilter | The Backstage | 60 | 01-11-2008 12:38 PM |
| strings don't stay in tune? | taypeng | Other Les Pauls | 3 | 01-09-2008 05:47 AM |
