Go Back   My Les Paul Forums > The Les Paul > Gibson Les Pauls
Old 07-23-2008, 07:35 AM   #1 (permalink)
Fitting Firebird mini hum on Les Paul Standard?
I want to try out a firebird style pick up on the bridge of my Les Paul Standard, in place of the full size Hum currently there. Is this possible? What mounting pieces would I need?
If it's not possible what would the closest alternative to a firebird pup be?
sonof101 is offline   Reply With Quote
Old 07-23-2008, 07:38 AM   #2 (permalink)
Boleskinehouse's Avatar
Send a message via Yahoo to Boleskinehouse
Re: Fitting Firebird mini hum on Les Paul Standard?
It's called a Les Paul Deluxe.
http://www.geartalk.com Join us..
Old 07-23-2008, 07:43 AM   #3 (permalink)
I'm sorry, I couldn't resist. I don't think there's any way to do that. The Deluxe already has mini hums..
My '76...
Welcome to the forum! Which I think is more like an insane asylum this morning.
Old 07-23-2008, 07:49 AM   #4 (permalink)
TheWellGoodShow's Avatar
Send a message via AIM to TheWellGoodShow
there is a way, i remember it was goof something, its like a pick up ring extension try googling it. there was a thread that had something on it
"Now Known as The Post-O-Matic 5000"
ZOMG! Its Gemma!!
TheWellGoodShow is offline   Reply With Quote
Old 07-23-2008, 07:52 AM   #5 (permalink)
Yes, but I don't think they actually sell those in a kit or anything. Not to mention how bad it would look, IMO. A nice used Deluxe wouldn't be very expensive..
Old 07-23-2008, 08:35 AM   #6 (permalink)
hmm true they are ugly, but why do you want mini bucks on a les paul?
ZOMG! Its Gemma!!
Old 07-23-2008, 08:51 AM   #7 (permalink)
I want a firebird pickup, it's different to a normal mini hum. Looks like I may have to upgrade to a deluxe in order to do it.
Old 07-23-2008, 09:00 AM   #8 (permalink)
AXE
AXE's Avatar
+1 on the fact their different p'ups... I have a set from my old bird that I'm going to use in the "Axeplorer" Project ,One is going bridge the other is going middle and a 500t for the bridge .
Sorry for the drift . Keep us posted .
The Whole Pickguard Thing Keeps Me Awake Nights
AXE is offline   Reply With Quote
Old 07-23-2008, 09:07 AM   #9 (permalink)
AXE
AXE's Avatar
Okay back on topic .
Do you have the original F/bird mounting rings ? If so it appears they will mount right up . The bird rings are a bit wider top to bottom and narrower front to back . And appear that they will cover the cavity .
Old 07-23-2008, 09:10 AM   #10 (permalink)
stevefried's Avatar
I looked into putting a mini humbucker into one of my Epi Les Pauls to get a Neil Young sound. I talked to a guy (don't remember the name) at Willies American Guitars in St. Paul MN. Between us we thought maybe with a custom mount (maybe brass or plastic) it could work. Otherwise I know there's minis that are made to go in place of full size humbuckers. Look at GFS website.
stevefried is offline   Reply With Quote
Old 07-23-2008, 09:12 AM   #11 (permalink)
My answer to this thread should have been, "I have no idea." !
Old 07-23-2008, 09:28 AM   #12 (permalink)
You got it, I want the Neil Young sound but out of my Standard! That is a p90 on the neck (for which I can use a gibson p94) and a firebird on the bridge. So You reckon If I got F/bird mounting rings they would fit on the Standard OK?
Old 07-23-2008, 09:39 AM   #13 (permalink)
AXE
AXE's Avatar
The bird rings are flat and need to be contoured to meet the radius of the arch on the Paul . I'm thinking they will probably work ...
Roman or Greg may be of more assistance ...
Old 07-23-2008, 01:29 PM   #14 (permalink)
Grand Pappy in Chandler's Avatar
The Firebird pup rings screw onto the top of the body w/ 4 screws. The pup is attached to the pup ring w/ 2 screws used for height adjustment.The Firebird body is flat.
The LP Deluxe has a contured top as mentioned earlier. The mini's in the LP are mounted using a hollow plastic housing. The LP uses only 2 screws which screw into 2 threaded inserts in the bottom of the pup cavities. These 2 screws hold the pup housing and the pup itself to the guitar and act as height adjustments for the pups.
I hve no idea as to the dimensional differences between an Firebird mini and a LP type mini.
I just assumed the dimensions were the same.
Sounds like a lot of work and mods in order to install any mini in an LP standard.
I agree it probably wouldn't look too good either.
Good luck!
Grand Pappy in Chandler is offline   Reply With Quote
Old 07-23-2008, 02:27 PM   #15 (permalink)
Grumpy Old Luthier
BCRGreg's Avatar
I can make up a ring to do the job, call me at the shop on Thursday(off Wednesdays).
717.730.9775
www.bcrmusic.com
www.grumpyoldmenband.com
http://www.youtube.com/user/unkagreg
www.ristguitars.com
BCRGreg is offline   Reply With Quote
Old 08-11-2008, 10:12 PM   #16 (permalink)
captain tightpants's Avatar
It ain't hard, this took me 15 minutes to bang together. I'm guessing a nicer one might take an hour.
Have we had a Firebird thread yet? Hackubus Other Gibsons 100 11-29-2008 02:38 PM
Firebird, Should I? Skynyrdpicker Other Gibsons 41 07-16-2008 01:01 PM
Firebird versions? pequod*123 Other Gibsons 10 05-16-2008 10:08 PM
Mini Les Paul Guitars FLICKOFLASH The Custom Shop 23 03-31-2008 08:34 AM
Firebird Tuners Weldaar Tonefreaks 2 03-21-2008 03:20 PM
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
