#1 (permalink) |
Especially on the G string, my bends going up one step are melancholy and anemic sounding. The G string is supposedly in tune, even a bit sharp, according to my Korg 30. The bends remind me of a cat wailing, not like the bends I hear EVERYONE else make. This Epi LP might be the problem, because I had it set up by a pro. Bad neck?
#2 (permalink) |
Re: My Bends are Anemic. How to Improve?
Two words: finger strength.
I used to carry a tennis ball around and just squeeze it. It builds up strength in your fingers. Nowadays they have grip-type things that they sell to do the same thing, but a tennis ball is a good way to do it on the cheap. - D
Bands, Present & Past: Nurse Diesel | Diesel On MySpace | Big Sky | 20FTWide | Solo Work | Chronicles: The Clapton Project "I learned a long time ago that one note can go a long way if it's the right one, and it will probably whip the guy with 20 notes." - Les Paul "You were old the first time I signed you." - unnamed A&R guy to StrangerNY, 2000 |
#3 (permalink) |
Memphis "The Paul" • Mightymites Partscaster • Lace Sensor Gold Vox AD60VTX • VC12 Vox VT30 • Crybaby Classic Danelectro Nifty Fifty 4Sale |
#5 (permalink) |
Location: Well I never been to heaven but I've been to Oklahoma
Try practicing a slow deliberate bend with your ring finger. Then practice with your index. After they start sounding the way you want them to, mix them in with riffs. Add speed later.
======================================== I hate to see her go but I love to watch her walk away. Gibson Les Paul 2008 custom 1997 Fender American Stratocaster plus Peavey Classic 50 combo 410 Peavey Delta Blues combo Vox Night Train 15 watt tube amplifier head Fender Band-Master VM 212 2x12" Straight Guitar Speaker Cabinet |
#6 (permalink) |
![]() Join Date: Jun 2008
You could try digging in more on the G, it's a great string to bend on. Make sure you're getting plenty of support from your other fingers on the string behind the fretted note.
If I'm fretting with the third finger, I'll tend to have both the first and the second fingers on the string for extra strength, supporting the bend. YMMV. |
#7 (permalink) |
What gauge strings are you using, and what tuning?
My finger strength is pretty good, but I still don't like 10s. Hence my use of 9-46s.
![]() MLP's biggest blue-collar asshole. |
#8 (permalink) |
Great point. Also remember the pinky is weak. Some players don't use it. Some use it for hammer and pulls only. I don't think anyone uses it for bends.
#9 (permalink) |
Right. When I pinky-bend, I'm usually using four fingers.
#11 (permalink) | |
Blame the guitar? Come on now.. practice, over and overrr..String size isn't usually a big issue either - I mean sure, at first it is, but your fingers adapt pretty quickly. I went from 8's a couple months ago to 11's now just gradually building up.. can't see any point in going any higher though |
#12 (permalink) | |
#13 (permalink) |
My .010 strings may have to go
My .010 strings may have to go. I tried an Ibanez with .009 strings and it was easier to bend the notes. BTW, my .010 strings have been on there for five months. Maybe they are worn out.
#14 (permalink) | ||
-Joe Join My Forum!!!! My band Atomic Pilot on: YouTube atomicpilot.com Myspace Twitter My Music Thread VM Worn Cherry Refin MIM Tele Refin |
#15 (permalink) |
MLP Ninja
![]() Join Date: Apr 2008
Well, according to _{Onesilverdousche}- or what ever his name was, you can use a wah pedal to "bend" your strings!!!!
![]() ![]() Your thread made me think of that, sorry. Try one of these.
GUITARGASM ![]() ![]()
#16 (permalink) |
Do you use all 4 fingers like River noted above when bending with the pinky?
#17 (permalink) | |
Charvel Model 2 (Japanese) 1987, Jackson Floyd Rose, Electric Blue, Rosewood Fender Telecaster USA Highway One 2007 Blonde, Maple Burny RLG 50 (1983-85) Black Gibson Les Paul Standard '58 VOS Washed Cherry 2008 Marshall 12R amp 1987 Line 6 POD X3 Fender Precision bass 70's replica in the making: http://www.mylespaul.com/forums/my-o...s-project.html |
#18 (permalink) | |
thinner strings = less tone
Practice your bends with your tuner on. Work on bending crisply to the desired note and holding it there. You need to develop the muscle memory and the ear memory to get there with authority. It's a skill, your gear, including strings, won't make any difference.
#19 (permalink) | |
#20 (permalink) | |
b) Excellent advice.
#22 (permalink) |
Here's another thought- generally when ones does a bend he bends the string up a 1/2 or full step and then either releases the bend so the note goes back to its original pitch, or he moves on to another note without the pitch of the bent note returning to where it started. In the latter case one has to mute the bent string as he lets go of it so that you cannot hear it return to its normal pitch. If you are not doing this the effect might sound like the wailing cat you refer to or as Justin Sandercoe says "seagulls".
#23 (permalink) |
Bending is personal. It's not personal like underwear, but personal because you bring your own touches, and because I get to share in it. I do not 'train' using grips or strengtheners to play guitar. I just play.
Off topic: but Sin, your avatar is striking. One of those new-fangled computer altered thingies, no doubt. |
#24 (permalink) |
When I was first starting out, I had 10-46 strings and could only bend to about 2 notes. I decided to move to 11-52 strings to play the same song I was learning just to see if the tone changed much and noticed bends were significantly harder but I persisted. After about 2 days of going at it to the point where my fingers were sore, I picked up my other guitar that had 10-46 strings and noticed I could easily bend to 3 notes.
#25 (permalink) | |
#26 (permalink) | |
'MLP Mid-West'
![]() Join Date: Jan 2008
![]() Like it was also said--it's all about hand strength...not just the fingers. Get one of those hand squeeze-exercise things, and work it out. Strong hands=monster bends and vibrato. Also, very important...stretch your hands and forearms before/after playing or exercising. BB
'Do it again on the next verse, and people think you meant it.' Chet Atkins |
#27 (permalink) |
True enough. I understood the OP's problem as not being able to bend the string enough but either way I think building up strength makes it considerably easier to nail accuracy. Then at least it's not a strength effort to get to that point but instead it's about how far you need to go to get the note you're aiming for. That's just about listening, practice, and muscle memory.
#28 (permalink) | |
#29 (permalink) |
Thanks. I'm an ex-commercial photographer (pre-digital) but its hard to tell how things are created these days. I thought a good caption for the photo would be "Everyman's fantasy, everyman's nightmare."
#30 (permalink) |
I keep an old takamine acoustic (12-54) around the house to play and when I plug in my electric it's easier all around to play it (10-46). Similar idea.
Another thought is that you may incorporate it as part of you style...and refine it... Albert King said those picks kept flying out of my hand so I just used my thumb...his bends are pretty large, if he needed to go up to a note he'd just bend to it. |
| How to improve the PCB board | The_Sentry | Gibson Les Pauls | 72 | 02-17-2010 06:30 PM |
| Exercises to improve your playing | mc_carlini | Guitar Lessons | 7 | 06-16-2009 02:19 AM |
| How to improve my guitars sound? | Knarbens | Tonefreaks | 13 | 10-04-2008 11:02 PM |
| Bends Vibrato and Major Notes!! Blues You Can Use Video | dkirwan | Guitar Lessons | 4 | 02-05-2008 03:24 PM |
| new member, looking to improve my epi LP | buckfu | Epiphone Les Pauls | 37 | 08-04-2007 01:44 PM |
