Go Back   My Les Paul Forums > The Les Paul > Gibson Les Pauls
Old 03-11-2009, 06:55 PM   #1 (permalink)
armann's Avatar
Send a message via MSN to armann
Question Pickup installation Seymour Duncan.
Hi I'm trying out new pickups in my Les Paul.
This is what the manual says:
Standard humbucking operation
With a 4-Conductor humbucker: the Red & white wires are solderd together and taped, the green & bare wires are connected to ground, and black wire is the hot output.
The white and red are soldered and taped together, the green is soldered to the pot so the black should be soldered where the only wire from the previous pickup was soldered to ?
I'm sorry about the noob question I just want to do this myself and try to learn something.
Thanks.
What were becoming real big at that time were bands like Poison and Warrant – glam metal – guys that could barely play… but had crazy looking pants! - Paul Gilbert
armann is offline   Reply With Quote
Old 03-11-2009, 07:03 PM   #2 (permalink)
Re: Pickup installation Seymour Duncan.
That sounds correct. Both the green and black are connected to the pot, one is the ground and connected to the back (green one) and the other connects to one of the three little tabs sticking off the pot.
Take your time you should be OK.
You can check it on Duncan's site.
That link should provide the answer you need. If not post some more!
Robert
Sawgwa is offline   Reply With Quote
Old 03-11-2009, 07:20 PM   #3 (permalink)
zslane's Avatar
You've got it correct armann.
Les Paul Standards: ('96 Goldtop, '99 Ebony, '03 Honeyburst)
Les Paul Supreme: ('07 Trans Black)
Les Paul Custom: ('04 Alpine White)
Other Gibsons: ('01 Tony Iommi signature SG)
Click here for the full-size group photo.
zslane is offline   Reply With Quote
Old 03-11-2009, 09:08 PM   #4 (permalink)
armann's Avatar
Thanks guys.
One more thing, the manual says the neck humbucker be set 1/8" from the strings.
Converted to mm that's 3mm if I'm right, that's really close, is this correct ?
A bridge humbucker be se 1/16" at the high E-string and 3/32" at the low E-string.
Sound correct to you guys ?
1/16" that's only 2mm, now that's close and 3/32" I don't know how high that is in mm.
Just want some input, I know I should base it on my ears but some comments would be good
Old 03-12-2009, 04:58 AM   #5 (permalink)
armann's Avatar
Any thoughts about string height from the pickups ?
See last post ...
Old 03-12-2009, 09:40 AM   #6 (permalink)
That seems correct. You can adjust humbuckers that close to the strings. This is just a starting point. You can always adjust them later to suit your ear.
skeeterbuck is offline   Reply With Quote
Old 03-12-2009, 09:58 AM   #7 (permalink)
armann's Avatar
Thanks, just for reference do you have yours so close to the strings ?
Old 03-12-2009, 11:37 AM   #8 (permalink)
Blues Power's Avatar
those are just reference points you can go higher or lower dep. on the balance of the vol when you switch from the neck to bridge. if it too loud you go lower etc
i set mine by ear at rehersal or band levels and theyre way lower then the 3mm
Blues Power is offline   Reply With Quote
Seymour Duncan Pickup Guru : FLICKOFLASH Pickups 5 02-24-2009 01:30 PM
Seymour Duncan SH-4 JB pickup, Chrome Cover, $49 Jims Les Paul Member Classifieds 0 01-12-2009 09:02 PM
Seymour Duncan P-Rails on a Black Beauty 3 Pickup justlildavid Epiphone Les Pauls 0 12-06-2008 09:36 AM
Pickup Installation! Bluesjam Pickups 1 10-07-2008 06:44 PM
Seymour Duncan Pickup Booster Circuit EEF13 Tonefreaks 2 06-15-2008 10:43 PM
Powered by vBulletin® Version 3.8.4
