MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Unread 07-09-2010, 11:23 AM   #1 (permalink)
Hamtone's Avatar
Consensus on locking tuners for a LP
I have never had any, but they look to be pretty cool. Those who have them do they slip or are they more stable than winds?
Hamtone is offline   Reply With Quote
Advertisement
Unread 07-09-2010, 11:34 AM   #2 (permalink)
st.bede's Avatar
Re: Consensus on locking tuners for a LP
I have four guitars with locking tunners...
two PRS, which come with them and, my LP and MM have planet waves on them...
the planet waver are very stable and you can really dial in pitch of the string to a very fine degree...some people dislike that you can pull the strings out of them but, it takes a lot of strength and I can not imagine a situation where that would happen unless you are purposely trying to pull them out...
the PRS ones are not as fine but work very well....
one day I plan on having planet waves on all my guitars but, it is on my very long to do list...it really is about ease and string changes become significantly quicker and much less a hassle...
overall my experince would suggest they are as good as or better then typical tunners...
"to criticize without vision is to be complicitious with dominance" Carolyn Casey
"There is no hierarchy of goodness" Des
"Two kinds of karma, instant and full perk. Both will keep you up."
kevinpaul
st.bede is online now   Reply With Quote
Unread 07-09-2010, 11:45 AM   #3 (permalink)
Raz59's Avatar
The thumb wheel looks cool and it doesn't have the obscenely long tuning post that is associated with other tuners. And I would have had those if they came out earlier...so I settled for your standard nickel Grovers
ἀ θ ε ό τ η ς
Raz59 is offline   Reply With Quote
Unread 07-09-2010, 11:48 AM   #4 (permalink)
I put locking Grovers on my '77. They work perfectly and do not slip. Changing strings is a breeze. My PRS came with locking tuners stock.
My only question is why LPs don't come with locking tuners as stock?
https://soundcloud.com/torren61/dadgad-mlp-jam-1
Dying is like going into another room. Another room where you're dead.
Torren61 is offline   Reply With Quote
Unread 07-09-2010, 12:15 PM   #5 (permalink)
Alvinfan's Avatar
I have Sperzels on a couple of mine. It works great and makes string changing so much easier. I also have tonepros on a SG to keep the vintage look :
TonePros-Kluson
Alvinfan is offline   Reply With Quote
Unread 07-09-2010, 12:18 PM   #6 (permalink)
They're exactly the same. I've got Sperzel lockers on some LP type guitar headstocks, standard Gotohs and the like on others. There's no difference in terms of tuning stability whatsoever. The Sperzels are a bit quicker to swap a string on. That's it.
dspelman is offline   Reply With Quote
Unread 07-09-2010, 12:43 PM   #7 (permalink)
Hamtone's Avatar
I just need some in gold with this right angle screw hole
Or matches the original gotoh holes
Unread 07-09-2010, 12:53 PM   #8 (permalink)
Jason's Avatar
How far are your guys' guitars slipping out of tune? I don't have the best ears or the best digital tuner, but none of my cheapo guitars slip out of tune as far as I can tell. Not only that, but tuning is always a compromise so you can't really say it's ever really "in tune", can you? I dunno, I'm just trying to wrap my head around the situation, not trying to be a smart ass.
Jason is offline   Reply With Quote
Unread 07-09-2010, 12:57 PM   #9 (permalink)
Hamtone's Avatar
Im modifying an lp and saw these as an option, so when I asked if they slipped out of tune etc, I was asking how good are lockers compared to wrapping your strings.
Unread 07-09-2010, 12:59 PM   #10 (permalink)
BillB1960's Avatar
I've never had a guitar that slipped out of tune regularly. I have seen a bunch of guitars with the strings so poorly wrapped that it was amazing they ever stayed in tune. Locking tuners are no more "stable" that regular tuners they just make it really easy to change strings.
Gibson LP Classic Antique Fireburst GOTW #2 Bolt Electric Vintage P'ups
Gibson LP G0 Darkburst GuitarForce LOTB P'ups
Gibson LP Special TV Yellow Fralin P-90s
Gibson Limited Edition Flying V 57 Classics
Fender Limited Edition Strat
Fender American Ash 8502 Telecaster
Fender Bullet Deluxe S2
Ibanez AR-250 SD Phat Cats
Epiphone DR500M Masterbilt
Epiphone 58 Reissue Korina Flying V
"It ain't what they call you, it's what you answer to"
BillB1960 is offline   Reply With Quote
Unread 07-09-2010, 01:03 PM   #11 (permalink)
Hamtone's Avatar
Thats what i wanted to know if they were more less the same whatever, I change my strings a lot and when Im playing out I change then right before sound check of every gig
Unread 07-09-2010, 01:04 PM   #12 (permalink)
Jason's Avatar
Ah, gotcha now. It's a mystery to me! I would think they'd be helpful if you had one of these and were going for absolute tuning perfection:
Unread 07-09-2010, 01:09 PM   #13 (permalink)
BillB1960's Avatar
Those frets keep making me rub my eyes
Unread 07-09-2010, 01:09 PM   #14 (permalink)
Raz59's Avatar
ἀ θ ε ό τ η ς
Unread 07-09-2010, 01:11 PM   #15 (permalink)
Hamtone's Avatar
The original tuners that come on an 80s les paul, the vintage looking ones, will the screw hole on a grover fit?
All Im really up to is trying to replace the chrome with gold, and the joker before me installed schallers and drilled a 3rd hole in the headstock. Im also quite tight about spending 110 for a set of gold tuners, it makes me want to vomit a bit.
Unread 07-09-2010, 01:13 PM   #16 (permalink)
Hamtone's Avatar
Originally Posted by Raz59 View Post
I cant tell is that screw hole the same as the schaller? I see a good price on these at wd
Unread 07-09-2010, 01:15 PM   #17 (permalink)
Raz59's Avatar
ἀ θ ε ό τ η ς
Unread 07-09-2010, 01:16 PM   #18 (permalink)
Hamtone's Avatar
You my friend are a handy guy, thanks
Unread 07-09-2010, 01:19 PM   #19 (permalink)
Raz59's Avatar
I just hope it helps! Cheers mate
ἀ θ ε ό τ η ς
Unread 07-09-2010, 01:23 PM   #20 (permalink)
Hamtone's Avatar
Looks as though I will have to stick with the regular schallers because the screw holes. Oh well stew mac has a great price on them, thanks again everyone.
Unread 09-17-2010, 09:12 AM   #21 (permalink)
I have a lowly Epiphone Special... nonetheless, I've suped it up and like her pretty well. I'm thinking about replacing the tuning machines. Are there any good tuners out there that will improve stability of tuning AND that won't require me to enlarge the holes?
CherryBomb is offline   Reply With Quote
Unread 09-17-2010, 09:59 AM   #22 (permalink)
Dino Velvet's Avatar
I have sperzels on my Parker and I love them. Very easy to work with. I didn't really like the locking tuners on my Deluxe strat. I have never put locking tuners on my lps because I just didn't have that many tuning problems.
Hmmm, smells like nitro....
Dino Velvet is offline   Reply With Quote
Unread 09-17-2010, 10:14 AM   #23 (permalink)
Boleskinehouse's Avatar
Completely unnecessary IMO...
Unread 09-17-2010, 10:25 AM   #24 (permalink)
SingeMonkey's Avatar
Location: Cape Town, South Africa (Yes. It's a real country)
I don't think they really help tuning stability that much, but they are very convenient. I have sperzels on my Pacifica, and I'm going to put rotomatics on my '83 LP. String changes are much faster with locking tuners and there's no real disadvantage.
Just like the move from slotted headstocks to the typical kind made string changes quicker, locking tuners push it even further - and with no real cosmetic change.
SingeMonkey is offline   Reply With Quote
Unread 09-17-2010, 10:29 AM   #25 (permalink)
circusboy28's Avatar
Sure it's unnecessary, but why not...I hate changing strings!!
circusboy28 is offline   Reply With Quote
Unread 09-17-2010, 10:32 AM   #26 (permalink)
It doesn't take me any more time to string with conventional tuners... You shouldn't need more than two or three winds anyway.
Unread 09-17-2010, 12:34 PM   #27 (permalink)
Trea's Avatar
I have them on my Trad Pro. I wouldn't change out my other guitars for them unless there was a problem, but they do make string changes a bit quicker. I've never really had tuning issues on any of my Gibsons.
Way too much gear for my skill level...
Trea is offline   Reply With Quote
Unread 09-20-2010, 02:51 PM   #28 (permalink)
John Vasco's Avatar
Grover locking tuners on my '08 LP Standard - superb. Holds the strings perfectly. No wrap-around the string posts so no slack to be taken up. 100% superior to standard tuners. Don't listen to the Luddites...
Live clip of Splinter at The Cavern, November 2006: http://www.youtube.com/watch?v=GxOCksQUKbI
There are always crowds at Stonehenge. Doesn't mean they're all f*ckin' Druids...
D Major is a key, not a pitch.
John Vasco is offline   Reply With Quote
Unread 09-20-2010, 04:27 PM   #29 (permalink)
I love the Grover locking tuners on my Trad Pro. But that being said, I never had a problem with non-locking tuners either. Honestly can't really see a difference in tuning the guitar or the guitar staying in tune. BUT... I love how quick and easy it is to change strings on the Trad Pro.
1986 Ibanez AH-20 Allan Holdsworth Sig., 2009 Fender FSR Stratocaster (burnt orange flake finish), Fender Telecaster with Texas Special pups, 2009 Redplate Tweedyverb, Fender Super Champ XD, Lab Series L3 combo
Pedals: Line6 M13, Boss TU2, , Timmy, Red Snapper clone, Menatone Blue Collar, Hermida Reverb.
fjabjr is offline   Reply With Quote
Unread 09-20-2010, 05:07 PM   #30 (permalink)
lp_junkie's Avatar
My thoughts are they are useless, it's a fixed bridge guitar........ quit being lazy and if a lot of players would learn to string it properly and there are no tuning issues (non nut related) or slipping.
the "ease of restringing" excuse smacks of the general laziness that technology has started to introduce into our society. Do it the right way instead of looking for the easy way.
But those are my thought's- I also loathe the robot guitars and pcb's in guitars as well.
Shane
Just a guitar bum...........
lp_junkie is offline   Reply With Quote
