Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls
Unread 04-02-2010, 05:34 AM   #1 (permalink)
guitarcase's Avatar
Narrow or wide bridge?
From a previouse post, I am going to fit a new Gotoh bridge. They do a modern abr ish equivelant which is narrow, or a Nashville which is wider and gives a larger range for intonation adjustment. Same stud and saddle spacings on both. What would you go for? Any disadvantages of wide bridge, will strings touch back so have to set tailpiece higher?
guitarcase is offline   Reply With Quote
Unread 04-02-2010, 05:44 AM   #2 (permalink)
Re: Narrow or wide bridge?
I would go wide as I like for adjustment flexibility and this might prevent you from having to flip the saddles around to get the correct intonation adjustment. It will also give you the flexibility to intonate a variety of string gauges.
Matt616 is offline   Reply With Quote
Unread 04-02-2010, 06:06 AM   #3 (permalink)
Dr. Brown's Avatar
ABR all the way. You'll have to topwrap with the Nashville if you go low with the Tailpiece. Plus the Nashville is ugly.
Dr. Brown is offline   Reply With Quote
Unread 04-02-2010, 06:09 AM   #4 (permalink)
Agreed!
Unread 04-02-2010, 07:32 PM   #5 (permalink)
ctkarslake's Avatar
The Nashville is not that much uglier, but it IS wider and will get in the way of dropping the tailpiece down. The ABR is just as fine a design, smaller in width and won't get in the way of dropping the tailpiece down to the deck. Why Gibson went Nashville is beyond me. ABR is more than enough to intonate, as long as your neck/frets are in the right place. Plus, it's a simpler design and transfers the strings vibrations more directly deep into the wood via thin posts screwed into the top. Classic. As far as I know these bridge designs are NOT interchangeable.
2007 LP R7 Ebony w/factory bigsby, Gloss
2005 LP R8 Plaintop, washed cherry sunburst, Gloss
2003 LP Elegant Quiltop, butterscotch, Gloss
2001 LP Standard, Raw Power, Satin
1998 LP R8 Flametop, vintage red, Gloss
1997 LP R8 Plaintop, vintage red w/factory bigsby,Gloss
1965 Hagstrom II, baby blue
Marshall AVT50H+4x12CAB
Epiphone Valve Jr.
ctkarslake is offline   Reply With Quote
Unread 04-03-2010, 12:19 PM   #6 (permalink)
guitarcase's Avatar
You can get m4 inserts to go in body to replace my usa, and m4 thumbwheel to fit the Gotoh ABR.(so I have been led to believe) So nowhere near authentic abr, but in the same size range. Thanks, I think I will go this route as raising tailpiece so the string didn't touch the back of bridge was a concern I had of the wider 'nashville'
Unread 04-03-2010, 12:23 PM   #7 (permalink)
ehamady6's Avatar
+1 on the ABR.
_________________________
ehamady6 is offline   Reply With Quote
