#1 (permalink) |
Out Of Phase Pedal?
Is there such thing as a pedal to make your guitar sound out of phase??
'11 Gibson Les Paul Traditional Pro Fender Affinity Series Squire Takamine G Series 6 String Synsonics Acoustic Guitar |
#2 (permalink) |
Re: Out Of Phase Pedal?
anybody
#3 (permalink) |
Not sure, but I sure would contemplate getting one if there was!
Gear: 2003 Fender Custom Shop '51 Nocaster Relic 2005 Fender Custom Shop Custom Classic Telecaster Amps: Fender '59 Bassman RI Pignose Legendary 7-100 Marshall MG15CDR MS II Rig: Plutoneium Chi-Wah-Wah Korg Pitchblack Lovepedal Eternity Black EHX Memory Toy
#6 (permalink) |
Bartlett Retrospec Member
![]() Join Date: Mar 2009
I would think not - if you don't have a stereo guitar. After the signal leaves your guitar the signal from both pickups can no longer be split like they can before the input jack so I don't believe it's possible.
Just flip a magnet and try it out first and if it's a tone that you'll use - get a push pull pot so you can swap between the two.
Bubbletonic on Youtube:www.youtube.com/bubbletonic |
#7 (permalink) |
Die Hard LP Man
![]() Join Date: Sep 2009
Out of phase in what way? The term is relative and for one signal to be out of phase it really needs too be referenced to another. (P Green PU different story).
If you want a thin phasey type sound then a phase shifter (which splits your guitar signal into 2, delays one (ie shifts it's phase) and mixes it back with the original signal. I seem to recall either an MXR model or mybe Elect Harm one that allowed you turn off the automatic function and manually set it to a particular one.
If you can keep your head while all about you lose theirs,.... you obviously haven't grasped the situation!! GEAR 2010 CS 50th Aniversary R0 V2 from Guitar Works 2012 CS R8 Iced Tea from Eddie's Guitars 2010 CS R7 Gold Top from Eddies's Guitars POD HD500 VOX Valvetronix VT30 |
