Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls
Like Tree1Likes
  • 1 Post By djwilbanks
Unread 04-02-2010, 12:20 PM   #1 (permalink)
weirdotis's Avatar
Pickguard installation tips
Does anyone have any tips for actually installing a pickguard properly? As far as proper screw placement?
Thanks guys, I'm planning a series of mods on my guitar to keep me entertained over the summer, and I think this is a good place to start.
-Matt.
Originally Posted by k.guitars View Post
Heaven forbid someone show a video of Audley Freed actually playing his Historic. Such nonsense might take away from the riveting conversations about Lifton cases and the tonal variations of glue...
http://matthewbrownmusic.net/
weirdotis is offline   Reply With Quote
Unread 04-02-2010, 12:22 PM   #2 (permalink)
djwilbanks's Avatar
Re: Pickguard installation tips
Tips for installing pickguard: Don't.
El_Greco likes this.
This post happily existed in all possible states until you observed it. Now it has collapsed into a single state. I hope you're happy.
Click Deadpool for my Soundcloud page.
djwilbanks is offline   Reply With Quote
Unread 04-02-2010, 12:30 PM   #3 (permalink)
axepilot's Avatar
Put one on my Gem not to long ago.......
Make sure the pickguard fits - no big gaps around the pickups or against the neck.
Leave the mount bracket just a bit loose when you're locating the screw position
Mark the holes carefully
Predrill the holes - that will keep you from cracking the clear coat and the screws will go in easier
Once you get over the fact that you're drilling holes in a Les Paul, it's easy.
axepilot is offline   Reply With Quote
Unread 04-02-2010, 12:36 PM   #4 (permalink)
weirdotis's Avatar
Should the mounting bracket be flush against the body?
I don't mind drilling holes in my nice guitar, since there's always Bondo!
-Matt.
Unread 04-02-2010, 12:36 PM   #5 (permalink)
weirdotis's Avatar
No.
-Matt.
Unread 04-02-2010, 12:36 PM   #6 (permalink)
Xavier_32's Avatar
It's pretty hard to mess up. Basically, line up the pickguard so the pickup rings sit flush against the slots for them in the pickguard, then shove the screw for the top of the guitar into the wood. When you line up the bracket, try and get the screw right where the binding meets the body.
Your pickguard should be at an angle, with the left most edge (on a right handed guitar) touching the bottom of the pickguard rings near the body, and the outer edge floating off the body. Of course, you could do what I did and gently bend the bracket to change the angle. I have my pickguard flush with the tops of the pickup rings.
Bassist for Cab 20 and Future Shock
Originally Posted by blakem (in regards to Norlins) View Post
Mines done got sausage too! Maple, Pancakes and sausage!
From now on, mini humbuckers shall be known as sausages.
Xavier_32 is offline   Reply With Quote
Unread 04-02-2010, 12:39 PM   #7 (permalink)
SludgeBurns's Avatar
Make sure the screw that holds the mount underneath the pickguard doesn't bump or press against the body.
Other than that, I agree with dj
SludgeBurns is offline   Reply With Quote
Unread 04-02-2010, 12:39 PM   #8 (permalink)
axepilot's Avatar
No. It should be angled a bit.
Unread 04-02-2010, 12:42 PM   #9 (permalink)
weirdotis's Avatar
Er, my bad. I meant, sound the part of the bracket that holds the screw to the side of the guitar be flush? If you see what I mean.
-Matt.
Unread 04-02-2010, 12:43 PM   #10 (permalink)
weirdotis's Avatar
Cool... Thanks for the info!
If I was to pre drill the holes, what size drill bit should I use?
-Matt.
Unread 04-02-2010, 12:44 PM   #11 (permalink)
axepilot's Avatar
then shove the screw for the top of the guitar into the wood.................
You really don't want to just shove a screw into the wood. Predrill the hole with a very small bit:
-It will get the screw started right where you want it...the screw won't be sliding over the clear coat and possibly going in at a bad angle
-You won't crack the clear coat
-The screw goes in easily
Unread 04-02-2010, 12:45 PM   #12 (permalink)
axepilot's Avatar
About half the diameter of the screw.
Unread 04-02-2010, 12:48 PM   #13 (permalink)
axepilot's Avatar
The side mount bracket should be mounted flush to body when it's screwed in. The screw and nut on the pickguard should be tightened once both screws are secure.
Unread 04-02-2010, 01:00 PM   #14 (permalink)
axepilot's Avatar
Good point. I checked this before I marked the mounting holes.
Unread 03-09-2013, 12:29 PM   #15 (permalink)
cgm
cgm's Avatar
I am putting this video here so I can find it if i decide to put a pickguard on my LP Fireburst Studio... Not that this looks all that difficult to do, I just need to bring up my nerve to drill into my guitar if I decide that I want a pickguard. My old epi had a one, and I really liked using it as a finger rest. I have been playing this for a month or two, I think it is time to install one into this:
Does anyone have an extra cream pickguard sitting around collecting dust? If so, let me know how much for it shipped to 01830.
cgm is offline   Reply With Quote
