MyLesPaul.com
Go Back   MyLesPaul.com > The Les Paul > Gibson Les Pauls
Unread 08-09-2009, 11:47 AM   #1 (permalink)
nicolaidenmark's Avatar
Adjusting action?
I noticed some fret buzz but it's hard for me to turn the tunomatic "bridge-dials" with my fingers? I loosened the tension of the string already, how do you guys do it?
Yours Truly,
Fender VRI '57 Black strat / Gibson Les Paul Traditional (Ice Tea)--> Korg DT-10--> TS9--> T.C. Nova Delay--> Vox AC15H1TV
nicolaidenmark is offline   Reply With Quote
Advertisement
Unread 08-09-2009, 01:09 PM   #2 (permalink)
Re: Adjusting action?
Just what you did. Loosen the string tension a bit and man up!
lol
scozz is offline   Reply With Quote
Unread 08-09-2009, 02:17 PM   #3 (permalink)
lol
Are you suposed to do it with your fingers? The Trads don't have flat head screws in the top of the tunomatic bridge?
Yours Truly,
Unread 08-09-2009, 02:28 PM   #4 (permalink)
Dr. Brown's Avatar
You are trying to turn the thumb wheels that the bridge sits on aren't you?
Dr. Brown is offline   Reply With Quote
Unread 08-09-2009, 02:28 PM   #5 (permalink)
There are lots of little bits and pieces that will help you with this. StewMac (Stewart-MacDonald: Everything for building and repairing stringed instruments!) makes a little tool called the bridge jack. It's designed to work as a sort of lever to lift the bridge while the strings are in full tension so that you can rotate the bridge thumbwheels. Find it and you'll see what it does and how it does it and you'll probably be able to fabricate something along those lines to do the same thing.
dspelman is offline   Reply With Quote
Unread 08-09-2009, 02:34 PM   #6 (permalink)
Dr. Brown's Avatar
From what he said about the flat head screws I think he may be trying to turn the bridge posts instead of the wheels...
Unread 08-09-2009, 02:53 PM   #7 (permalink)
Correct... if this wrong..??
Yours Truly,
Unread 08-09-2009, 02:57 PM   #8 (permalink)
Dr. Brown's Avatar
No, not at all, you just confused me as to why you mentioned flat headed screws....
Unread 08-09-2009, 03:04 PM   #9 (permalink)
Ah, my bad: all flatheaded screws are connected with the tail piece, not the tune-o-matic...
So, fingers it is then?
Yours Truly,
Unread 08-09-2009, 03:09 PM   #10 (permalink)
JPaul's Avatar
Fingers, as you so rightly say, it is.
JPaul is offline   Reply With Quote
Unread 08-09-2009, 03:10 PM   #11 (permalink)
Dr. Brown's Avatar
No worries, yeah should move with your fingers even under full string tension.
If it won't budge take off the strings and the bridge then rub some graphite from a pencil all around posts.
Unread 08-09-2009, 03:25 PM   #12 (permalink)
dennistruckdriver's Avatar
...take off the strings and the bridge then rub some graphite from a pencil all around posts....
You guys and your 'pencil lead'....
A simple drop of oil will suffice, and will help to keep the threads from corroding in the future.
Unread 08-09-2009, 03:31 PM   #13 (permalink)
JPaul's Avatar
What type of oil is best for this sort of thing?
Unread 08-09-2009, 06:14 PM   #14 (permalink)
I find this works well:
....however, even a drop of clean motor oil will work. Wipe off any that squeezes or drips out.
Unread 08-09-2009, 07:30 PM   #15 (permalink)
kspeed's Avatar
I used to adhere to the pencil shaving method but it always left residue on my fingers and dirtied up the strings. Chapstick applied with a razor's my preferred method now, though what Dennis recommends (or vaseline, or KY) will work just fine
kspeed is offline   Reply With Quote
Unread 08-10-2009, 03:12 AM   #16 (permalink)
Dr. Brown's Avatar
I never like to recommend oiling things on guitars because you need to use it sparingly and really don't want oil getting into the wood of you guitar.
As Dennis says just a drop and make sure any residue is wiped off.
Unread 08-10-2009, 12:24 PM   #17 (permalink)
You guys are all ADD ("Oh Look, A squirrel!"), off on your oil discussion <G>.
Here's the StewMac bridge jack -- it's got felt on the back to keep from marring your guitar, and you can even use it while the guitar is in playing position to check the distance at the 12th fret. There are some other bridge and tailpiece tools here as well. You can probably build some variation on this contraption yourself. In fact, this was apparently a kludge...er...high concept tool (*ahem*) that StewMac found in operation at the Gibson factory to do this very thing:
Unread 08-10-2009, 12:28 PM   #18 (permalink)
NOT KY. That's water based lube (corrosion!) and it won't keep anything lubricated long term (read what it's made of). Vaseline is petroleum based, at least. There are also some lubes out there that leave teflon behind -- these are also excellent.
But none of these will help you get the thumbwheels turned under full bridge tension.
Unread 08-10-2009, 12:48 PM   #19 (permalink)
Dr. Brown's Avatar
Yeah were all ADD and you go and post a whole tool kit and a ****ing jack for turning the thumbwheels....
Unread 08-10-2009, 06:44 PM   #20 (permalink)
axepilot's Avatar
LMAO!
You don't need tools to turn the thumb screws - just loosen the strings a bit, adjust the action, and retune.
But I guess that there are those anal enough to require the tools..............
axepilot is offline   Reply With Quote
Unread 08-11-2009, 02:02 AM   #21 (permalink)
Dr. Brown's Avatar
Originally Posted by axepilot View Post
LMAO!
+1000
Unread 08-11-2009, 03:35 AM   #22 (permalink)
I loosen the string tension a bit and man up!
but i've got a lot of information as an amateur,so thanks guys
bzuka is offline   Reply With Quote
Unread 08-11-2009, 10:47 AM   #23 (permalink)
This set will run ya 5 bucks at Harbor.
secondrateplayer is offline   Reply With Quote
