#1 (permalink) |
How Do I Shave the Neck of my Standard Faded???
Its too damn gummy, I want it smoother what technique should I use?? anything special I should do for the Faded??
#2 (permalink) |
![]() Join Date: Aug 2007
Re: How Do I Shave the Neck of my Standard Faded???
I use a green scrubbie to take the gunk off the back of a neck
'92 Les Paul Studio '96 Les Paul Studio '05 Les Paul Deluxe '07 Voodoo LP Special Traynor YVC-20(stock) Crate Vintage Club 20 WB Pickups:Habeneros,Firewaters,67-07 VTPs,67-07 VTP Hotttsss,Greeny 67's
#4 (permalink) |
Use 0000 wire wool and a little bit of lemon oil.
Take your time and use your hand to do all the work. Rub your hand along the neck following the grain and it'll all come off nicely. |
#5 (permalink) |
My Classic is that way also...
Its goooey ...like stepping in some bubble gum in a parking lot. Question is....whats is the neck gonna look like after it gets the steel wool treatment ? Just Curious...
#7 (permalink) |
this was from when i sanded the neck with 400 then 800, you more or less get a soft dull finish. You will get similar results with the steel wool.
![]() ![]() I eventually decided to take it all the way down, its was faster after dulling the finish... but after taking it all the way down and applying some tungs oil now its super fast!
"Last time I called shotgun, we had rented a limo... so I fuxked up." -Mitch Hedberg ![]() ![]() insanity is genius in disguise http://www.myspace.com/cheapmaltliquor |
#9 (permalink) |
![]() Had mine done professionally and tung Oil is the way to go bro'.
"To realise your dreams you must first go to sleep..." I dream of being up on Blueberry Hill Proprietor of "The Bare Back Club" The place where discerning gentlemen discuss the benefits of a well shaven & oiled lady... Gentlemen Please Sign Up Below http://www.mylespaul.com/forums/grou...back-club.html If you like Joe Bonamassa Then follow my link below. Thank you http://www.jbonamassa.com/affiliates...ate.php?id=765
#10 (permalink) | |
... yours looks awesome by the way! I dont think people realize just how much that finish will slow you down until you play a neck thats been stripped bear, rubbed in with tungs oil and polished with 0000 steel wool... its just no going back lol
#11 (permalink) |
I have to agree it is a very smooth ride and so it is hard to play anything else once you have become accustomed to it.
Well worth the effort and makes for a fantastic gigging guitar now. Sweat and Lacquer generally don't make for great feel! We should start a Bareback Club!
#12 (permalink) | |
#13 (permalink) |
I just created a Bare Back Club for the boys. Come on in all that prefer them shaved...
#14 (permalink) |
#15 (permalink) |
I found on all mine that once I have polished them a few times that they are a lot less gummy. Maybe just breaks em in a little. Worth a try before you attack with scratchy stuff. Just my two cents.
#17 (permalink) |
I've done refins where I've left necks bare and masked off a "stinger", but how do you guys actually create the stinger on a guitar that's already finished?
#19 (permalink) |
So the wood is now raw and exposed to the elements or did it just
remove the glossy coat and some of the color ? |
#22 (permalink) |
I would imagine tapping it off heavily might do the trick.. not to sure. I plan on adding a stinger to my neck, since i took off that areas paint when i shaved mine.. Just got to find some poly that will match and I hope it will take a minute to paint it. Just gotta find out what type of paint to use.. should i ask Roman about this?
Heritage Cherry Sunburst Epi Les Paul Standard Vintage Dimarzio Super Distortion pups 50's style wiring harness from Jonesy "MLP's Official Thread Pirate Plunderer"
MLP Thread Pirates |
#23 (permalink) | |
You could use pure tung oil, but it literally takes days to dry and cure fully, especially here in the south. It also will feel more gummy. Whatever route you decide to go, be sure to hit it with 0000 steel wool for a ultra smooth finish.
#25 (permalink) | |
travismbrown, Apply light coats of tung oil and use the steel wool between coats. Tru-oil works great too. |
