Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls
Like Tree4Likes
  • 1 Post By zslane
  • 2 Post By KenG
  • 1 Post By River
Unread 05-11-2012, 04:02 PM   #1 (permalink)
DanL's Avatar
Tune-o-Matic with adjustable saddles?
I did a quick Google search and can't find anything of the sort. Does anyone know if there is a tune-o-matic bridge with adjustable saddles? Adjustable height I should say. I'm aware they can be intonated, but I was wondering if anyone (Schaller or TonePros maybe?) had made a TOM bridge with individual height adjustments for each saddle like a strat bridge has.
If it's not out yet, I'm typing in legalzoom.com right now.
Not that it's that necessary for Gibson guitars because they're plek'd now and even before the nuts were cut pretty well for the most part, but on cheaper Les Paul copies this could really save the playability of the instrument. I've played a few cheaper ones (epiphones etc) that had great low action but one string (usually the G) would still buzz. It might be weird to have one string a bit higher than the other, but I'd prefer that as opposed to an overall high action on the guitar. Thoughts please.
Danny Gator and The Gator Den
DanL is offline   Reply With Quote
Unread 05-11-2012, 04:09 PM   #2 (permalink)
Bartlett Retrospec Member
dudu's Avatar
Re: Tune-o-Matic with adjustable saddles?
There are no such bridges that I know of, but what you could do is getting one without
notches and file them yourself to the desired depth. You may need to compensate by
raising the bridge a little, though.
Hop on my SoundCloud
dudu is online now   Reply With Quote
Unread 05-11-2012, 04:40 PM   #3 (permalink)
zslane's Avatar
Originally Posted by DanL View Post
It might be weird to have one string a bit higher than the other...
More than might be. I can't stand strings that don't conform, more or less perfectly, to the radius profile of the fretboard.
...but I'd prefer that as opposed to an overall high action on the guitar. Thoughts please.
Better still to only play guitars with straight necks, properly filed frets, and set up with the correct amount of relief. If that means staying away from cheap POS guitars, so be it.
River likes this.
Les Paul Standards: 1999 Ebony, 2005 CR7 Goldtop, 2008 VOS R8 Tobacco Sunburst
Les Paul Customs: 1993 Transparent Black (over flame maple top), 2004 Alpine White
Other Gibsons: 2012 50th Anniversary "Standard 24" SG, 2005 SG '61 Re-issue, 2002 ES-333
Click here for the full-size group photo.
zslane is offline   Reply With Quote
Unread 05-11-2012, 05:48 PM   #4 (permalink)
bdubbs's Avatar
Maybe the bridge has flattened on those guitars?
Guitars
2004 Les Paul studio Alpine White
2011 Les Paul Traditional Plus
Epiphone Masterbilt Acoustic
Amps
Mesa Boogie Mark V Head
Marshall JVM 210H
Blackstar HT-100
Blackstar HT-5 Combo
Peavey Ultra 60 Head
Marshall 1960a Cab
Marshall MF280 Cab
Check Out my Band!
http://www.sin4sin.com
bdubbs is offline   Reply With Quote
Unread 05-11-2012, 06:34 PM   #5 (permalink)
KenG's Avatar
Unfortunately most Gibson ABR bridges do not match the 12 inch FB radius! SoI've had to play with the notch depths to compensate.
River and tampa898 like this.
If you can keep your head while all about you lose theirs,.... you obviously haven't grasped the situation!!
GEAR
2010 CS 50th Aniversary R0 V2 from Guitar Works
2012 CS R8 Iced Tea from Eddie's Guitars
2010 CS R7 Gold Top from Eddies's Guitars
POD HD500
VOX Valvetronix VT30
KenG is offline   Reply With Quote
Unread 05-11-2012, 06:39 PM   #6 (permalink)
Here you go.I've spoke to Jeff several times,very cool conversations.
Babicz Full Contact Hardware - TOM#
onegoodtrick is offline   Reply With Quote
Unread 05-11-2012, 06:39 PM   #7 (permalink)
River's Avatar
Should I admit what I've done when this problem arises, especially on acoustics, where fvcking with the bridge involves sandpaper, softening glue, and risking total destruction of the guitar?
Probably not. But I will anyway. I adjust the nut and saddle slot depths with little pieces of 3x5 card.
Hey, it works.
DanL likes this.
Unread 05-11-2012, 11:34 PM   #8 (permalink)
DanL's Avatar
Hey, it works.
That's what I've been doing too, especially on acoustics that I buy used. Thought I could squeeze some money out of this idea though. But sadly it looks like it's already been thought of.
