Go Back   My Les Paul Forums > Music Gear > Guitar Lessons
Old 10-24-2009, 02:03 PM   #1 (permalink)
st.bede's Avatar
poly-rythms
ok...I was wondering: how do you count 5 and 7 and 9 over a 4/4 measure(the whole measure, all four 1/4 beats)...I have no problem with 3 against 4 but the others are strange....
ultimately, what I want, is to hear the choices in my minds eye.
"to criticize without vision is to be complicitious with dominance" Carolyn Casey
"Go easy and, if you can't go easy, go as easy as you can" Jennifer Stone.... (from KPFA Cover to Cover)
the wings of inspiration come to each according to their own song-des
st.bede is offline   Reply With Quote
Old 10-24-2009, 02:31 PM   #2 (permalink)
huw
huw's Avatar
Re: poly-rythms
Find the common denominator: eg for 5 against 4 the CD would be 20. Think of it as 16th notes in 5/4 (1234 2234 3234 4234 5234. Obviously the 1/4 note beat is your 5; and to find the 4 beat, accent every fifth 16th note...
...put it all in a drum machine & just listen to it looping until the pattern gets into your head & you aren't thinking about the count...
Real amps have FENDER written on them...
huw is offline   Reply With Quote
Old 10-24-2009, 02:39 PM   #3 (permalink)
st.bede's Avatar
Re: poly-rythms
once again thank you....
Removing Poly..... HCB 06 The Custom Shop 8 06-09-2009 08:41 AM
Retouching poly Kuroyama The Custom Shop 1 03-22-2009 07:51 AM
Poly Checking leftylover The Custom Shop 5 03-20-2009 10:10 PM
poly vs nitro RocknRoller Epiphone Les Pauls 37 03-06-2009 05:08 PM
LP with poly finish rybass Gibson Les Pauls 4 02-03-2009 06:23 PM
Powered by vBulletin® Version 3.8.4
