Go Back   Les Paul Forums > The Les Paul > Historics & Reissues
Unread 01-23-2011, 12:39 PM   #1 (permalink)
skynyrd67's Avatar
1959 build
Well after carefull consideration I have decided to build my own 1959 Les Paul Standard, granted I know it won`t be the same as a 52 year old origonal but its the closest to the real deal as I will be able to afford. Thinking about putting Seymour Duncan Pearly Gates pups in it since they were copied from 1 awesome 59 standard. Any pointers and or tips from the more experienced here would be greatly appreciated.
skynyrd67 is offline   Reply With Quote
Unread 01-23-2011, 06:42 PM   #2 (permalink)
chuck's Avatar
Re: 1959 build
Try the Luthier's Corner! Go through the build threads, it's worth every second you spend reading them...
Cheers
chuck is offline   Reply With Quote
Unread 01-24-2011, 05:00 PM   #3 (permalink)
skynyrd67's Avatar
Re: 1959 build
Thanks Chuck will definately give that the once over. very much appreciated.
Unread 01-24-2011, 05:39 PM   #4 (permalink)
Die Hard LP Man
KenG's Avatar
Re: 1959 build
Very ambitious undertaking I think. I've seen some good work done but it's always been done by real craftsmen not a hobbyist.
If you can keep your head while all about you lose theirs,.... you obviously haven't grasped the situation!!
GEAR
2010 CS 50th Aniversary R0 V2 from Guitar Works
2012 CS R8 Iced Tea from Eddie's Guitars
2010 CS R7 Gold Top from Eddies's Guitars
POD HD500
VOX Valvetronix VT30
KenG is offline   Reply With Quote
