#1 (permalink) |
Les Paul sustain
It has been mentioned on another thread that heavy wood automatically means more sustain, i would like to lay this myth to rest once and for all. Ok lets get the KM gibsons out of the picture they are a whole other story, lets just focus on the TN gibsons. I have a few heavy wood LPs from the late 70s they dont sustain more than say your average guitar of this type, i have some early LP classics probably chambered and very light in weight. The classics drop jaws with the sustain they produce im not kidding, they go on for ages its crazy what is going on?
#3 (permalink) |
Re: Les Paul sustain
....and the bridge....and the nut....and the strings....
1980 Gibson Les Paul Custom - Heritage Cherry Sunburst (stock) 2004 Epiphone Les Paul Standard Plus - Honeyburst Flame-Top (SD Phatcat P-90 / Gibson '57 Classic Plus Pups) 2002 Epiphone Elite Standard Plus Faded Cherry 2005 G&L Legacy '79 Alvarez 12 string 2007 Seagull 6-string acoustic Vox AD60VTX "Have you hugged your Custom today?"
#4 (permalink) |
There are a lot of factors involved in sustain in electric instruments, the biggest one being construction quality. Weight doesn't always equal sustain. Sustain comes from free movement of the strings. It is often *but not always* the case that a lighter guitar will absorb more of the string movement than one of the same size, but with more density, because the dense wood itself is less likely to vibrate. 90% of the time though, its the actual physical construction that matters.
My 79 KM will out sustain any of my other electric guitars, and yes it is heavy, but it is also a near flawless instrument. I have an 88 TN that used to be a dog to play, but I put some work into it and now it plays and sounds great. Is about 4 lbs lighter than the KM, and is missing some of that mystical sustain. I can't just blame the weight though. It is a late 80's Standard.... Not exactly known to be the best Gibson had ever made... What year is your Classic? It wouldn't be chambered unless its a late 06 or 07. All Classics from before '06 have weight relief holes drilled into the body, but no chambering. |
#5 (permalink) |
Oh and FYI I used to have a Plexiglas Strat that would out-sustain anything... Why? Because the body material was so hard it couldn't absorb sound *Plexiglas is used as drum shields to separate the drummer from the vocal mics.*
Now this didn't mean that it sounded good... *It didn't sound too bad* but it had immense sustain. |
#6 (permalink) |
I've also heard arguments that the more pieces - i.e. laminated pancake body w/ 3 piece top - the less likely you are to get good sustain as the laminate points (especially if imperfect) don't transmit the vibration like solid wood.
_________________________________________ 2004 LP Faded Heritage Cherry 2001 LP Plus 2004 LP Limited Santa Fe Sunrise 2003 LP 1957 Custom w/ Custom Shop flames 1983 Marshall 50w red head * 2005 THD BiValve |
#7 (permalink) |
By dropping the pick-ups pole pieces can result in an increase of sustain....
![]() ___________________________________ 2002 LES PAUL STD 50'S NK, HCSB 2006 ES335 59 REISSUE, VSB 1996 EPIPHONE DOT, CHERRY RED (REFITTED) MARSHALL JCM2000 DSL100 & 4x12 SLANT CAB GARRISION ELECTRO-ACOUSTIC BOSS - TU-2, CH1,DD-6,PH-1, DUNLOP 535Q, ZW44 |
#8 (permalink) |
![]() Join Date: Jan 2008
vibrations happen in the strings and produce energy. the faster the energy is absorbed into the guitar, the less sustain one gets. the slower the energy is absorbed into the guitar, the more sustain one gets.
a luthier explained to me that it doesn't matter if a guitar is chambered or weight relieved. a good luthier can cause such a guitar to have more sustain than a standard without chambering. it all depends on how he or she arranges the wood. it can be put together in such a manner that energy is absorbed into the guitar at a slower rate producing more sustain.
Got groove? Myspace Treat EVERYONE with the respect and kindness you would want to be treated with and you are someone special.
#9 (permalink) |
![]() Join Date: Apr 2008
IMO, the simple answer to this is the sustain of a Gibson is unique and no matter if its chambered or not, the sustain will always be better than any other guitar out there. I have a "high-end" Ibanez Joe Satriani signature series and from listening to songs like Flying in a Blue Dream, I thought the sustain was fantastic. It was. But when I played a Gibson LP, my definition of sustain changed altogether.
2008 Gibson Les Paul Classic Heritage Cherry 2005 Fender American Standard Stratocaster Triple Sunburst |
#10 (permalink) |
![]() Join Date: Oct 2007
hey Lair. theres so many tales on this subject that its amazing
my 80 The Paul has a 3 piece Walnut body and a 5 piece neck and sustains for days with a pair of super D's. With the stock ceramics it couldnt get out of its own way. The walnut is so soft that you can scratch it with your nail. go figure how much does the soft wood affect it....who knows |
#11 (permalink) |
Walnut is a hardwood. The difference in hardwood and softwood is only viewed microscopically. Build a guitar out of a Douglas Fir and see if it does anything.
![]() As far as the wood itself actually being soft, sure... But its still a tonewood, and a hardwood at that. Whether or not the top felt soft, it still wasn't absorbing the sound like a softwood, or some kind of foam. Maple can be scratched and dented with a fingernail when its unfinished as well. Wood is not exactly the hardest material available, but different tonewoods affect the actual sound of the instrument. I've been told countless times that the best sustaining electric guitar would be made out of concrete. Would weigh 40klg but would sustain for days.
#12 (permalink) |
![]() Join Date: Jul 2007
and who'd have ever though that balsa would be a tonewood? But Gibson used it in some of the 'light' models, and it works. Supposedly, very close to mahogany as a tone wood I believe.
Of course, they called it something other than balsa. |
#14 (permalink) |
![]() Join Date: Dec 2007
Balsa (Ochroma pyramidale, synonym O. lagopus)...maybe they made the name up from it's Latin name
BFG Defender....The normal ones...Not the over priced "First 52 of Each" ones.
THIS THREAD IS DEAD! |
#16 (permalink) |
yeah...I'm sure they would
#17 (permalink) |
![]() Join Date: Nov 2007
There are plenty of light guitar that sustain well. There's more to it than weight.
My Les Paul with the best sustain is also the lightest - go figure. |
| sustain and feed back | player777 | Tonefreaks | 1 | 03-22-2008 06:39 PM |
| what can help me get increased sustain | schmidty123 | Tonefreaks | 34 | 02-16-2008 03:28 PM |
| Maximizing sustain? | MIDNIGHT | Tonefreaks | 8 | 02-11-2008 01:41 PM |
| How to sustain forever with a Les Paul? | Rock Star | Gibson Les Pauls | 23 | 10-16-2007 04:31 PM |
| Sustain...... | goofballone | My Other Guitars | 0 | 08-12-2007 05:15 PM |
