| LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
Anybody know where to get longer nickel covered brass screws for ABR posts?
I recently did the Mapleflame mod on my R9 with some stainless 6-32 screws. While I liked being able to have them go deeper into the body it seemed to make this particular R9 just too bright. So I was thinking of trying to find some nickel plated brass screws to make deeper posts.
I found one seller on Amazon and ordered it but eventhough it says it's #6-32, the rod seems to be a larger diameter as the posts screws won't thread. Anyways, just wondering if anybody here has any experience with this |
#2 (permalink) |
Re: Anybody know where to get longer nickel covered brass screws for ABR posts?
I have done the same to a half dozen guitars and would like to see what you find out
![]() I've done stainless screws and I leave the heads on so that sucker is locked to the thumbwheel under the ABR.
![]() Axes: Tak LP,Lifeson,Dellinger,Suhr Set Neck Amps: 11R,Matrix 1000,GSP1101,GR-55 |
#3 (permalink) | |
Maybe they sent you 8-32 by mistake. I mean 6-32 is 6-32 is 6-32 AFAIK. The standard diameter only varies by .0008". Don't know how it could be different from 6-32 SS screws.
Gibson LP Classic Antique Fireburst GOTW #2 Bolt Electric Vintage P'ups Gibson LP G0 Darkburst GuitarForce LOTB P'ups Gibson LP Special TV Yellow Fralin P-90s Gibson Limited Edition Flying V 57 Classics Fender Limited Edition Strat Fender American Ash 8502 Telecaster Fender Bullet Deluxe S2 Ibanez AR-250 SD Phat Cats Epiphone DR500M Masterbilt Epiphone 58 Reissue Korina Flying V "It ain't what they call you, it's what you answer to" |
#4 (permalink) |
![]() Join Date: Sep 2009
I wouldn't tough the length to be honest! I'd only consider changing metal types.
One you should always pre-drill a pilot hole before going deeper into the guitar to avoid splitting the wood, and two drilling into the already threaded hole (threaded from the first rod) can mess the wood threads and make the hole sloppier.
If you can keep your head while all about you lose theirs,.... you obviously haven't grasped the situation!! GEAR 2010 CS 50th Aniversary R0 V2 from Guitar Works 2012 CS R8 Iced Tea from Eddie's Guitars 2010 CS R7 Gold Top from Eddies's Guitars POD HD500 VOX Valvetronix VT30 |
#5 (permalink) | |
