Go Back   Les Paul Forums > The Les Paul > Historics & Reissues
View Poll Results: Bigsby options (with Vibramate mounting)
Put it on the 335.. dude.. Richie Blackmore! 3 17.65%
Put it on the Les Paul.. Neil Young did.. 9 52.94%
You want a wiggle stick, buy a strat you moron.. 5 29.41%
Voters: 17. You may not vote on this poll
Unread 03-20-2011, 11:53 AM   #1 (permalink)
Bhodie's Avatar
Help with Bigsby Choices
I have been getting the jones lately to put a Bigsby on one of my Gibsons. I have both a(n) Historic '59 335 and a R8 LP.. both excellent guitars, both light enough to handle the extra weight without penalty.
I plan on using the Vibramate mounting system, so completely reversible in either case, but they do not use the same hardware (so I can't experiment between the two without spending 2X $) which means I have to pick one...
Give me your thoughts..
Bhodie is offline   Reply With Quote
Unread 03-20-2011, 12:35 PM   #2 (permalink)
darren.mcc's Avatar
Re: Help with Bigsby Choices
I've got one on both but I've never compared it to be honest, I'd say it should be the same though otherwise they'd market different ones for 335's and LPs...I'll check when I get home.
The Only Goal is Tone!
darren.mcc is offline   Reply With Quote
Unread 03-20-2011, 01:21 PM   #3 (permalink)
ryanmichael95's Avatar
Send a message via ICQ to ryanmichael95
On the Les Paul! The old school look of a Bigsby and a Les Paul go hand in hand IMO. My R9 will be getting one soon. Plus Les Paul used them, so it must be right!
gibson r9 (iced tea w/Bare Knuckle pups)
gibson SG classic faded
egnater renegade 65
epiphone valve jr.
2010 mesa boogie dual rectifier multi-watt
soldano hot rod 50+
kustom 412 u.s.a. cab w/WGS ET-65's/Veteran 30's
ryanmichael95 is offline   Reply With Quote
Unread 03-20-2011, 01:24 PM   #4 (permalink)
jd0272's Avatar
Well, my Gretsch is 'Bigsby armed', but in truth, I never utilise it. As such, tuning stability is usually fine, even with some moderate noodling, and even with the floating bridge. However, when it does get knocked it can whack the tuning out somewhat. I wouldn't have it as first choice for any serious wigglin'. Sure looks pretty tho!
jd0272 is offline   Reply With Quote
Unread 03-20-2011, 01:31 PM   #5 (permalink)
Alvinfan's Avatar
Here is the vote from the Danish jury :
Larry Carlton 335 - 1967 345 - Diamond hole 335
Alvinfan is offline   Reply With Quote
Unread 03-20-2011, 04:41 PM   #6 (permalink)
Bhodie's Avatar
Wow.. that is quite a jury!
