#1 (permalink) |
My Les Paul won't stay in tune!!
Hi guys
My 06 Gibby Standard won't stay in tune. Was thinking of changing the tuners but i'm not sure if that's the problem. Could it be the nut? It's my first LP so am quite a newbie. |
#2 (permalink) |
Re: My Les Paul won't stay in tune!!
Could be the bridge, maybe the nut, maybe the tuners, maybe the neck. Best thing to do would be to take it to a guitar tech and have him/her set it up.
#3 (permalink) |
Do you get a "tink" when you tune your G?
Les Pauls have notorious nut problems - shallow, binding slots. Easily solved in the long run with a pro nut filing job, replacing the nut; or in the short run with lubricating the nut.............................hell, lube the nut after a pro file job. I use Big Bends Nut Sauce to lube the nut. It works great. Some guys use pencil lead. The Les Paul's tuners are solid and not your problem. I would look to the nut for that. Last edited by axepilot; 11-30-2008 at 12:24 AM. |
#4 (permalink) | |
Give it a try, you will be pleasantly surprised! |
#6 (permalink) | |
![]() Join Date: Sep 2008
graphite under $2.00,problem solved
#9 (permalink) |
it's the nut. Lube it with graphite or Big Bends
http://www.myspace.com/satch0922 |
#11 (permalink) |
I have the same problem on my Standard and in a pinch I have used chap stick to solve the issue. Use on the nut and the bridge and life will be good again.
#12 (permalink) |
+1 Pencil lead always does the trick for me. Of course proper string installation is a must.
www.myspace.com/scorned_08 My Bar band road dogs: '05 Jooooooooooooooooooooooonyur Speeeeeeeeeeeeeeeeeeeshul w/ humbuckers (thanks to BCRGreg for the correct spelling)![]() '07 Les Paul BFG Hughes and Kettner Edition Tube combo Dime Custom Crybaby DB-02 |
#13 (permalink) | |
Chamber Champion
"HAVE YOU HUGGED YOUR PHAEZ TODAY ?" |
#14 (permalink) |
I use Chapstick (any flavor.
) on the nut and bridge on every string change. Works great!
"Have you hugged your Custom today?" ![]() the CS Customs make the Standards sound like a plastic banjo with a live cat stapled to the back! - Hemply, 2009 |
#15 (permalink) |
1. make sure you are keeping tension on the string while you're winding them around the tuners
2. make sure you stretch them after you tune them, then tune them again if you do that and there's still an issue then go with all the lubing solutions on the nut and the bridge. more often than not tho, its one of the things above. |
#16 (permalink) |
Grumpy Old Luthier
![]() Join Date: Apr 2007
Original Chapstick is best, but the Berry flavor adds upper harmonics to Norlins.
Cool guitars, extreme repairs and brutal honesty. www.bcrmusic.com www.grumpyoldmenband.com http://www.youtube.com/user/unkagreg |
#20 (permalink) |
That Ibanez Guy
![]() Join Date: Apr 2008
+1 to everything everybody's said.
On top of that, how do you wind your strings? Assuming you don't have locking tuning pegs, instead of simply sliding in your strings and wrapping them around the post try this:
#21 (permalink) |
Grumpy Old Luthier
That vid shows a ton of wrongs.
#23 (permalink) |
Chapstick?! Enlighten me! LOL. We have an overabundance of that stuff here.
Guitars, Music, and Enthusiasm! Paul Reed Smith Guitars, Diezel Amplification 08 PRS Custom 24 (whale blue quilt/birds) 06 PRS CE-22 (McCarty sunburst) http://www.youtube.com/user/Unseenbass http://www.myspace.com/munashiku Check out my guitar blog, Gear Madness! http://gearmadness.blogspot.com/ |
#26 (permalink) |
![]() Join Date: Mar 2008
![]() Been smearing it lightly on my nutz for years. No petroleum distillates like chap stick. There's not enough in chap stick to harm anything.
Never argue with idiots. First they drag you down to their level, then they beat you with experience.
#27 (permalink) |
Yeah i'll have to agree with everyone here. I used to get the tink on the same tuner every time I re-strung my guitar or changed tunings. Great advice
#30 (permalink) |
Could tell rest of your band to all play out of tune so ya don't stand out
J/K Try some nut sauce lubricant on the nut and bridge,or graphite from pencil will work for now |
| Installed New locking tuners but it won't stay in tune | Y&T | Gibson Les Pauls | 13 | 09-28-2008 05:19 PM |
| Does your Historic stay in tune ?? | BOBBO | Historics & Reissues | 51 | 09-03-2008 10:16 PM |
| Strings wont stay in tune. | MapleLeaf97 | Tonefreaks | 10 | 07-28-2008 09:02 PM |
| New Epi won't stay in tune | Gunnysmiles | Epiphone Les Pauls | 43 | 05-26-2008 08:48 AM |
| strings don't stay in tune? | taypeng | Other Les Pauls | 3 | 01-09-2008 05:47 AM |
