| View Poll Results: How do you treat the adjustment of the truss rod? | |||
| Leave it to the pros, don't want to cause damage. |
17 | 30.91% |
| Set the neck bow to the best spec I can find and leave it. |
23 | 41.82% |
| Take the truss rod cover off every time I set a guitar up. |
15 | 27.27% |
| Voters: 55. You may not vote on this poll | |||
LinkBack | Thread Tools | Display Modes |
#1 (permalink) |
![]() Join Date: Nov 2007
Truss rod poll
Just because the truss rod thread kind of interested me, here's a little poll on how people deal with truss rod adjustment.
#2 (permalink) |
Grumpy Old Luthier
![]() Join Date: Apr 2007
Re: Truss rod poll
You are not going to break your guitar with a mild twist of the rod.
Cool guitars, extreme repairs and brutal honesty. www.bcrmusic.com www.grumpyoldmenband.com http://www.youtube.com/user/unkagreg |
#4 (permalink) |
![]() Join Date: Dec 2007
Re: Truss rod poll
I check relief now and then...but I always stick with thte same guage strings and haven't had to adjust many of my guitars.....Most were set up by a good tech when I bought them and have stayed comfortable and buzz free....
#5 (permalink) |
Re: Truss rod poll
If it needs adjusting, I adjust it. But once the neck settles in, it doesn't require adjusting very much. It varies from guitar to guitar. Some I don't ever touch, others I adjust maybe twice a year at the most.
I agree that mild adjustments won't/shouldn't hurt anything. But if you don't know what you're doing, by all means have a pro do it. Or buy a cheap guitar and practice on that. This is good advice for any guitar work you want to do. Practice on a cheap beater before you work on your R9...
#6 (permalink) |
![]() Join Date: Oct 2007
Re: Truss rod poll
Fret strings at 1st and 16th frets ,use string as as staightedge to check
relief[0.004'' minimum at 7th fret][use a capo at 1st fret if needed].Provided you always keep the neck in concave relief[strung to tune] then you'll never damage a neck . The most damage you can do,is to cut your nut to optimum depth ,without first adjusting the neck relief to it's optimum setting.if you reduce the relief after cutting the nut the result can be open string buzz at the first fret.ALWAYS set required neck relief before final nut height adjustment,otherwise you'r likely to need a new nut.Every thing else is reversable[apart from when your adjusting saddle slots to maintain fingerboard/ bridge radius geometry].One Final thing is ,if you do adjust your guitar[or have it adjusted]to minimal neck relief, very low nut height and action height,you're more likely to be readjusting everything with changing weather condituions etc. |
#8 (permalink) | |
Re: Truss rod poll
#9 (permalink) | |
![]() Join Date: Aug 2007
Re: Truss rod poll
'92 Les Paul Studio '96 Les Paul Studio '05 Les Paul Deluxe '07 Voodoo LP Special Traynor YVC-20(stock) Crate Vintage Club 20 WB Pickups:Habeneros,Firewaters,67-07 VTPs,67-07 VTP Hotttsss,Greeny 67's
#10 (permalink) |
Master Luthier V.I.P.
Re: Truss rod poll
On my favorite guitar, I have not touched the truss rod in 15 years!
Roman
Factories build guitars for profit, Luthiers build them for players ![]() |
#12 (permalink) |
![]() Join Date: Feb 2008
Re: Truss rod poll
Damn dude thats a sturdy axe!
60% of the time...it works every time....Gun Control = Using Both Hands!! ![]() Everyone Please Pray for Sgt Jeffery Crones and the rest of the boys in iraq! Get some boys! Chris "The Gunhand" Of the MLP Pirates Crew 1986 Les Paul Jr (Cherry red Singlecut ) 1994 MIJ fender Telecaster 52 reissue 1984 JCM 800 1x12 50 watt combo Behringer 4x12 cab (Bugera speakers) |
#13 (permalink) |
Re: Truss rod poll
I check my neck regularly and only adjust when I hear and or detect problems ,
I am a sheepdog, Its not just a vocation, its my nature Live with it, Lead, Follow, or get the hell outta my way . Tis better to have the sword and live by it, than to reach in need and find the scabboard empty .Democracy is two wolves and a sheep voting on whats for dinner- Ben Franklin Don't be talkin' the talk if you can't walk the walk |
#15 (permalink) |
Re: Truss rod poll
I really don't fit into any of the three polled questions. At every string change, I check my relief, my guitars almost never need adjusting. I think I've adjusted my Custom 3 or 4 times maybe, I've had it 25years! I always check though.
#16 (permalink) | |
![]() Join Date: Mar 2007
Re: Truss rod poll
On a Rick which has a double Truss Rod, Bow the neck by hand first then tighten the truss rod nuts. Rick Truss Rods are way different than the usual guitar. |
#17 (permalink) | |
Re: Truss rod poll
I always set the truss rod to get the relief minimised when I'm levelling frets, so I guess thats an extra truss rod adjust every time. |
#19 (permalink) |
![]() Join Date: Jan 2008
Re: Truss rod poll
i have set up my guitar in the past and I have found out that the pros do it better (with my telling them what I want). I pays my money......
#22 (permalink) | |
Grumpy Old Luthier
Re: Truss rod poll
Just do it, you'll be fine. It's not a bomb, it's a tool.
#23 (permalink) |
Re: Truss rod poll
It depends on when something needs fixed. The local store I do business with will occasionally offer there service for free, a string change and adjustment.
Ive been pretty lucky over the years because I live in a REALLY REALLY dry climate but the humidifer runs year around and keeps things in order. I will do truss rod adjustments but past that Im clueless. |
#24 (permalink) | |
Re: Truss rod poll
Liam |
#25 (permalink) |
Re: Truss rod poll
I recently gave my TR a 1/4 turn on my STD because it had some minor fret buzz. It could have been imaginary. It seems okay now but I am thinking of taking it in for a proper set up. A pro will surely do a much better job than me. It would be interesting to see.
![]() 04 LP Std HCSB (Grace) 94 Epi LP Classic Birdseye Maple top (The Captain) Flextone III XL http://www.thesilverhorses.com/# |
#26 (permalink) |
Re: Truss rod poll
I tweaked the truss rod (slackened by 1/4 turn to give a bit more relief) when I brought my '02 standard home from the shop having fitted new strings and as part of finding the best set-up for me. I check the neck relief now and again, but it hasn't needed re-adjusting since that first time.
#28 (permalink) |
Re: Truss rod poll
Mine broke
in my top of the line, upscale , pretty expensive at the time in '93 ( $1,800.00 ) Fender Set-neck Strat. Plus it stripped at the adjusting end.Fender blew it with that one........ Traded a '70 Les Paul Blake Beauty for some of it too....Grrrr..... ( THE LP needed a neck reset ) I had to adjust the truss rod every week or two on my limited edition G&L ASAT JR ![]() My '68 BB LP, set it once in ten years. Same with my early '90's classic LP.
"Ape Shall Not Kill Ape” Only 1,970 years until the Reign of Zaius! ![]() I Use WB Pickups http://www.wbpickups.com/ "Trizzle Trazzle Trozzle Trome, Time For This One To Go Home!" http://www.sargescomics.com/ |
#29 (permalink) |
Re: Truss rod poll
never touched it on any of my guitars and my oldest is 28 now.
i dontt turst my local music store techs so I just leave it alone. no buzzzing no intonation probs so if it aint broke I dont fix it,. |
#30 (permalink) |
Re: Truss rod poll
If I like the guitar I'm too afraid to touch the truss rod on account that bad things happen when things fall into stupid hands. (like mine, lol)
Its something I've never really got round to doing cos a truss rod setup is really cheap and I can use it as an exscuse to visit a guitar shop. MVL.
www.weepingstrings.co.uk My music: www.myspace.com/weepingstrings My vids: www.youtube.com/victorlazarus Thank you.
| Epi Truss Rod | taypeng | Epiphone Les Pauls | 32 | 08-01-2008 01:54 AM |
| Truss Rod Covers | simppa9 | Epiphone Les Pauls | 14 | 03-10-2008 07:57 PM |
| Truss rod | raisinbrain | Gibson Les Pauls | 44 | 02-20-2008 05:09 PM |
| a new poll?????? | st.bede | Gibson Les Pauls | 5 | 02-12-2008 08:26 PM |
| truss rod??? | tarddoggy | Tonefreaks | 1 | 02-02-2008 05:08 AM |
