Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls
Like Tree36Likes
Unread 04-29-2012, 11:39 AM   #1 (permalink)
Eddie's Avatar
Chrome vs nickel hardware sonic test
I was bored today and decided to perform a little A/B test to see the sonic differences in the two platings. My test went as follows:
The nickel plating on my Les Paul sounded fat, full, and thick with a ton of sustain and a lovely growl.
The chrome plating on my strat's hardware sounded much thinner and a little more sparklier, but not even close to the sustain and fullness of the nickel.
Conclusion:
To my ears, nickel is a far superior plating to chrome at least sonically. Next I will include the gold plating on my custom.
Hope this helped!
Chicks don't care how long your tenon is, just that you know how to use it...
Eddie
2003 Faded DC Special
2003 B7 Custom Black Beauty
2004 R7
2006 Explorer
Join the Black Beauty Rockers!
http://www.mylespaul.com/forums/grou...y-rockers.html
Eddie is offline   Reply With Quote
The Following 2 Users Say Thank You to Eddie For This Useful Post:
Unread 04-29-2012, 11:51 AM   #2 (permalink)
kdm
kdm's Avatar
Re: Chrome vs nickel hardware sonic test
.....those glorious instruments are often mocked for having all the suttelty of a sledge hammer
and the dynamic range of a chainsaw, a jangling noise machine.....
After all they only made so many guitars, and they ain't makin' any more.
kdm is offline   Reply With Quote
Unread 04-29-2012, 11:58 AM   #3 (permalink)
Keep em coming, lol.
What about strap lenght? Always wanted to know.
gypsyseven and Kerry_King like this.
Wiking is offline   Reply With Quote
Unread 04-29-2012, 12:00 PM   #4 (permalink)
Shawn Lutz's Avatar
Send a message via Yahoo to Shawn Lutz
tough to tell sarcasm these days so I honestly don't know if this is a satire thread or not. With that out of there not an accurate test. If you want a fair test use the Les Paul with a nickle bridge, used the same guitar same amp same everything setting and then swap the bridge to chrome
http://shawnlutz.com
Shawn Lutz is offline   Reply With Quote
Unread 04-29-2012, 12:07 PM   #5 (permalink)
Who
Who's Avatar
I don't know what is sillier, the fact that you did this test in April in Florida (humidity is all wrong, for sonic tests), or the fact that you did the test without changing to plating-matched cables.
Just running the two through the same cables isn't gonna do it.
Another thing: Science has shown, the main reason the results of this test are so hard to get correct:
- You (of course) can't run the tests on two different guitars (too many variables, as Shawn pointed out)
- If you swap the parts onto the same guitar, you run into all the tone-problems of re-using the same screw-holes. EVERYONE knows that the screw-holes on Gibsons are single-use (which is why original/un-modified is so desireable).
Please tell me that you at least ran the test before noon, and pointed the headstock angle 13 degrees higher when testing the nickel, to compensate for the specific-gravity of the elements.
Who is offline   Reply With Quote
Unread 04-29-2012, 12:38 PM   #6 (permalink)
Eddie's Avatar
perhaps the best way is to bind the two guitars together making them one cohesive unit and trying the test again.
Eddie
2004 R7
2006 Explorer
Unread 04-29-2012, 12:41 PM   #7 (permalink)
BillB1960's Avatar
Gibson LP Classic Antique Fireburst GOTW #2 Bolt Electric Vintage P'ups
Gibson LP G0 Darkburst GuitarForce LOTB P'ups
Gibson LP Special TV Yellow Fralin P-90s
Gibson Limited Edition Flying V 57 Classics
Fender Limited Edition Strat
Fender American Ash 8502 Telecaster
Fender Bullet Deluxe S2
Ibanez AR-250 SD Phat Cats
Epiphone DR500M Masterbilt
Epiphone 58 Reissue Korina Flying V
"It ain't what they call you, it's what you answer to"
BillB1960 is offline   Reply With Quote
Unread 04-29-2012, 12:43 PM   #8 (permalink)
Who
Who's Avatar
Would introduce too many harmonic-imbalances, due to the covalent bonding.
Eddie, You've been on MLP for four years, but you're acting like you don't even understand basic Gibson-physics!
Unread 04-29-2012, 01:04 PM   #9 (permalink)
MTwang's Avatar
I have nickel on my Tele, do you think that will help me with the straplocks?
MTwang is offline   Reply With Quote
Unread 04-29-2012, 01:07 PM   #10 (permalink)
Who
Who's Avatar
Straplocks on a Tele?! Teles CAN'T BREAK, so I see no purpose for straplocks on them.
Oh wait, maybe you're trying to protect the floor from getting broken.
MTwang and ed1996 like this.
Unread 04-29-2012, 01:13 PM   #11 (permalink)
Eddie's Avatar
You're right. I'm overthinking this like a rookie. Now I'm ashamed...
Eddie
2004 R7
2006 Explorer
Unread 04-29-2012, 01:54 PM   #12 (permalink)
joedonner2001's Avatar
So as the gold plating wears off, I guess the guitar's tone will gradually improve. There is light at the end of the tunnel for the gold hardware lovers.
Can you please also thoroughly test different toggle switch tips? I'd like someone to confirm my findings that the cream ones make the guitar sound more creamy and the black ones improve sustain.
Lowdown and DanL like this.
joedonner2001 is offline   Reply With Quote
Unread 04-29-2012, 02:51 PM   #13 (permalink)
Eddie's Avatar
I'm on it!
Eddie
2004 R7
2006 Explorer
Unread 04-29-2012, 06:05 PM   #14 (permalink)
Murfdog's Avatar
I performed a similar sonic test between solid and weight relieved guitars. I chose an '09 R8 for the solidbody and a Gibson J-200 for the chambered guitar. The solidbody had much more sustain, and produced a much more organic overdriven tone. The J-200 had very little sustain and squealed horribly when plugged into the overdrive channel. I concluded that chambered guitars are inferior.
Eddie, MTwang, DanL and 2 others like this.
Always this talk from musicians about equipment. ... It's all in the fingers and the brain/heart.--Flea
Murfdog is offline   Reply With Quote
Unread 04-29-2012, 06:12 PM   #15 (permalink)
Eddie's Avatar
That's the caliber of research I'm talkin' about!
Murfdog likes this.
Eddie
2004 R7
2006 Explorer
Unread 04-29-2012, 06:20 PM   #16 (permalink)
Malikon's Avatar
I hope pickguards were removed from both guitars before testing.
to be fair.
Malikon is offline   Reply With Quote
Unread 04-29-2012, 06:43 PM   #17 (permalink)
Satch0922's Avatar
Did you "Top Wrap" the nickel or chrome tailpiece?
Satch0922 is offline   Reply With Quote
Unread 04-29-2012, 06:49 PM   #18 (permalink)
HOT-BRIT's Avatar
after conducting extensive testing, I have always found that the gold hardware gives a much richer tone
Malikon likes this.
HOT-BRIT is offline   Reply With Quote
Unread 04-29-2012, 06:50 PM   #19 (permalink)
Not necessary, depending on whether the jackplate is plastic or metal. Unless it has been aged. And unless you're testing on a Les Paul Classic, and depending on the greenness of the fretboard inlays.
Everybody knows that.
Unread 04-29-2012, 07:14 PM   #20 (permalink)
Eddie's Avatar
It was a Les Paul Classic, but it was a 1991 model so no green inlays
Lowdown likes this.
Eddie
2004 R7
2006 Explorer
Unread 04-30-2012, 04:07 AM   #21 (permalink)
geddyleefan's Avatar
I've noticed some tonal differences in certain stopbar and bridges when theyre made of different metals. Nickel being full and sustaining and chrome being rather thin but with some bite to it. But thats just what I've heard after years of owning multiple LPs with different stopbars and bridges
'98 Gibson LP Classic
'98 Gibson LP Standard (3 pickup)
'97 Gibson LP Studio Gem
'96 Gibson LP Studio Gem (mini-hb's)
'05 Gibson LP Classic Plus
'01 Gibson LP Standard
'07 Gibson SG Standard
'05 Gibson SG Special w/P90s
'07 Epiphone SG-caster
'08 Gibson DSM-CE
'10 Recording King Gospel Songstress
'96 Fender Strat MIJ
'03 PRS SE EG
Marshall JCM900 combo
Vox AC100CPH
Peavey Royal 8
geddyleefan is offline   Reply With Quote
Unread 04-30-2012, 06:52 AM   #22 (permalink)
Eddie's Avatar
Nickel ages better which is probably why it sounds better. Old looking stuff always sounds better!
Eddie
2004 R7
2006 Explorer
Unread 04-30-2012, 07:12 AM   #23 (permalink)
MeKevin's Avatar
Eddie, how do you get the nickel to stick. I'm assuming glue of some sort. Does it matter if I don't plate mine?
Originally Posted by River View Post
But it's not worth the effort. I'd be preaching to the choir on one hand, pissing up a rope on the other.
"I'm gonna get out of here now, let the horn man come in."
MeKevin is offline   Reply With Quote
Unread 04-30-2012, 07:23 AM   #24 (permalink)
Dino Velvet's Avatar
I found that changing to the amber switchtip produced a cornucopia of sounds that had both bloom and sustain.
.....Where the down boys go.......
Dino Velvet is offline   Reply With Quote
Unread 04-30-2012, 07:38 AM   #25 (permalink)
Eddie's Avatar
1950's baseball card gum. Stuff is getting rare though!
MeKevin likes this.
Eddie
2004 R7
2006 Explorer
Unread 04-30-2012, 07:41 AM   #26 (permalink)
Eddie's Avatar
The switchtip is often overlooked. I have amber on all of mine except the strat. I bet that's another reason the lesters sound so much fuller!
Eddie
2004 R7
2006 Explorer
Unread 04-30-2012, 08:07 AM   #27 (permalink)
Who
Who's Avatar
Eddie, I'm not sure if you realize this, but instead of "nickel", if you spend the extra 20 cents and go with "quarter", you can get a whole new world of tone and sustain.
Lowdown likes this.
Unread 04-30-2012, 09:02 AM   #28 (permalink)
Eddie's Avatar
Man, that's an idea! I might just stick about three fiddy inside my control panel!
Eddie
2004 R7
2006 Explorer
Unread 04-30-2012, 09:08 AM   #29 (permalink)
tampa898's Avatar
I hear the Uranium 238 hardware really is the way to go. Iridium 192 is next and Cobalt 60 coming in behind that. Nickel and chrome are not where it's at these days.
1973 Les Paul Deluxe Tobacco Burst
1990 Lado Classic III
1992 HHR Stratocaster MIJ
2007 Les Paul STD
2007 Fender 62 reissue
2011 Custom Telecaster
Metaltronix M-1000 Head 4x12 Fender Cab
Crate V50 2x12
It's Not What It's Worth, It's What You Can Get For It
tampa898 is offline   Reply With Quote
Unread 04-30-2012, 09:19 AM   #30 (permalink)
Eddie's Avatar
I'm old school! Great advances though!
tampa898 and MeKevin like this.
Eddie
2004 R7
2006 Explorer
