#1 (permalink) |
neck bow
Hey,
so this has been bothering me for a while now. I have a '08 gibson les paul studio, and the neck is extremely bowed/curved. It started curving/bowing the moment the neck leaves the body (17th fret) - can this be fixed by adjusting the truss rod, or do i have a serious problem? |
#6 (permalink) |
Re: neck bow
push the big e string on the 1st fret and the 11 fret .
what is the space between the string and the 5th fret ? push the big e string on the 1st fret and the last fret . what is the space between the string and the 10th fret ? |
#9 (permalink) |
Re: neck bow
How is it curved? The action looks pretty low. ? I don't see any curve? Take a picture looking down the neck from the headstock
------------------------------------------- http://www.bluebellyguitars.com FACEBOOK Link http://www.facebook.com/pages/Blue-B...66137280086032 |
#10 (permalink) |
Re: neck bow
if u look at the two horizontal ones, i think u can see that the nut is rather forward (dunno if thats the right term) compared to being in a straight line from where the neck and the body meet. the ruler picture shows that too
is this what you were looking for? |
#11 (permalink) |
Re: neck bow
I can't see any abnormal bowing in these pictures. Your fretboard and the top of the neck look to be in line with the rest of the body. The back of the neck isn't supposed to be flat, if that is what you are asking. The neck is naturally "curved" so that you can easily move your hand around. Now if there is an abnormal curvature or bow, then yes, you could loosen the truss rod a bit. But if you're not having any intonation or stability issues, and it plays comfortably, then I see no reason to adjust it. Just my two cents.
#12 (permalink) | |
Re: neck bow
#14 (permalink) |
Re: neck bow
I think he's talking about neck angle? It looks fine to me, but as others have said take some actual measurements.
1993 Les Paul Classic Tobacco 2010 Les Paul Traditional Pro Goldtop 2008 SG Special Faded Worn Brown 1985 Ibanez RS420SB 2010 American Standard Stratocaster, CFM 1991 Gibson J30 2011 American Special Telecaster Martin 000CX1E |
#19 (permalink) | |
Re: neck bow
"push the big e string on the 1st fret and the 11 fret . what is the space between the string and the 5th fret ? push the big e string on the 1st fret and the last fret . what is the space between the string and the 10th fret ?" is showing you how to tell 'how bowed' the neck is. A string is straight so if you fret at 1st and at the last then you see the biggest gap at the 10th...that gap is how 'off from straight' the neck is. |
#20 (permalink) | |
#21 (permalink) |
Re: neck bow
It needs to be bowed a little, OR the frets filed at an ever decreasing slope so you dont have any dead frets. You can straighten the neck, but chances are youll have dead frets unless you set it up with an uncomfortably high action. Bottom line, yes, a little bow is the way it should be.
02 Gibson Les Paul Standard 07 Epiphone Les Paul Standard 05 Epiphone Les Paul Custom 03 Jackson DKMGTFF 94 Alvarez AED-200 Line6 Spidervalve HD100 MKII |
#22 (permalink) |
Re: neck bow
Actually I think he is looking at holding the guitar vertical and imagine a line extending down from the plane of the nut.
I think he is wondering why they aren't parallel, why the nut is back, behind the body, so to speak, as that plane would intersect the body somewhere in the middle. |
#24 (permalink) |
Re: neck bow
He's talking bout the set neck angle to the body. That's why he put the ruler along the body and has it pointing down the neck.
If he was trying to show the bowing of the fretboard from string tension he would have laid the ruler on its edge on top of the frets. rockerbebn, you do not adjust the neck set with the truss rod. Truss rod is for adjustment of "neck relief" which is the very slight curve on the top of the fretboard when your strings are all tuned up. If your neck set angle is a problem (doubtful) you will have to see a luthier (guitar builder) or service center. Best way to evaluate you neck set angle would be to take the guitar in to a shop and compare it to other les pauls.
10' Gibson R6 Goldtop Darkback 08' Gibson LP Standard Ebony 11' Gibson Midtown Ebony Marshall JVM 410C 03' National Steel "EN" Resonator 10' Yamaha FS720S Ebony Acoustic
#25 (permalink) |
Re: neck bow
Do you mean the neck is twisted at the nut?
Guitars: 2010 LesPaul Trad Pro Gold Top 1994 Tele Black 2011 Tele build Sonic Blue Amp: Peavey Classic 30 Ibanez TSA15H Tube Screamer head Old 20w Crate SS |
#26 (permalink) | |
Re: neck bow
I'm trying to say that, say if i made the guitar's body and neck disappear, and put the base of the fretboard flat on the ground, the nut/headstock area of the fretboard would be much higher than the base. does that make sense? I know that les pauls have an angled neck. Sorry if I'm being unclear! but i really appreciate all of your input ![]() well I've had mine for four years, but it's the only one I've had, and only recently have I had the realization that I can set it up myself and such. I've worked with the action and pickup height, dropped the bridge, and stuff like that, but never messed with the truss rod or the neck itself. |
#27 (permalink) |
Re: neck bow
Sorry, but I really don't think you do.
If the guitar plays well, fuggedaboutit. You're fine. If it doesn't, don't touch a damned thing, and take it to a good tech.
#28 (permalink) |
ACE FREHLEY'S BASTARD SON
![]() Join Date: Nov 2009
Re: neck bow
Which one are you talking about??
![]() '08 Gibson Explorer '01 Gibson LP Standard Tobacco '10 Gibson LP Traditional Plus Desert '10 Gibson LP R8 VOS Lemon '12 Gibson LP Ace Frehley VOS Budokan '12 Gibson SG 61 Reissue '09 Epiphone LP Standard Plus '10 Epiphone SG G-400 '11 Epiphone Limited Edition Thunderbird IV Bass A few other guitars..... Marshall DSL100 & VM 2266CB, Pignose, Crate BV120 Eleven Rack, Kemper KPA http://soundcloud.com/aceluek http://www.youtube.com/user/Earnhardt12345 |
#30 (permalink) | |
Re: neck bow
haha fine i have no idea what i'm talking about, ill accept that. ACELUEK, it looks just like the 'up-bowed one'- maybe not as extreme, but yeah |
