#1 (permalink) |
Tail piece wrap around technique...
This last time I strung her up, I decided to feed in the strings backwards into the tailpiece and wrap the strings around the bridge. Not only does it look cool, but it allows you to put the tail piece flatter. In addition the strings themselves sit much flatter after the bridge which really feels great to my dampening and wrist bracing. MUCH more comfy. Give it a whirl.
2007 Les Paul Custom 200x Fender Mary Kaye Relic V-Neck See thru Blond 2008 Fender Custom Classic V-Neck Daphne Blue 2003 MIM Strat Faded Green Metalic A couple of Alvarez Acoustics AMPS: VOX AD60VTX, Micro Cube |
#2 (permalink) |
Re: Tail piece wrap around technique...
There was another thread on string gauge that I asked a question and didn't get an answer to yet. Does this have any effect on tone or sustain?
" Less is More" www.myspace.com/brianlucasproject http://www.soundclick.com/blucas |
#3 (permalink) |
I'm not sure how I could tell since I switched up to 11's from 10's at the same time I chaged the tailpiece stringing method. I'm sure it would be really hard to prove an effect on tone other than what your ears say, which would mean I'd wager that people will have differing opinions on the effects to tone and sustain.
#5 (permalink) |
I can't see it really affecting sustain, but people think that if the tail peice is sunk down it will sustain better... if so its only marginal.
It gives a slinkier feel to bends and makes it easier for palm muting, thats for sure. The actual fretted note doesn't continue past the bridge while playing, but guitars that have a string thru body design instead of a stop tail seem to sustain better, so maybe there is something to it. I always string my LP's that way... always have... the old man showed me when I was a kid and it just stuck with me. |
#6 (permalink) | |
#7 (permalink) | |
#8 (permalink) |
the key is to get a Tone Tail. Not only is it "notched" so there is less of a tendency to break strings but they are made out of aluminum like the late 50's Les Paul tail pieces. I put one on my Wine Red Studio and it was a noticeable difference. Yes you can bolt the tail piece right to the body and the aluminum is know for it's affect on tone as well.
Tone Tail replacement guitar tail pieces You can see the strings over the top of the tail piece in this picture
1984 Les Paul Studio - Classic White w/factory Kahler 1991 Explorer - Classic White/Gold TP-6 1993 Les Paul Studio - Wine Red/Gold 1996 Les Paul Studio - Alpine White/Gold 2002 Les Paul Classic - Cherryburst/ Classic 57's 2007 SG Standard - Cherry Marshall JCM2000 DSL100 Marshall 1960 Lead 4x12 Crate V18 1x12 Tube Combo |
#9 (permalink) |
btw...check out Billy Gibbon's 59.."Pearly Gates"
#11 (permalink) |
ok, I'll have to give it a try. I have been playing one particular riff everyday for a while so I will restring and see if I hear or feel any difference.
Thanks,
#14 (permalink) |
![]() Join Date: Jul 2007
I use the ball ends off of an old set of strings, run the string thru them first. This helps the break angle on the wrap. Sorry for the crappy picture, but this gives you the idea
#16 (permalink) |
Here's my favourite axe (mine!) strung that way too:
![]() Looks good, is nice for resting the palm on and makes it easier to adjust the intonation too. |
#18 (permalink) |
A couple things to keep in mind when considering topwrapping:
- the TP is adjustable for a reason, slammed right down can increase sustain but lose some of the overtones. Many guys look for a sweet spot for overtones, close to the same break angle as over the nut. - if you have a low neck set angle the top wrap might not work - the strings will be crossing the TP too high. Here's a pic of the wrap on my Custom. The topwrap gives me about the same sweet spot with the benefits of a slammed TP,
#19 (permalink) |
I've done this before with my Les Paul's. I've liked it on some, but not others...weird.
I do top wrap my replica though, and have the tail down too. I prefer it this way on this particular guitar. It's much easier on the fingers also if you want to go up a gauge in strings.
#20 (permalink) |
I topwrap all my LPs except for my Customs. I like to use the ball ends clipped off of old strings & slide them on the new strings. Helps with the breakover angle like Dwagar said & prevents string pokage to your picking hand.
#24 (permalink) |
Once upon a time... I had an old '53 Goldtop with P-90's that only had the wrap-around type bridge/tail piece, but that's another story...
You guys got me curious as to the possible differences in tone/sustain/whatever by doing this on "newer" LP's, so last night I put on a new set of strings with the wrap-around. I didn't get a chance to really give it a test drive, but I will when I get home from work tonight. Stringing it up that way did bring back some bittersweet memories of the old days...
Larry J Griggs http://www.myspace.com/larryjgriggs 2005 Gibson Les Paul Studio Light Burst 2005 Gibson Les Paul 30th Anniversary Deluxe Goldtop w P90's Raised in Macon, GA Playing that "Southern Rock" stuff for 35 yrs |
#25 (permalink) |
I have always strung my pauls up that way. It allows you to place the tail piece on the body of the guitar, the way it should be. Here is a pic of my 94 classic strung up that way.
#26 (permalink) |
![]() Join Date: Sep 2007
I have a few new sets of strings, ill have to get off my butt
and try it. The thing is i just put a new set on last week, maybe ill wait a couple more weeks then give it a try. Does Gibson sell any of thier guitars strung that way since the 50's
