Go Back   My Les Paul Forums > The Les Paul > Gibson Les Pauls
Old 02-17-2008, 09:02 PM   #1 (permalink)
buck7617's Avatar
Fret life
I bought my les in september of last year and today I was looking at the frets and noticed they were already developing ugly notches. Is this normal after this short period? This is my first new guitar all the others I bought already has considerable play. Is it possible to press to hard? How long do frets usually last? Do the fretts on a les paul have a shorter life than on a strat? Probably a dumb question but oh well.
buck7617 is offline   Reply With Quote
Old 02-17-2008, 09:29 PM   #2 (permalink)
Master Luthier V.I.P.
Roman Rist's Avatar
Re: Fret life
Sorry, it all depends on you.
I have refreted this one players guitar 6 times in the last ten years.
Some it will take ten years to need new frets.
They will last longer if you dress them every once in a while (maybe once a year), just because you will get more usable life out of them.
If you let the grooves get deeper, the repair man has no choice but to pull them out like bad teeth.
Roman
Factories build guitars for profit, Luthiers build them for players
Roman Rist is offline   Reply With Quote
Old 02-17-2008, 11:06 PM   #3 (permalink)
Scooter2112's Avatar
Re: Fret life
Is there any truth to the notion that nickel strings will cause less fret wear than steel strings??
"Have you hugged your Custom today?"
the CS Customs make the Standards sound like a plastic banjo with a live cat stapled to the back! - Hemply, 2009
Scooter2112 is offline   Reply With Quote
Old 02-17-2008, 11:29 PM   #4 (permalink)
BobbyK's Avatar
Re: Fret life
sometimes the frets wear down to a better size...
my oldest guitar has seriously worn frets on the top two strings, and it's so easy to play.
but, in time it'll probably need new ones
BobbyK is offline   Reply With Quote
Old 02-17-2008, 11:55 PM   #5 (permalink)
buck7617's Avatar
Re: Fret life
Ok another dumb question whats it mean to have your frets redressed?
Old 02-18-2008, 05:40 AM   #6 (permalink)
bobb6k34's Avatar
Re: Fret life
I wouldn't know about just the normal steel stings but i use stainless steel stings and thay do wear down the frets quicker than normal stings
bobb6k34 is offline   Reply With Quote
Old 02-18-2008, 06:16 AM   #7 (permalink)
v8ko's Avatar
Re: Fret life
Ive only ever worn down frets on my Lp. Ive owned plenty of guitars longer but no wear to speak of.
Hmmm.
v8ko is online now   Reply With Quote
Old 02-18-2008, 12:07 PM   #8 (permalink)
GeeJay's Avatar
Re: Fret life
Steve Howe's 175 still has the original frets in it IIRC..
GeeJay is offline   Reply With Quote
Old 02-18-2008, 03:27 PM   #9 (permalink)
Roman Rist's Avatar
Re: Fret life
The frets get filed so the grooves are gone and they are all a uniform height.
Next they are "crowned", what this means is they are rounded again,
They are then sanded and polished.
The end result is you have brand new frets again with a slightly shorter height
Old 02-18-2008, 03:36 PM   #10 (permalink)
buck7617's Avatar
Re: Fret life
Thanks!
Old 02-18-2008, 06:52 PM   #11 (permalink)
Liam's Avatar
Re: Fret life
If you're wearing out particular frets more than others (first 3 go on mine) then a partial refret every year or 2 makes a whole lot of sense. I have generally dressed them all down, but in future I'm going to see if changing a few frets will get the guitar going again. It does get expensive if you're heavy on frets. I'm OK until I start playing in "function" bands, and you just end up playing too many hours a week, and a lot of open chords.
Liam is offline   Reply With Quote
Old 02-19-2008, 12:33 PM   #12 (permalink)
Blues Power's Avatar
Re: Fret life
my 80 still has plenty of life left in them and so does my 88 Strat.
i prefer them a little worn. my 02 is a bit hard to play b/c imo the frets are still too new for my likings
when the crown is gone i find it plays the best.
but its all up to your preferece
Blues Power is offline   Reply With Quote
Old 02-19-2008, 07:26 PM   #13 (permalink)
LoKi's Avatar
Send a message via MSN to LoKi
Re: Fret life
My 79 has original frets. I've had them redressed once... They are pretty solid.
It really depends on how often you play and if you use heavy gauge strings, and if they are nickel or steel plated. Nickel is softer than steel and won't wear out your frets as fast, but frets are a wearable part that need plenty of attention.
www.youtube.com/LoKi6922
LoKi is offline   Reply With Quote
Old 02-19-2008, 07:28 PM   #14 (permalink)
LoKi's Avatar
Re: Fret life
Also I have 3-4 guitars that I use gigging regularly, and I use either my favorite Standard or my fav Custom for rehearsals, alternating each time. They all sort of wear out at the same time which sucks on the wallet, but hey! Thats life. No worse than getting tube amps serviced... Or your car for that matter. Maintenance must be done.
Old 02-20-2008, 03:47 AM   #15 (permalink)
Rock Star
coldsteal2's Avatar
Re: Fret life
Roman
Dang is the guy using rusty cables on it?
...........Cold Steal II Soundclick Songs ................. ColdSteal2's YouTube Videos.............MusicMight Secret Service
Still Rockin' at 56
coldsteal2 is offline   Reply With Quote
Old 02-20-2008, 04:19 AM   #16 (permalink)
lp59aholicDon's Avatar
Re: Fret life
IF you play in only certain areas of the neck or just a particlar scale in only one or two keys you can get this wear in various parts of the board, playing in as many keys as you can to try and even it all out helps, I have one strat I recently got needs a dressing but my main axe I have been playing steadily since 92 is still pretty damn good ( Les Paul)
Local guitar tech, Newbie Luthier , let me use his Stew mac tools to re level another Les Paul I had, maybe two hours work at most
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk
lp59aholicDon is offline   Reply With Quote
Old 02-20-2008, 04:26 AM   #17 (permalink)
lexluthier's Avatar
Re: Fret life
Depends on the quality of the fretwire as well. I noticed that some brands are softer than others and wear faster. Seems like Dunlop frets wear faster. Jescar wire from Germany is harder.
lexluthier is offline   Reply With Quote
Old 02-20-2008, 04:33 AM   #18 (permalink)
Re: Fret life
Will remember than when getting frets, Thanks Lex, Always helpful info from you
What does Stu Mac sell?
Best Night Of My Life!! dizmal The Backstage 2 05-11-2008 12:39 PM
You could practice your whole life... ArchEtech The Backstage 12 02-10-2008 01:27 PM
Tree of Life LPSWR Gibson Les Pauls 12 12-28-2007 05:43 PM
Perspective on life. Markster The Backstage 2 12-17-2007 05:59 AM
What is the meaning of life? Sean French The Backstage 78 10-14-2007 12:46 PM
