Go Back   Les Paul Forums > Music Gear > Guitar Lessons
Like Tree8Likes
  • 1 Post By Thumpalumpacus
  • 4 Post By Thumpalumpacus
  • 1 Post By Seceded
  • 2 Post By huw
Unread 12-14-2011, 03:35 PM   #1 (permalink)
how to jam over this song??
Hello guys so I am trying to solo over
But I am stuck.. I looked at the tab and the main riff is in fourths.
this is mostly all the song
Main Riff
E:-------------------------------------
B:-------------------------------------
G:------------------------------------- x4 (At The Start)
D:-------------------------------------
A:---0--3-4--0--6-7--10--6-7--0--5--3-4
D:---0--3-4--0--6-7--10--6-7--0--5--3-4
and this small not so strong harmony
PM
G:------------------------------------- x4 (The Last 3-4 is not palm muted and on the last time you miss out
D:------------------------------------- the last note)
A:-------------------------------------
Corus
E:----------------3--------------------
B:----------------0--------------------
G:--7------5------0------5-------------
D:--7------5------0------5-------------
A:--5------3------2------3-------------
If I analyze the notes in the main riff. The notes do not belong to a single key so I am clueless what could I use to solo over.. and dont sound out of tune/key
Any tips how to find the scales that will work over and dont sound out?
What is a good way to know what work over given song?
-maybe moving the major scale box. (ioian mode) until you find the right key??
then aply major pentatonic etc..?
And finally when you compose do you think in keys?
-something like lets do a song in D major?
-or you just simply lay out chords you think sound good together?? then do melody
-same but starting with the melody?
any input is greatly apreciated
LESPAULplayer is offline   Reply With Quote
Unread 12-14-2011, 04:18 PM   #2 (permalink)
Seceded's Avatar
Send a message via AIM to Seceded
Re: how to jam over this song??
The solo for slither is mostly pentatonic as it is. I would just start with the notes in the regular solo then work down/up the fretboard.
"I'm On The Nightrain!"
Guitars:
USA - Gibson 1958 RI plaintop VOS
MIC - Epi Slash Plus Top 50's wiring
MIK - Epi Ebony Custom W/ BB's "Crowd Pleaser" Pickups
Seceded is offline   Reply With Quote
Unread 12-14-2011, 07:30 PM   #3 (permalink)
cessnapilot182's Avatar
Try different modes of the pentatonic over D..the song is in the Key of D, so you need to solo in the key of D.
cessnapilot182 is offline   Reply With Quote
Unread 12-15-2011, 12:21 PM   #4 (permalink)
hey thanks..
may I ask how do you know it is the key of D??
Unread 12-15-2011, 12:42 PM   #5 (permalink)
Thumpalumpacus's Avatar
Use more than one key. Play through the changes.
cessnapilot182 likes this.
My Soundcloud
Unread 12-15-2011, 12:47 PM   #6 (permalink)
Also, as far as composition goes, sometimes they start as exercises, sometimes as inspired moments, and sometimes simple mistakes.
River, JohnnyN, Seceded and 1 others like this.
My Soundcloud
Unread 12-15-2011, 01:38 PM   #7 (permalink)
Seceded's Avatar
Originally Posted by LESPAULplayer View Post
hey thanks..
The song is in drop d tuning IE song is in D
Guitars:
Unread 12-15-2011, 04:38 PM   #8 (permalink)
garybaldy's Avatar
The main notes to use are D F G A C - the Dmin pentatonic.
Its surprising what you can achieve riff and run-wise with just these few notes over this kind of rock song.
You can then add an F# (Gb)between the F and G as a 'passing note' and also G#(Ab) between the G and A up or down.
As you get more proficient you will be able to add the other notes not mentioned so far.You'll soon realise which work and which dont.
Ultimately the choices are limitless.
garybaldy is offline   Reply With Quote
Unread 12-16-2011, 03:05 AM   #9 (permalink)
ryancowden's Avatar
Here's what you do. put on a top hat, smoke ciggarettes, and get a badass les paul. you wont have a problem at all soloing over that song.
haha.
that song is really tricky, do what i do man, find a couple notes that work and start running different scales off of those notes until you find one ya like, then use FEELING when you play it.
good luck man, post it on youtube when you find somethin good.
2011 Gibson LP 50s Tribute W/ 'Buckers
Dean Dime 'O Flame
Ibanez RGA7 7 String
60s Decca Semi Hollow
Cheap Johnson LP Copy
Yamaha Classical Nylon Acoustic
ZW Phase 90
Wylde Wah
Boss DS-1
Orange Micro Terror
Peavey 5150 II 120W Head
Line 6 Spider IV 75W
and metal in my soul...
ryancowden is offline   Reply With Quote
Unread 12-17-2011, 11:01 AM   #10 (permalink)
huw
huw's Avatar
Location: Macclesfield, on the edge of the Peak District
That's true in this case, but not every song in drop D tuning is in the key of D. EG - Zeppelin, Ten Years Gone: Drop D tuning but key of A.
A chord change is not a key change. It's just a chord change.
huw is offline   Reply With Quote
