#1 (permalink) |
E String Problem with Grover Tuners
Hey guys.. Little problem concerning my high E string on my 2008 standard
Ive had the guitar 4 weeks and 3 High- E strings have broken on it. Any tips/ resolutions? Is it something to do with the lockers on the tuners being too tight Any response is greatly appreciated! Thanks! |
#2 (permalink) | |
Re: E String Problem with Grover Tuners
#3 (permalink) |
Switch it with another tuner, say the G string. See if the breakage continues. If so, it's most likely a burr, see if you can find it and smooth it out. If the breakage continues on the E string, it's something else.
#4 (permalink) |
The string will usually break close to where the problem is, like the other's have stated it's most likely to be a sharp edge at the saddle or tuner or even just the way you're stringing it up
#6 (permalink) |
Cheers for the quick replys!!
2 of the strings broke at the Tail piece so im guessing its the burr Any advice of resolving it? ![]() Cheers again! |
#7 (permalink) | |
![]() Join Date: Sep 2009
Their breaking at the tailpiece? You sure their just not coming unwound?
1973 Les Paul Deluxe Tobacco Burst 1990 Lado Classic III 1992 HHR Stratocaster MIJ 2007 Les Paul STD 2007 Fender 62 reissue 2011 Custom Telecaster Metaltronix M-1000 Head 4x12 Fender Cab Crate V50 2x12 It's Not What It's Worth, It's What You Can Get For It |
#9 (permalink) | |
![]() Join Date: Dec 2008
If they broke at the tailpiece, then there is something seriously wrong with that. What make of strings are you using? Are they cheap crap, or from one of the 'quality' brands? If they are breaking at the bridge saddle, then you need to consider having that looked at, as has been suggested, due to some burrs or over-sharpness. If they are breaking at the nut, then that's the area requiring attention. If they are breaking at the post, then it is likely that the tiny rod that is actuated in the locking tuner is cutting through the thin 1st string. On my '08 Standard I do not 'lock' the top two strings, but wind them conventionally.
[url]Live clip of Splinter at The Cavern, November 2006: http://www.youtube.com/watch?v=GxOCksQUKbI There are always crowds at Stonehenge. Doesn't mean they're all f*ckin' Druids... Just as long as the guitar plays, It'll steal your heart away, Steal your heart away... D Major is a key, not a pitch. |
#10 (permalink) |
Im using Ernie Ball Heavy bottoms and light tops so all this is really puzzling me :P...... They're not cheap so there must be a probelm
1 more attempt on an E string or im going to bet the bridge examined and fully set up to ensure it but thanks everyone for the help!
#11 (permalink) |
If it is a burr, emery paper folded (creased) into a "V" applied to the notch.
"I have always been baffled by the depravity of some and the stupidity of others." Tone Deaf"If opinions are like a**holes, you should be able to smell me from a mile away." Tone Deaf "There are two sides to every story. I am only interested in the one that makes me feel better." Tone Deaf |
#12 (permalink) | ||
get a piece of fine grade sandpaper and smooth out the string notch in the saddle. |
