MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Unread 01-11-2010, 07:16 AM   #1 (permalink)
Alekseriator's Avatar
Send a message via ICQ to Alekseriator Send a message via Skype™ to Alekseriator
Slash's guitar's neck profiles...
What do all Slash's guitars have for a neck profile?
Alex
Guitars:
Gibson Les Paul Standard 2006
Amps:
Marchall class 5 selling atm
soon to be mine Blackstar HT 40/60
Alekseriator is offline   Reply With Quote
Advertisement
Unread 01-11-2010, 07:22 AM   #2 (permalink)
w00dsy's Avatar
Send a message via MSN to w00dsy
Re: Slash's guitar's neck profiles...
big, very big.
w00dsy is offline   Reply With Quote
Unread 01-11-2010, 07:48 AM   #3 (permalink)
MXR
MXR's Avatar
slash signature les pauls have slim profile neck
MXR is offline   Reply With Quote
Unread 01-11-2010, 08:06 AM   #4 (permalink)
Fracture's Avatar
Somewhere in between.
Fracture is offline   Reply With Quote
Unread 01-11-2010, 08:35 AM   #5 (permalink)
It's funny you ask this to 100 people and get 100 different answers. Even Gibson cant/wont answer it. I just know that I love it and wish I could send any Les Paul to Gibson to get that neck. It's the most comfortable 'for me'.
PeteyPablo is offline   Reply With Quote
Unread 01-11-2010, 08:56 AM   #6 (permalink)
dennistruckdriver's Avatar
Here....let ME Google that for you....
"The Slash-designed solid mahogany neck is given a thin, comfortable profile to Slash's personal specifications...."
Gibson Guitar: Gibson USA Limited Edition Les Paul Slash Guitar Specs, Price and Pictures
Unread 01-11-2010, 09:34 AM   #7 (permalink)
bullpentherapy's Avatar
thanks for the info here! also is the case that comes with the usa the same case you get with any newer style usa paul? the handle and outer skin looks a little different?
bullpentherapy is offline   Reply With Quote
Unread 01-11-2010, 09:37 AM   #8 (permalink)
circusboy28's Avatar
and does this profile give you the famed "Slash - Tone" or any of his chops?
circusboy28 is offline   Reply With Quote
Unread 01-11-2010, 09:38 AM   #9 (permalink)
Originally Posted by bullpentherapy View Post
....also is the case that comes with the usa the same case you get with any newer style usa paul?....
Click the link....
Unread 01-11-2010, 09:45 AM   #10 (permalink)
Click the link....
i ask because, when i click on the link, the thumbnails 4 and 6 have different handles to the case, check it out! its at the usa gold top les paul thumbnails! the one with the darkback!
Unread 01-11-2010, 09:48 AM   #11 (permalink)
Gibson - Gibson Guitar: Talk 2 Us, Electric and Acoustic Guitars, Bass Guitars, Baldwin Pianos and
Unread 01-11-2010, 09:55 AM   #12 (permalink)
[QUOTE=dennistruckdriver;1432406]Gibson - Gibson Guitar: Talk 2 Us, Electric and Acoustic Guitars, Bass Guitars, Baldwin Pianos and[/QU
ok thanks, i dont think i will be asking about this one though!
Unread 01-11-2010, 10:02 AM   #13 (permalink)
Why not?
Unread 01-11-2010, 10:11 AM   #14 (permalink)
Why not?
well there are alot of reason's, the money for one, two a signature guitar ehh idont know, etc. etc. but on the other hand , the specs are great and value in time will skyrocket if youre a collector!
Unread 01-11-2010, 10:11 AM   #15 (permalink)
In the same breath, Gibson typifies Slash's original neck (and the one they're modeling this guitar on) as a compromise between a 50's and a '60's. That's not "thin".
We may have covered this before (and I think there may be some real data on this out there), but I think that most 50's necks are in the 1" depth (fretboard to the back of the neck where your thumb rests) range with not a lot of taper. The thinner necks drop into the 22mm (25.4mm is one inch) to 23mm range. I think someone mentioned that the Jimmy Page neck on one of his guitars was actually thicker at the 1st fret, tapering to around 20mm somewhere around the 8th fret and then going thicker again as it moved toward the 14th fret, etc. I think that's unusual for a Gibson.
A *thin* neck is probably something like what I've got on one of my guitars -- it's 17mm at the first fret, tapering to 20.5mm at the 12th. That's moving toward Ibanez Wizard territory.
SHAPE is a whole 'nother matter, of course, with V and boat and C and D shapes changing everything. Taper (does it go from thin to thick, or from thick to thin to thick, or does it stay pretty much the same depth the whole way?) and asymmetrical shapes throw yet another monkey wrench into the works.
For all that Gibson gabbles on about their necks being hand-shaped, any luthier worth his salt will tell you that neck shape is repeatable (and should be) even when formed by hand. Most shapers will not simply pull material in a random or whimsical way (though I know of one classical guitar builder who does 12-14 extremely high-end guitars a year who works by feel) -- they'll work with a series of shape templates as they go.
In any case, I think that if we delegated someone to pick up one of these (cheapass contour gauge) from the local hardware store:
And measured, then scanned/photographed/traced the resulting contour at, say, the first, fifth and twelfth frets onto quarter-inch graph paper, we could build an accurate library of neck shapes that we could refer to as necessary...
dspelman is offline   Reply With Quote
Unread 01-11-2010, 10:24 AM   #16 (permalink)
Exluthier's Avatar
Jimmy's neck was reshaped to that profile, and I'd say it's an unusual neck for any guitar, not just Gibson.
I think your profile library is a great idea. There was a thread not too long ago where someone took the profiles off a vintage instrument (a junior I think?) and compared it to a RI of the same model. I've got some profiles copied and hidden around somewhere. If I dig them up I'll scan them and post them. They're only taken at the 1st and 12th fret but some of them are interesting.
Teles with humbuckers
Orange OR15
Phaez SIBLY
Exluthier is offline   Reply With Quote
Unread 01-11-2010, 02:59 PM   #17 (permalink)
mrtoulouse's Avatar
i meassured a slash glodtop's profile roughly using a very primitive set of calibers in a local shop a few months back. it was around 22mm at the first fret, and very gently got fatter towards the 12th fret which was around 23.5. This is a wee tad bigger than most 60's necks Ive had my hands on, but the trick, on this particular example at least, was in the very rounded shoulders, that gave it the feel of a slinkier neck than it really was.
Personally I shave down all my guitar necks to be around 20mm's pretty much consistently thoughout the 1st to 12th fret
As for the Jimmy Page profile, I have actually seen somewhere that it tapered to as little as 18mm around the 8th fret . Of course I can't recall where now, but I am pretty sure that that's what I read.
Perhaps someone who owns an example could provide the exact meassurements.
- 2006, r6
- 2008 faded, now a blacktop
- 2008 tele, almost qualifies as partscaster
- 1996 tele standard
- classic vibe tele
- marshall 2061x head
- marshall jcm2000 combo
- 1x12 and 4x12 g12t-100 cabs.
- fx: Boss TU-2 -> Tc electronics Nova dynamics compressor -> marshall bb2 -> Boss BD2 -> cc chorus -> Carl martin RR delay -> line6 verbzilla -> clean boost
mrtoulouse is offline   Reply With Quote
Unread 01-11-2010, 03:25 PM   #18 (permalink)
nick1962's Avatar
I had one of the slash LP standards, and I have to say I don't think the neck was 'thin' - would say it was somewhere in between thick and thin.
nick1962 is offline   Reply With Quote
Unread 01-11-2010, 03:40 PM   #19 (permalink)
>Photi G<'s Avatar
It's a 60's slim taper, right?
Who Needs Signatures Anyways...
>Photi G< is offline   Reply With Quote
Unread 01-12-2010, 01:15 AM   #20 (permalink)
w00dsy's Avatar
the Slash Epi Gold Top that i played had a fatter neck than my Studio neck, but obviously the Gibby version has a slimmish neck?
Unread 01-12-2010, 07:35 AM   #21 (permalink)
xguitardevilx's Avatar
It's a custom profile and it's more on the slim side. Kinda an in between '59 and 60's neck profile.
Equipment:
'96 Gibson Les Paul Standard Cherry Sunburst
'09 Gibson Les Paul Traditional Plus Iced Tea Burst
'82 Gibson Les Paul Custom Wine Red
'72 Epiphone acoustic
Marshall JCM 900 amp head
Roland Micro Cube (tiny thing screams!!)
"Keep it heavy, keep it metal"
xguitardevilx is offline   Reply With Quote
Unread 01-12-2010, 04:40 PM   #22 (permalink)
nick1962's Avatar
Not as slim as the 60s neck.
Unread 01-13-2010, 03:47 AM   #23 (permalink)
v8ko's Avatar
Great description. Im not a fan of the 60 slim necks and while I have a deep love for the 50's heftness the Slash profile really offers the best of both worlds to me.
circusboy28, Im sure your post was in jest but does a Gibson (take your pick) make you a better guitarist? Of course not lol , can it make you a wannabe? of course it did.
My new band The Disintegrators along with our new label will finally be in studio in 2016!
Having trouble keeping your Gibson tuned?
http://www.mylespaul.com/forums/gibs...ng-2-lead.html
[/COLOR]
Ive always thought of myself as a Hunter...but after looking at my gear Im pretty sure Im a Gatherer : p
v8ko is online now   Reply With Quote
Unread 01-14-2010, 09:24 AM   #24 (permalink)
mrtoulouse's Avatar
oh ohh. A local shop has just recieved a goldtop slash and it's at a really nice price. though I really do need an octaswitch and a tubeking(damn those things ROCK) more And I've aso planned to buy the new classic vibe custom tele... decisions decisions
- 2006, r6
- classic vibe tele
Unread 01-14-2010, 09:37 AM   #25 (permalink)
In any case, it's still chunkier than I prefer. I realize most LP players buy their guitars and then praise the necks, but I'm in the skinny neck camp, and I'm talking skinnier than a 60's. I think Gibson needs one more choice in neck profiles <G>.
Wide, thin and flat, with that Axcess neck heel. If I get famous, that's what my "sig" guitar will have...
Unread 01-14-2010, 02:34 PM   #26 (permalink)
i would never buy one of your sigs...
Alex
Guitars:
Amps:
Unread 01-16-2010, 02:23 PM   #27 (permalink)
mrtoulouse's Avatar
I would
dspelman: So do you play with sandpaper every time you bring a guitar home as well ? Been thinking that I perhapswas the only one who would be weird enough to start sanding something I have just paid over 2k for
- 2006, r6
- classic vibe tele
Unread 01-19-2010, 11:18 PM   #28 (permalink)
I love the neck on the Goldtop and wish I could duplicate it on all my guitars. That said, is it safe to say that each one is different?
