Go Back   My Les Paul Forums > The Les Paul > Gibson Les Pauls
Old 01-16-2009, 08:40 PM   #1 (permalink)
Klownkilla's Avatar
Want to change Pots and Caps"Suggestions"
I have a 1976 Custom Tobacco Sunburst.Want to change the pots and caps or maybe just the pots or maybe,I dont know...I just broke one of the pots and need some input.The pot is still good i just was spreading one out so the new knob would be snug and SNAP too much pressure.These are the originals i suspect so should i change the one or convert to another setup Helppppppp!!!!Heres a pic of the guitar.
Klownkilla is offline   Reply With Quote
Old 01-16-2009, 08:41 PM   #2 (permalink)
Klownkilla's Avatar
Unhappy Re: Want to change Pots and Caps"Suggestions"
Will send pic tomorrow sorry,having technical difficulties.....
Old 01-16-2009, 08:42 PM   #3 (permalink)
slowhand0461's Avatar
contact jonesy!!!!! He can hook you up!!!!!
"Crank up the Drums...Crank up the Bass....Crank up My Les Paul in your Face"
MOJO'd
slowhand0461 is offline   Reply With Quote
Old 01-16-2009, 08:43 PM   #4 (permalink)
'MLP Mid-West'
b-squared's Avatar
You're in luck...RS Guitarworks is have a 30% off sale on their Superpot volume pots this weekend.
Welcome to RS Guitarworks | Winchester, KY - Home
Give them a call--ask for Billy (he's a member here at MLP), and tell him what you are doing. He'll ask some questions, then give you a recommendation.
RS has caps as well, or you can contact Jonesy, our own "Capacitor Ambassador."
BB
I use:
WB Custom Pickups--6707 VTP/VTPH, 5707 Prototypes, Habaneros, Firewaters
DeTemple 'Sweet Spot' Pickups (Strat)
RS Guitarworks Electronics
Jonesy's Caps
b-squared is offline   Reply With Quote
Old 01-16-2009, 09:29 PM   #5 (permalink)
Master Crafter
Last's Avatar
Yep!
Be prepared to be amazed at the difference these tweaks will make too.
Also check out the Tonefreaks Sub Section of this forum.
Last is offline   Reply With Quote
Old 01-16-2009, 09:41 PM   #6 (permalink)
nakleh's Avatar
Send a message via AIM to nakleh
BB
Thanks for the heads up, BB.. I've been considering replacing the pots on my custom..
do you know anything about their "pre-wired" kits? Any negatives to worry about, considering it's pre-wired? I play modern rock, so I'd assume the "modern" kit would suffice me more than the vintage kit [there is no LP kit listed under vintage anyway]..
was looking at this one.. RS Guitarworks Online Store
edit: I see the sale is only on the superpots, but I am still considering the prewired kits..
nakleh
WebsiteMySpaceBand MySpace
2006 Gibson Custom Shop Les Paul Custom
1978 Marshall JMP 2204 • 1993 Marshall JCM900 4100 • Marshall JCM800 4x12 Cab
Egnater Rebel 20 Head • Avatar 1x12 Closed Back Cabinet
Mac Pro Tower • Pod XT • Guitar Rig 3
nakleh is offline   Reply With Quote
OT: Fender's "Black Beauty" !? Fender "John 5" Telecaster ethanleow Epiphone Les Pauls 9 09-26-2008 01:03 PM
How to identify "Alpha Pots" wantsa58 Epiphone Les Pauls 11 08-31-2008 03:03 PM
I want to change the caps, pots. etc in my new LP Standard Guitarman Gibson Les Pauls 18 08-10-2008 01:05 PM
(newbish question...) can someone explain what "pots" are? Tippsy- Epiphone Les Pauls 2 05-22-2008 02:55 AM
Caps, Pots, wiring? Suggestions geomcnasty Tonefreaks 6 01-06-2008 09:26 AM
