Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls
Like Tree1Likes
  • 1 Post By lespaulrocker17
Unread 04-23-2012, 07:49 PM   #1 (permalink)
lespaulrocker17's Avatar
Talking Gold p90 covers
I saw these gold p90 covers online Gibson P90 Cover Metal Gold
I'm thinking about changing the pickup covers on my white 60s tribute.Would it change the sound on the guitar and will they fit?
ALZ likes this.
lespaulrocker17 is offline   Reply With Quote
Unread 04-23-2012, 07:51 PM   #2 (permalink)
LedZeppelin's Avatar
Re: Gold p90 covers
Edit: nvm
LedZeppelin is offline   Reply With Quote
Unread 04-23-2012, 08:13 PM   #3 (permalink)
Leroy's Avatar
Re: Gold p90 covers
On the bottom of that page it says "Gibson Factory Leftover".
I'm not aware of any P90 model that had gold covers but i'm by no means an expert. As to if they'll change your sound, i don't thinks so. If you can connect them to the ground then it may reduce noise somewhat. People will suggest that you may lose some high end due to extra capacitance introduced by the covers but i don't think thats the case.
Are you just changing the covers or are you going to change all the hardware to gold?
Leroy
Jtm20 "Bettie"
18watt liteIIB EL84
2002 Standard - DesertBurst - Wolftone MarshallHead A2 Bridge - SD Alnico Pro II Neck
2012 PRS Se Korina One
www.riffinery.com.au
Leroy is offline   Reply With Quote
Unread 04-23-2012, 08:45 PM   #4 (permalink)
NRBQ's Avatar
Re: Gold p90 covers
I just got a set from Ebay, pretty sure its the same guy. They haven't arrived yet so I can't say how they sound but I'll post the results when they come in. I would love to post pics but for some reason it doesn't take and I'm a techno boob so no pics so far.
NRBQ is offline   Reply With Quote
Unread 04-23-2012, 08:56 PM   #5 (permalink)
Re: Gold p90 covers
For those new to P-90s such as the ones on the 60s tribute model, there are a lot of "aftermarket" covers that don't fit. A lot of the plastic covers will need a grinder on the inside and outside to fit in the Les Paul.
You'll never know if these particular metal ones will work in your 60s Tribute or not until you try them. Also, the ad does not say THESE COVERS CAME FROM GIBSON. It says "checkout under Hardware/Specials Gibson Factory Leftover deals". While that might imply one thing or the other, there is a lot of wiggle room in that statement.
I hope they work great right out of the box. Just don't be surprised if you run in to issues.
If the box has genuine Gibson packaging, your chances are MUCH better of a nice fit.
02589 is online now   Reply With Quote
Unread 04-23-2012, 09:01 PM   #6 (permalink)
ALZ
ALZ's Avatar
Re: Gold p90 covers
so guys will that effect the sound ? see ya , alz --p.s. i like to leave my stuff stock , unless i change out the pickups for hotter ones !
ALZ is offline   Reply With Quote
Unread 05-05-2012, 09:15 AM   #7 (permalink)
CA-8-5799's Avatar
Re: Gold p90 covers
Hi,do you know if they have em deep enough for the bridge and neck? Thanks
CA-8-5799 is offline   Reply With Quote
Unread 05-06-2012, 04:09 PM   #8 (permalink)
NRBQ's Avatar
Re: Gold p90 covers
As far as I know my gold/metal covers were from Germany and are not made by Gibson. The ones I got were from "Crazy Parts" and they fit perfectly with no modifications at all. I love them and as far as I can tell the sound hasn't changed to my ear. But the look is spectacular, I have always hated the look of those plastic soapbar 90's with a passion and not sure why but these covers make the whole thing look completely different and really special, now I love the look more then I can say. I also got a gold mirror pick guard that is amazing and goes with the covers like pea's and carot's. I am getting a gold/metal toggle switch cover that has Rhythm/Lead etched or engraved in the metal. Someday I would love to find a way to change the vintage tuner buttons from that weird kind of green to butterscotch pearl buttons but no time soon. Here are a couple of pics of the LaBeast and her name is Lucy, Lucy Loob, no just kidding just Lucy O Ball or Lucy Plain and Tall, no just kidding again, just plain Lucy.
File Type: jpg LesPaul with gold pickup covers 004.jpg (92.5 KB, 28 views)
File Type: jpg LesPaul with gold pickup covers 003.jpg (92.2 KB, 21 views)
Unread 05-06-2012, 05:00 PM   #9 (permalink)
kdm
kdm's Avatar
Re: Gold p90 covers
the covers in question coming from "Crazy Parts".....
.....those glorious instruments are often mocked for having all the suttelty of a sledge hammer
and the dynamic range of a chainsaw, a jangling noise machine.....
After all they only made so many guitars, and they ain't makin' any more.
kdm is offline   Reply With Quote
Unread 05-08-2012, 09:02 AM   #10 (permalink)
CA-8-5799's Avatar
Re: Gold p90 covers
Thanks alot,man.I'm just looking for the covers and pole screws to fit a 68 goldtop.appreciate it!!!!!
Unread 05-14-2012, 03:54 PM   #11 (permalink)
CA-8-5799's Avatar
Re: Gold p90 covers
In answer to your Question,I've changed to chrome metal covers from plastic before and it did'nt change the sound a bit.Ive also got an ES-330 that has Metal dog ears on it from the factory in 64 and I changed em out to gold and never had a problem.
Unread 05-14-2012, 03:56 PM   #12 (permalink)
CA-8-5799's Avatar
Re: Gold p90 covers
To KDM,,Ive dealt with crazyparts in Germany before,For a headstock overlay,and it was perfect.I never thought about them.THANKS
