#1 (permalink) |
1960 nut
I have a G0 from '05 or so that has serious nut issues. Tuning is a real problem as there is quite a bit of sticking. Should I be using something like nut sauce or going in with some sandpaper and widening things out a bit? I've already used pencil lead to no avail.
#3 (permalink) |
Bartlett Retrospec Member
Re: 1960 nut
Or replacing the nut with a bone version. For my Epiphone I built myself a bone nut. Up close it looks kind of dodgy but hey: it does its job very well!
![]() 2007 Epiphone Les Paul Std HCS 2011 Epiphone Casino 'Inspired by John Lennon' 2009 Fender CD-60CE BLK 2005 Behringer Strat Starter pack 70's MIJ Columbus SG 70's MIJ Ibanez 2350 Les Paul Custom Epiphone Blues Custom 30, JJ Tubes All electric guitars (except Casino) are loaded with IronGear pickups! |
#4 (permalink) | |
Re: 1960 nut
10-15 passes with each, kinda rocking the paper from side to side in the slot. Very gently. You can subtly flare out the headstock end of the slot as well. ![]() Lube with chapstick, graphite, or vasoline. Or my new fav... graphite powder *in* vasoline. MM
MM 2009 Gibson LP Standard Trad Pro Heritage Cherry Sunburst, 2007 Edwards LP-130LTS/RE-LMD, 2010 Gibson LP 50's Tribute Studio Goldtop w/Bigsby, 2006 Gibson LP Special DC Faded Cherry, 1989 Carvin DC135T, 1988 Carvin SH225, 1998 MIJ Squier Vista Venus, 2005 MIA Squier Affinity Telecaster, 2006 Ibanez Artcore AS83VLS, ShredStrat w/FR, SwampStrat w/ StraBro90's, Carvin V3 & V30 412, Egnater Rebel 30, Dave Hunter Two-Stroke, 2xCarvin 212CE, 2xCarvin 212 Classic |
#5 (permalink) |
Die Hard LP Man
![]() Join Date: Sep 2009
Re: 1960 nut
I invested in the STEWMAC nut files and with some other tools have made a few Micarta nuts (one's currently on the Elitist Plus). I've also found the files very handy for tweeking the nuts on my Trad and R0 (although nylon 6/6 doesn't cut as cleanly as corian). When I use sandpaper (400, 600 & 1200) I reinforced it with the nut files to keep the shape of the slots correct.
The files were also good for cleaning up the saddle notches and usefull when I replaced my pre-notched saddles on both of my Elitists with proper blank ones (done to better match the fretboard radius).
If you can keep your head while all about you lose theirs,.... you obviously haven't grasped the situation!! GEAR 2010 CS 50th Aniversary R0 V2 from Guitar Works 2012 CS R8 Iced Tea from Eddie's Guitars 2010 CS R7 Gold Top from Eddies's Guitars POD HD500 VOX Valvetronix VT30 |
