Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls
Unread 10-27-2009, 03:34 PM   #1 (permalink)
Noise from the pickguard?
I exchanged my cream pickguard for a black one on my ebony LP Standard Traditional Pro and ever since there is a fizzing noise when I put my finger on it while playing. Strange. It looks good so I don't want to take it off. (No I do not think it's due to the change of colour...). Any words of advice?
5939 is offline   Reply With Quote
Unread 10-27-2009, 03:36 PM   #2 (permalink)
The Devil's Advocate
The_Sentry's Avatar
Re: Noise from the pickguard?
The_Sentry is offline   Reply With Quote
Unread 10-27-2009, 04:26 PM   #3 (permalink)
I presume this is just an "acoustic" noise (not from the amp). I had a similar problem with my traditional - except that it buzzed unless I put my hand on it. The problem with mine was that the bracket was vibrating against the underside of the guard - the screw was tight, but there was still a gap between the end of the bracket and the pickguard away from the screw. Solution was to put a slight (and I mean slight) upward bend in the bracket, just enough so that when the screw is tightened the bracket presses up against the plastic of the guard all the way along. Hope this makes sense - might be nothing to do with your problem, but it fixed mine.
One other thing to watch for is that the screw fastening the bracket to the guard can get very close to the body, and can mark it if you bash it when playing hard. Could be this that's buzzing when you press it? I shortened the screw on mine and made the nut thinner by filing it, to keep it clear of the body. This is worth doing anyway if it's not got much clearance.
dpgumby is offline   Reply With Quote
Unread 10-27-2009, 04:40 PM   #4 (permalink)
kip0909's Avatar
Originally Posted by brayanaustin View Post
Whatever you do not try to lower your cable channel switch because son is not a string but a set of sub-size, so you must take two pounds of yarn and place it in a bag with a book. . They spent a crap load of welding and son and a lot of useless.
kip0909 is offline   Reply With Quote
Unread 10-27-2009, 05:05 PM   #5 (permalink)
Thanks, The Sentry. No, it's not an "acoustic" problem, though there's a dent under the pickguard just like you described. Itīs definitely an electric phenomenom and occurs regardless of which amp I use.
Unread 10-27-2009, 05:06 PM   #6 (permalink)
Wish I could help. I've never heard of such a thing.
Unread 10-27-2009, 05:08 PM   #7 (permalink)
The_Sentry's Avatar
Lose the pickguard = problem solved.
Unread 10-27-2009, 05:10 PM   #8 (permalink)
River's Avatar
I had the same problem just the other day. It went away.
Yes, I'm serious.
Unread 10-27-2009, 07:16 PM   #9 (permalink)
motowntom's Avatar
it is static elec. it is quite comon on strats of cheap mfg.( my 50th aviv. squire), rub a dryer sheet over the guard b4 playing. if you are recording or playing for extended time cover it with a clear shipping tape, the tape barrier stops the static. cheers
motowntom is offline   Reply With Quote
Unread 10-27-2009, 07:25 PM   #10 (permalink)
zeppelin101's Avatar
right there is a man who knows what he is talking about
A dirty joke is a sort of mental rebellion.
George Orwell
Originally Posted by dennistruckdriver View Post
Chicks are like buses....if you get in the way, they run you down....I mean, if you miss one, another will be along soon.
zeppelin101 is offline   Reply With Quote
Unread 10-27-2009, 07:31 PM   #11 (permalink)
hipofutura's Avatar
Wow, I was going to make some dumb ass comment like "remove the nibs". Sure glad I didn't!
Don
Unencumbered by Knowledge
Trapped inside this old man's body, is the mind of an old man
www.dcsysinc.com
www.seatrakinc.com
hipofutura is offline   Reply With Quote
Unread 10-27-2009, 07:34 PM   #12 (permalink)
snaredrum's Avatar
kip may have posted the most busy and non helpful post ever there!
good work
www.facebook.com/themadelinerust
snaredrum is online now   Reply With Quote
Unread 10-27-2009, 08:58 PM   #13 (permalink)
axepilot's Avatar
Correct!
axepilot is offline   Reply With Quote
Unread 10-28-2009, 12:47 AM   #14 (permalink)
Red face Re: Noise from the pickguard?
Thanks a lot guys. Why do you never go for the simple answer right away?
Unread 10-28-2009, 05:39 AM   #15 (permalink)
rockstar232007's Avatar
Where's the fun in that?
rockstar232007 is offline   Reply With Quote
Unread 11-27-2009, 11:46 AM   #16 (permalink)
VealCutlet's Avatar
THANKS! I had just done a full electronics swap-out - pots, caps, pickups, switch - on my Epi LP Standard and started getting this electric humming noise when touching the pickguard. I thought I had screwed something up with the rewiring. I removed the pickguard and didn't get the noise...then searched this forum, cleaned and de-staticized the pickguard...replaced it and NO MORE NOISE!
VealCutlet is offline   Reply With Quote
