Go Back   Les Paul Forums > The Les Paul > Gibson Les Pauls
Unread 02-18-2011, 11:57 PM   #1 (permalink)
MNDZA's Avatar
Sounds too dirty?
I notice on my Traditional Pro that when I have the knobs turned to ten that the sound is kinda dirty and not well defined....very noticeable when trying to play chords. I'm connected to an AC15C1 on the clean channel with regular and master volume both about halfway. Lowering the guitar knob volume to 7 or 8 gets rid of the dirty sound. Is this normal?
MNDZA is offline   Reply With Quote
Unread 02-19-2011, 02:28 AM   #2 (permalink)
Re: Sounds too dirty?
I would imagine that's normal. It's nice to have a slight crunch on 10 and then be able to roll off slightly to clean it up. It's versatility (don't always have to be on 10). With the Pro having 500k pots wired 50's style, that definitely sounds normal to me.
Hichisky is offline   Reply With Quote
Unread 02-19-2011, 02:45 AM   #3 (permalink)
PsychoCid's Avatar
Yep, that's what volume does. As long as it's dirty and not 'scratchy,' anyway.
PsychoCid is offline   Reply With Quote
Unread 02-19-2011, 06:43 AM   #4 (permalink)
Sicboy's Avatar
If you find it too muddy for you, you might want to play with the tone knobs and roll them back a bit. That will tighten it up and give you some edge that is raw.
Sicboy is offline   Reply With Quote
Unread 02-19-2011, 06:57 AM   #5 (permalink)
If you're not happy with your tone, try adjusting the pickup height.
scozz is offline   Reply With Quote
Unread 02-19-2011, 07:12 AM   #6 (permalink)
mainiacs's Avatar
Is the Traditional also wired 50's style?
mainiacs is offline   Reply With Quote
Unread 02-19-2011, 11:06 AM   #7 (permalink)
MNDZA's Avatar
Thanks for the responses. I thought maybe something was wrong because I would leave all the knobs on max on my previous strat and with single pickups it still sounded clean. I get a similar effect on my LP if I coil tap.
Unread 02-19-2011, 11:19 AM   #8 (permalink)
River's Avatar
I almost never have the volume(s) on 10 when playing Humbuckers or P-90s. I set the amp's drive up into Cat Scratch Fever territory and only tap into it for searing leads with (or at least including) the bridge pickup.
Strumming all six strings with the volumes on 10 drives the amp into max distortion. If you never want it that distorted, turn it down.
You essentially can't set a dirty amp the same way for both Strats and Les Pauls. It doesn't work. Clean's another story.
