#1 (permalink) |
Metal plate in control cavity
So people have mentioned if I wanted to remove a little and I mean little weight I should remove it from my 79 custom.
But just curious why gibson started using them? Was it just easier to put the electronics on? |
#3 (permalink) |
Re: Metal plate in control cavity
The Gibson LP I am restoring, I am considering not putting my plate back in it. I am using it just to hold the pots as a template while I do all the wiring and soldering. then remove them complete with the new caps and all from the plate and install them into the cavity without the plate..
1998 Gibson Les Paul Studio 2007 Epiphone Les Paul Goth 2009 Epiphone Les Paul Special II 2010 Ohana SK-35 Soprano Ukulele 1010 Ohana SK-21 Sopranion (pocket) Ukulele 1930 Harmony Soprano Banjo Ukulele 1930's Gretsch Tenor Banjo 1930's Supertone 406, 5 string Banjo 2011 Epiphone Les Paul Concert Ukulele |
#4 (permalink) |
Some people claim a huge difference in tone without the plate, but I've never tried it. Also, IIRC, the plate requires long shafts, but without it you can use short shaft pots. I assume the long shafts would still work with some adjustments.
#5 (permalink) | |
Yes, the long shafts will work just add an adjusting nut to the stem. I have all the original pots for mine, but replacing them with CTS 500k 10% premium pots, and PIO caps. I still might use the plate, or not. Undecided about it really.
#6 (permalink) | |
#7 (permalink) | |
#8 (permalink) |
I am pretty confident (having rewired my gibby in the last couple of weeks) you still have to have long pots. You need to rewire the switch and jack as well (or have horrible joined telephone wire in the control cavity).
It's easy enough to do though. |
#9 (permalink) |
Think so.. I think the Gibby uses long pots, and the Epi uses the short pots is because the thickness of the top is thicker on the Gibbys.. That, and the plate both, but the thickness of the tops are the biggest contributing thing.
